Question about Sharp Aquos LC-42D62U 42 in. LCD HDTV
Image set up
Is there an ideal image set up (balance between the color, contrast, backlight, brightness etc) to get the best image posible in a Sharp Aquos 46" LCD?
  • 1 more comment
  • Anonymous Jan 01, 2008
    I am wondering about the quality of the picture. When I view the credits at the end of the show, white lettering on black, the white lettering seems to fade and then come back brighter. This happens all the time and is really obvious when there is a black background. Is this a setting problem or a tv problem? It is still under warranty.
  • Anonymous Mar 15, 2014
    vizio VO420E. powers on and audio fine. colors appear "solarized" or "negative" looking. this affects the entire screen, and the menu settings (brightness, contrast, tint, etc) do not fix the image.
  • Anonymous Mar 21, 2014
    trying to set to set up the perfect balance picture settings
What is cmc saturation and what setting should it be. What is 3d y/c slow,standard, fast or off. What setting should that be. What is range of opc setting. Function range max or min. What is opc on display mean. Thanks Doris
Posted on Feb 23, 2009
  • 71 Answers
Baclight 80%
Contrast 70%
Brightness 50%
Color 50%-60%
Tint 50%
Sharpness -6 to -8
OPC off
Posted on Dec 06, 2007
The best contrast and brightness settings for a toshiba crt floor model tv,model 50A61
Televisions are unlike other consumer electronics products. Their setup and settings have a tremendous effect on how well they perform. The best TV on the market incorrectly setup will almost always look worse than a mediocre TV setup well.
Ideally, you'll get a setup disc to ensure the correct settings, but regardless, it's important to know what each setting actually does.
To get the ultimate performance out of your TV, a full calibration by an ISF Certified technician is your best option. Even if you go that route, it's good to know what the calibrator is adjusting. So here's a quick look at the basic settings every TV has, and what they do.
Please keep in mind, this is only a general guide in what each setting does, and rough idea how to set it. Correctly setting up a television is a completely different article.
Where to start
Nearly all modern TVs have picture modes. These are labeled things like Standard, Cinema, Vivid, and so on. Cinema or Movie is often the most accurate setting, with all the controls set to offer an image close to what a director intended them to look like. Most people aren't used to an accurate image like this, and to them the TV may appear reddish, soft, and possibly dim. Technically, it isn't. Other picture modes like Vivid or Dynamic are programmed to "pop" on a store sales floor with an overenhanced, blue image. Because most people don't change any of their TV's settings, this has resulted in most people thinking a TV should look blue.
The choice is yours, of course, but we here prefer an accurate image and suggest you at least try it for a few days. Once you get used to it, you'll never go back. Check out What's the best picture mode? for more info.
Regardless, all TVs need tweaking to look their best. Here's what the main controls do.
Only LCDs have this control (though not all of them). This is a direct control of how bright the image is. Setting this lower will reduce eyestrain, and save a little on electricity. Before you adjust Contrast to make the image brighter, try here first. Check out LED LCD backlights explained for more on this.
Some plasmas have a control that drives the pixels harder, which in some ways acts similar to a backlight control. Samsung's name for this on their plasmas is Cell Light.
Sometimes labeled "Picture." This control makes the image brighter...up to a point. Every television has a maximum light output. Once you reach this point, increasing the Contrast control further actually degrades the image. Correctly set, you would see a fluffy cloud in a bright sky. Set too high, you'd see a blotch of white instead. As mentioned above, try setting the overall light output of an LCD with the Backlight control first (if available). Then adjust the Contrast.
This controls how dark the dark areas of the image are, again, to a point. Every TV has a minimum light output. Once you reach this point, decreasing the Brightness control starts removing "shadow detail." Correctly set, you'd see all the detail in a black leather jacket at night. Set too low, and it would be a black area on a black area, probably with a head sticking out of it. For more information on how the contrast, brightness and backlight settings interact, check out my article on contrast ratio.
Can be thought of as color saturation. Setting this too high will make everything look cartoony. Setting it too low will make for an expensive black-and-white HDTV.
Rarely will you need to adjust tint, a vestigial control left over from the CRT "tube" TV days. It gives a green or magenta shade to the image.
Jun 23, 2016 | Toshiba Televison & Video
The color on my sharp flatscreen is messed up and i can't get it to adjust
Go to menu and select factory default settings from the remote control. Then adjust brightness, contrast, sharpness, color etc. to your likings.
Jul 16, 2012 | Sharp Aquos LC-45GD4U 45 in. LCD HDTV
My Sharp 40'' LC-40E67UN has a dull and dark picture. Tried manual settings, not helpful. They have OPC automatic, not helpful.
Backlight -6, Contrast 32, Brightness 0, Color 0, Tint 0, Sharpness 0, CMS HUE = R 4,Y 1,G0,C 10,B0,M0; CMS Value R-6,Y0,G-10, C 10, B 10, M0 ColorTemp = Low, Active Contr=Off, Film On, DNR Off, OPC = Off.
