Power / Battery
On my IBM thinkpad the area where you plug in the charger is broken the "male plug" is wobbly...Is there anyway to fix the problem myself without spending alot of money?...I know it is a old notebook but It works fine for me right now...I want to know if it is worth trying to save or should I just get a new notebook?
  • 1 more comment
  • naah-naah Dec 03, 2007
    Thanks Ron,
    I might try to fix the problem myself but I have to find the time the mean time I'll just use my desktop and start shopping for a new notebook.
  • magnet69 Apr 02, 2008
    yes need a Fujitsu Amilo L1300 service manual
    my email is
    i have the board in bits just need to know wer to solder the middle input pin as the 1 on this as broke away
  • iamdan Apr 27, 2009
    i have the same problem. Acer Aspire 9410. email is
I need to be pointed to the repair manual. i have the other manuals but none that tell me how to remove the motherboard.
Posted on Nov 22, 2008
  • 324 Answers
Hey, naah-naah!
In order to do the needed repair, you'll need to remove the motherboard. Feel up to that? It's really not that bad of a job if you can invest a couple hours of time, you're good at keeping track of screws and handy with a soldering iron.
If you want to give it a try, let me know what model you're working on and I can point you to a repair manual.
As to the question of whether it's worth it, or not. I guess that you are the one to answer that. ;o)
If you need any additional information, please feel free to ask. If this information has assisted you in the resolution of you problem, please return here to give my assistance an appropriate final rating. If this information has answered your question and/or lead to a resolution, please rate it as "Fixya!".
Thank you, and have a super day!
Posted on Nov 30, 2007
My IBM Thinkpad won't turn on after improper shutdown.
Always check power supply first. Ensure green/orange charging light appears in the LED bank near the screen bottom when adapter is plugged in. If NOT then charger or battery (or motherboard) is faulty.
A dead battery shouldn't cause a shutdown, so the charger is the first suspect. The yellow power socket can become 'rusty' in some cases so inspect this also. If the contacts inside aren't clean & shiny then try some WD40 after scraping gently with a 1 or 2mm flatblade screwdriver (with the battery OUT). If not even a P.O.S.T. (Power On Self Test - IBM logo)
appears with the CDROM and Hard Drive removed, Try cleaning the memory and swapping its position on the back of the unit. Good Luck.
Jan 24, 2014 | IBM ThinkPad T20 2647 Notebook
IBM Thinkpad 2647 will not power on , i plug it in to charge and orange light flashes 5 times then stays solid orange . I can leave it plugged in for days and will not change , it will also not turn on...
This is a tricky problem, you need to troubleshoot this bit by bit - first take the memory out one stick at a time and try to turn it on each time, then try the hard drive. If it boots further with one of these things out then you know thats the problem. If it still doesnt boot after trying these components then you need a repair as it will be an onboard component.
My immediate guess would be the onboard power supply unit, unless your charger is broken and you can test with another charger to rule that out too.
Feb 26, 2011 | IBM ThinkPad T20 2647 Notebook
My IBM R51's battery ran down. Connected the
If it is the first time its happened, has your charger fused/broke.
Is the lead from the power block to the laptop loose??
Jul 09, 2010 | IBM ThinkPad R51 Notebook
IBM ThinkPad T30 2366 not start without battery
It is NOT Battery or Power Supply it is your laptop itself has gone faulty... You need to troubleshoot the Motherboard, hard Drive etc, to find the exact problem that will allow you laptop to start. A laptop, will go, with just the power supply, and NO battery, if it doesn't either Power Supply is faulty, regardless of lights, OR the laptop's motherboard or hard drive is faulty, you must isolate problem.
Feb 26, 2010 | IBM ThinkPad T30 2366 Notebook
IBM T22 laptop can't get it to start and not battery or charger.
What may have happened is that your power supply may have malfunctioned. I would try to plug another cable (new and functional) just to deny that this is the problem.
Nov 11, 2009 | IBM Thinkpad T22 Notebook
IBM Thinkpad won't work with adapter and won't recharge battery
Well he shorted out the regulator inside that tells the unit the battery needs to be recharged in witch transfers it to AC current, on this unit the rugulator is implemented in the motherboard and that wold not be practical ether to replace unless you find one for parts on for cheap and do it yourself that would be the only way that would cost you less money- thanks
Apr 30, 2009 | IBM ThinkPad R51 Notebook
A new charger costs $15/$40 , if you keep using the one sealed with tape you risk to damage the laptop.
Follow the good advice given by the customer support and get a new charger instead.
You can have the charger repaired for $60 or get a new one for $20:
IBM Lenovo Thinkpad R60 R61 90W New AC Power ...$21.95
Feb 07, 2009 | Lenovo ThinkPad R60 with Wireless Wide...
Thinkpad A31 2652
Sometimes a BIOS upgrade will cure battery charging behavior...
Feb 16, 2008 | IBM ThinkPad A31 Notebook
Battery charging recepticle
Here is a link to the IBM manual - warning what you want to do is probably a complete teardown of the machine and soldering equipment.
You may want to buy the power jack before taking it apart.
Try they have the right one.
Dec 27, 2007 | IBM ThinkPad T21 2647 Notebook
Computers & Internet Logo
127 people viewed this question
David Payne
David Payne
