Question about Canon PIXMA MP150 All-In-One InkJet Printer
Canon PIXMA MP150 - using too much toner
It seems like my printer is using too much toner. I only print maybe 10 pages/day and the last 2 black cartridges only lasted a little over a month. I always use the grayscale medium, not the best quality. I notice the spent cartridge is kinda gooey too.
What is "m!". Thanks very much for your clear answer
Posted on Nov 07, 2008
    Scholar:
  • 41 Answers
Some of the cartridge are not full of "ml". try to check the label before you install the cartridge..
Posted on Feb 11, 2008
SOURCE:
Black lines on print, new printer
Go to the settings on your computer hit properties and do an alignment, sometimes if you take out the ink cartridge and put it back in it will say do you want to do an alighment, then after the page prints you have to scan it, then pick which one looks the best
Jan 28, 2014 | Canon PIXMA PRO-10 Professional Photo...
New ink cartridge only last less than two weeks after printing less than 30 pages
I had that model and the same experience. I kept buying ink until I realized I could have nearly bought the printer for nearly the same cost as ink refills, black and color. I also had an HP. Same thing. I finally bought the Kodak 3250. The ads about ink costs was so correct. Many more pages are printed before the "need ink" message is displayed. Buying ink online saves even more.
Mar 27, 2012 | Canon PIXMA MP150 All-In-One InkJet...
My PIXMA MP150 starts printing from the LAST PAGE of a bunch. How can I make it start from the FIRST PAGE ??? Many thanks
In the driver you can select the printing order. You must select it in the properties of the printer in the control panel, printers menu; but not when you are trying to print in any program because it only should be useful for that program..
Thanks.
Dec 11, 2010 | Canon PIXMA MP150 All-In-One InkJet...
Have just replaced the ink cartridges and window says error 2 and will not print any answers please ???
just go to this link....
someone already have the same problem and the solution is...........this link...
http://mallcom.wordpress.com/2007/10/23/canon-mp150-reset-codes/
or just press the colour or black button for at less 5 seconds.....
Jan 07, 2010 | Canon PIXMA MP150 All-In-One InkJet...
Canon PIXMA MP150 How can I scan a small item but print it large
Use scale up settings, or fit to page.(can come out very poor quality) found in page layout tabs,
Jul 12, 2009 | Canon PIXMA MP150 All-In-One InkJet...
I just solve my first problem for code e8, thanks. after i start printing another problem came and keep flashing e2 and e7. what shall i do? got plenty pending printing to do. thanks
From Canon tech site.1. Load paper correctly then press Black or Color button (MP150)
2. Press ON/OFF switch to reset the multifunction device
3. Remove Packing Material MP150 / MP170 / MP450
4. Removing obstruction from ASF then press Black or Color button (MP150)
5. Reseat ink cartridge (MP150 / MP170 / MP450)
6. The MP150 may require repair
Jun 20, 2009 | Canon PIXMA MP150 All-In-One InkJet...
Improper printing
Clean the cartridge or replace it.
Feb 21, 2009 | Canon PIXMA MP150 All-In-One InkJet...
Printing are more costly.
it shows but the cartridge will print till the end.do not worry it will work properly.
Aug 15, 2008 | Canon PIXMA MP150 All-In-One InkJet...
Canon MP150
How to reset the Canon MP150 after a refill (Step 10 concerns refill; instructions below the steps):
Method1 (Safe Factory Method):
1) Disconnect the printer’s power outlet
2) Press and hold the power button while connecting the power outlet back.
3) While still holding down the power button, press the reset button twice.(red circle with a triangle)
4) Release the power button
The printer takes about 10 seconds to show the number 0.
5) Press + to change the value from 0 to 1.
6) When this value is 1, press colour button; this will light up two leds.
One is for plain paper and the other for photo paper. At this point is feed the printer with paper.
7) Press the power button twice and the printer will print a some stuff (if this page doesn't print by itself, press the "color" button once and the test page will print). Don’t worry much about the printed material. I got some stripped lines and some numbers. I believe that my colour cartridge is clogged which is why I got the green strips.
When you print this sheet the value in the display returns to zero.
8 ) Open the printer cover cover (not the scanner cover) and remove the cartridges. With the printer still open, disconnect the power outlet.
9) Close the lid and turn on the printer.
10) Refill cartridges and place them back in their nice little abode in the printer.
Aug 07, 2006 | Canon PIXMA MP150 All-In-One InkJet...
Canon PIXMA MP150 All-In-One InkJet Printer Logo
44 people viewed this question
Clive
Clive
old marine
old marine
Ekse