Jan 29, 2010 | Sharp Aquos LC-32D40U Television
Sharp AQUOS 65" LCD, No Picture Menu Access
change picture mode from (STANDARD)or other modes and put tv in CUSTOM then you will be able to change the contrast
make sure all cables are in
Dec 15, 2009 | Sharp Aquos LC65E77UM 65 in. LCD HDTV
Scratched sharp 46 inch lcd screen can it be replaced
The lcd screen is the most expensive component of the lcd screen/tv/monitor.
It makes no sense to try and replace it as first of all you won`t be able to find the part number required to do that job (e.g. the screens are internally made by sharp // special orders are placed to companies that only start the process for orders greater than tens of thousands of items) and secondly after a lcd panel has been replaced / installed you need to configure the colors, luminosity, contrast, balance etc through a data cable.
I am really sorry for your sharp lcd screen.
Nov 30, 2009 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
What are the best video settings for a Hitachi (46GX01B), 46 inch, rear Projection TV (from 2001) in regard to: contrast,brightness, color, tint, sharpness, etc. The setting level goes from 1% to 100%....
The best setting are the ones you prefer the most.In general most sets are optimized for 50% on color and tint and usually 70% or more for bright and contrast.
Nov 08, 2009 | Hitachi 46GX01B 46" Rear Projection...
Yellow tint no color red.
you can adjust in color mode. please balance the tint, color,brightness, contrast, & sharpness.
Aug 30, 2009 | Sharp Aquos LC-46D62U 46 in. LCD HDTV
What are the best picture settings for the 52" Sharp Aquos LCD
I'm happy with:
backlight +16
contrast +40
brightness +1
colour -13
tint 0
shaprness +2
although I found this setup but haven't tried it yet
backlight +5
contrast +24
brightness -7
colour +50 (review I found didn't say + or -. Try both
tint 0
sharpness -5
Nov 30, 2008 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
What is the best setting (as in brightness and contrast) for gaming on a Sharp - 32" Class 720p Flat-Panel LCD HDTV ???
-Picture menu
Mode: Movie
Backlight: 1
Contrast: 93
Brightness: 54
Sharpness: 0
Color: 45
Tint: 50/50
Nov 28, 2008 | Samsung LE32R41BD 32 in. HD-Ready LCD...
Picture settings
Colorimetre HCFR software
AVC HD 709 calibration disk
Spyder2 colorimeter (I know most prefer the Eye-One meters, but the Spyder2 was available from my job at no cost)
Here are the settings:
PS3 Blu-Ray player
Output Format (HDMI): Y Pb/Cb Pr/Cr (important!!! NOT RGB output)
BD 1080p 24hz Output (HDMI): On (this TV can reproduce video at 48hz for accurate 2:2 pulldown)
Y Pb/Cb Pr/Cr Super White (HDMI): On (not sure if this matters)
42LG50 Settings
Aspect Ratio: Set By Program (Personal Preference)
Picture Mode: Expert 1
Backlight: 50 (Personal Preference)
Contrast: 54
Brightness: 54
Sharpness: 40 (Personal Preference)
Color: 50
Tint: 0
Fresh Contrast: Off
Noise Reduction: Off
Gamma: Medium
Black Level: Low
Real Cinema: On
White Balance: Warm
Method: 10 Point IRE
10 (-3,8,-16)
20 (15,24,-21)
30 (20,36,-22)
40 (3,19,-40)
50 (8,34,-41)
60 (10,50,-20)
70 (-5,50,-8)
80 (-16,50,18
90 (-14,50,30)
100 (-22,38,21)
Red Color: -3
Red Tint: 0
Green Color: 10
Green Tint: 0
Blue Color: 14
Blue Tint: 0
Yellow Color: 0
Yellow Tint: 1
Cyan Color: -11
Cyan Tint: 0
Magenta Color: 0
Magenta Tint: -2
Take time to get used to the settings, you may think the screen looks dull at first. The truth is most people have way too much contrast on their TVs.
These settings will also work for Cable or Dish hookups, in which case you may change the Noise Reduction option to Medium to reduce signal noise.
Backlight: 65
Contrast: 55
Brightness: 45
Sharpness: 50
Color: 45
Tint: 0
Fresh Contrast: Off
Gamma: Medium
Black Level: Low
Real Cinema: On
White Balance: Warm
Method: 2 Point
Red Color: 3
Red Tint: 0
Green Color: 9
Green Tint: 2
Blue Color: -1
Blue Tint: 0
Yellow Color: 6
Yellow Tint: 5
Cyan Color: -1
Cyan Tint: 1
Magenta Color: 2
Magenta Tint: -1
Sep 15, 2008 | LG 42LG50 42 in. LCD HDTV
Sharp Aquos LC-42D62U 42 in. LCD HDTV Logo
579 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
