Question about KitchenAid KSSO48QM Side by Side Refrigerator
Replacing the water dispenser lever
How do I access the inside of the water/ice dispenser unit to replace the water dispenser lever? The part of the lever where the glass makes contact (the part marked 'water') is scratched and worn and I would like to replace it myself as soon as I get the part.
  • 291 Answers
SOURCE: Ice dispenser not working
Pull out auger & try With Out auger in place with door open and see if auger motor will spin with out auger and tray IN.. you with have to push door switch in to get auger to work .. with door open
Posted on Sep 12, 2007
SOURCE: ice "door" on dispenser
This happened to me this week. I removed the cover as you suggested. After sliding it up you must disconnect the ribbon cable to the buttons, which involves depressing a locking tab. I then noticed one of the two plastic mounting points for hinges for the ice chute door flap (part of the black plastic frame) was cracked. I repaired this (the part was still hanging by a thread of plastic) using two part 5 min epoxy resin. Note disc-like damper which must be inserted into the cylinder when reattaching the door flap and attaches to an arm that connects to the door flap near the hinge. I'll let the epoxy set overnight before attempting reassembly...
Posted on Sep 29, 2007
SOURCE: ice dispenser spring in door
There should be two slots in the bottom of the panel. Use a screwfriver to pop this out. You will have to unscrew the electrical panel to expose the dispenser area. Be wure to unplug the unit first and be careful not to break any wires.
Posted on Sep 23, 2008
  • 64 Answers
SOURCE: the water dispenser, ice dispenser and the light
check for power at the switches in the panel, if you have power then the circuit board has likely died
Posted on Jul 10, 2009
  • 70 Answers
SOURCE: water won't come out of the dispenser
check for if that source line is either pinched, clogged, severed or a routing valve or solenoid needs replaced.
Also check the house line where you tapped into that supplies the refrigerators water.
Posted on Jul 27, 2009
  • 256 Answers
SOURCE: Water dispenser works, ice maker makes ice but doe not dispense
Remove the ice bucket/container from inside the freezer compartment. Examine underneath at the front of the container to see if ice cubes are lodged between the metal blades. If cubes are caught in this area, they will prevent ice from dropping into the glass/cup.
Posted on Feb 22, 2010
0 characters
1 Points
Model #WSF26C2EXY02. Why is ice maker not making ice?
When the ice-tray is full it pushes 'UP' a lever that shuts the water supply off. When you move the lever down all goes back to normal.
Oct 14, 2015 | Whirlpool 25.6 cu. ft. Side-by-Side...
Whirlpool refrigerator water dispenser not working
hve u tried to clean any blockages in the unit.let me know wat other problem u face
Oct 23, 2008 | Whirlpool GS6NBEXR Side by Side...
Whirlpool side by side with a broken water dispenser
you may have a sticking water lever or a bad water valve.
the lever can be changed from the front and you should know if it sticks.
the water valve can be replaced from the rear of your unit. it is the plastic part where the water line hooks up to the unit.
Jan 03, 2010 | Whirlpool GS6NBEXR Side by Side...
I have an electrolux sisde by side with an in door water maker (model EI23CS55GS1). Its about 1.5 yrs old and the water dispenser in the abruptly stopped 2 days ago. The Ice machine is still working just...
More than likely the microswitch for the water lever has failed or broken.
You'll need to access the dual water valve on the back of the unit to determine that when you press the lever - the solonoid on the valve is getting voltage.
If it is getting the turn on voltage - the solenoid is bad and needs replacing.
If it is not getting a signal voltage - the switch is bad.
CLICK HERE for all the diagrams to your unit.
Unfortunately - most parts on this unit are unavailable. I have checked 3-4 different vendors.
This unit also uses a electronic board controller instead of individual components that can be easily replaced.
The replacement module for this unit is $376 and can be seen HERE as part #38C.
The dispenser module (#8) is not available.
Contacting the Manufacturer may be your best bet in finding replacement parts or an authorized repair center that can access the parts.
CLICK HERE for their service locator.
Thanks for using FixYa!
Jan 02, 2010 | Electrolux Refrigerators
Mold/Bacteria formed between ice dispenser and dispenser lever Can dispenser be removed from lever for cleaning? If not, how to clean?
Use a bathroom mold and bacteria remover spray available from most supermarkets. Also spray down into the feeder on the inside of the door. Make sure you rinse the area thoroughly after use and run water through the water chiller dispenser and run some ice throughthe ice dispenser and throw these away. Then it should be safe to use.
Sep 30, 2009 | Kenmore Refrigerators
My whirlpool fridge/freezer
probally need to replace inlet vavle. first check to see if valve powers up when you hit lever to recieve water. you can hear valve humm if not then replace micro switch above the lever inside dispenser housing
Jun 07, 2009 | Amana ARS2464B Side by Side Refrigerator
Icemaker will not stop dispensing ice
Can you confirm please does it dispense water by itself if you select water? have you tried lifting the ice maker stop lever by hand? At a guess from your fault description I'd say you need a new dispenser micro switch. at worst a new Ice maker unit inside freezer. cheers
Mar 26, 2009 | GE Refrigerators
Ice machine makes ice but doesn't dispense when the lever is pres
I would check for an electric "flap" that opens & closes when ice lever is depressed. My GE has one and it has been fouled before causing the ice to be stuck inside the door. Hope this helps!
Mar 05, 2009 | Whirlpool Gold White-on-White 21.9 cu. ft....
I have a 12 year old Whirlpool side-by-side refridgerator (ed20db) with water and ice dispenser. I have not used the water dispenser for years, but for some reason when I hit the lever yesterday, it did...
you have a possible water valve that is not shutting off all the way on the water dispensing side, it has 2 coils, one for ice and one for water. the other possibility is the dispenser tank is frozen, from being too cold in the refr. section and thats causing water pressure to continue running even when not pushing the lever. let the unit warm up slighty on the refr side and see if you can get water to flow properly.
if not working after warming up, then you might have to replace the water inlet valve.
Dec 29, 2008 | Whirlpool GS6NBEXR Side by Side...
Ice/Water dispenser is dispensing crushed ice only.
You could have a problem with the lever that changes from one to another. If you can access the panel behind that door you may be able to see if it is mechanical or not.
Dec 27, 2008 | GE GSS25JFPCC / GSS25JFPWW Side by Side...
KitchenAid KSSO48QM Side by Side Refrigerator Logo
22 people viewed this question
Top KitchenAid Refrigerators Experts
John Tripp
John Tripp
mike cooper
rugby prop
Are you a KitchenAid Refrigerator Expert? Answer questions, earn points and help others
