Question about RIM BlackBerry 7290
Can't find ringer icon
Thanks for reminding me how to display the phone off/on.vibrate icon.
i dropped the phone and when i re-booted it the icon was missing
  • 44 Answers
Menu show all icons
Posted on Jan 03, 2008
How do I turn the ringer on, on the handset?
Press program/mute button to confirm and you may program the following items: Set Language, Handset Name, Ringer Tone, Ringer Volume, Message Alert, Ring To Answer, Security Code, VIP Melody, Key Tone, Audio Predial, Vibrate Ringer, Area Code, Tone/Pulse, Registration, Deregistration and Default Setting.
Ringer Volume
From the Handset Setup Menu:1. Press the caller ID-volume ( 6 or 5) button to scroll to the RINGER VOLUME sub-menu.
2. Press program/mute button to enter the menu. SET RINGER 1HI 2LOW 3OFF shows in the display.
3. Use the touch tone pad on the handset to select 1, 2or 3, or use the caller ID-volume ( 6 or 5) button to scroll to your selection. HI is the default setting.
4. Press the program/mute button to save your selection. You will hear a confirmation tone and the new volume setting shows in the display.
NOTE: If you turn the ringer OFF, the ringer off icon shows in the display.
May 27, 2016 | Uniden Cordless Phone
Tracfone customer service
  1. Check a ringer volume and profile. Press a volume key to see the volume status bar at the top of the screen. Use the volume up and volume down keys to adjust the loudness of the ringer (scale 0 to 30). Tap on the text next to the ringer icon to change the profile (vibrate only, ring+vibrate).
  2. Check if the issue is with a specific ringtone: Go to Settings > ringtones+sounds > Ringtone, and tap on a playbutton to preview the ringtone.
  3. Switch off the ringer vibration (Settings > ringtones+sound > vibrate) temporary, to determine if your phone is affected by any motion settings i.e. Flip-to-Silence.
  4. Make sure that call forwarding is not switched on: Tap the phone icon > ... > Settings.
If the problem persists, restart your phone by pressing and holding the power and volume down keys simultaneously until the phone vibrates. Release and the phone will restart. After this operation, you may need to re-adjust the volume and set date+time on the phone. Note that this does not remove your personal content.
Mar 13, 2014 | Computers & Internet
My phone will not vibrate at all anymore
Hi
Make sure your ringer is not in vibrate mode. Try These this thing first
Press Menu > Settings/Tools > Settings > Sounds > Ringer Type > Voice Calls.
Select Caller IDor No Caller ID. (A list of ring type categories will be displayed.)
Select a category, and then use your navigation key to scroll through the available ringers. A sample ringer will sound as you highlight each option.
Press OK to assign a ringer. Make sure your speaker works. Turn On your speaker phone while talking to someone and see whether you can hear or not. Make sure the increase the volume using keys on side of your phone.
If none of these works the ******** motor needs to be cheked for loose connections inside the phone.
Thanks for using Fixya
Mar 24, 2011 | LG Ally Cell Phone
Can the jitterbug ringer be turned off?
You can set your phone to Vibrate or silent mode so that the phone vibrates rather than rings. With the phone on and open, look at the inside screen while adjusting the ringer volume using the rubber volume button on the outside of the phone. As you adjust the volume, the inside screen will display the ringer volume level. It ranges from Max to Vibrate. Simply turn it down until the level reads Vibrate.
If you would like more step-by-step instructions, please call our Customer Service department at (800) 733-6632. We are available 24/7.
Feb 14, 2011 | One Touch Jitterbug One-Touch Cellular...
My iphone keeps buzzing and shows an icon of the ringer with a slash thru it it wont actually ring, just vibrates altho the ringer is on
"An icon of the ringer with a slash through it"?....Usually that means that the ringer is OFF.If you're sure that the ringer is in fact ON , then check your profile.If it's in the Silent or Meeting profile, the ringer is switched off by default and it goes to vibrate.
Jan 09, 2010 | Cell Phones
The phone does not ring - ringer is off.
firstly read the operations manual for that phone look on how to adjust the settings of your phone it probably sure was indicated there, because the way i see from what you posted it has no internal circuitry prob. it just needed an adjustment.. hope this advice helps... ;-)
May 24, 2009 | Panasonic KX-TG2343 Cordless Phone
Intermittant vibration ringer
well try holding pound or thee button by the button by the camera
Jan 13, 2009 | Samsung Propel A767 Cell Phone
Reminders!
the phone has to be taken to a service center and have the either ringer replaced or it could be a software issue and then it would have to be reflash for the calendar reminder to work.
Sep 16, 2008 | T-Mobile Dash Smartphone
SPH-M300 continuous vibrate
I can solve this problem drop the phone on the floor, the problem is that the programming of the phone has messed up and is keeping the vibrating going so either buy new phone or keep dropping the phone till it stops vibrating
Jan 26, 2008 | Samsung SPH-M500 Cellular Phone
RIM BlackBerry 7290 Logo
50 people viewed this question
Top RIM Computers & Internet Experts
ismael castillo
David
Jerry Greenberg
Jerry Greenberg
Are you a RIM Computer and Internet Expert? Answer questions, earn points and help others
