Question about Vivitar 285HV Flash
No 'green' light on bacl of my 'old' Vivitar 285
My Vivitar 285 Thyristor with new batteries whines while re-charging (I believe that noise is normal). However, only the Red light glows. The Green does not come on. Now, it used to go back and forth between Red and Green and have a 'chirp' when the flash was ready (I assumed it was fully charged). Now, it still 'chirps', but only the Red light glows. I set the flash to M for manual and hit the test button -- it flashes. I set the flash on 'Yellow' and then aimed the flash unit at the wall -- hit the test button and it flashes and the Green light (not the charging Green light) came on saying there was enough light. So, is the Flash completely charged and the Green charg light burned out or is there another problem?
  • OldOne1 Jan 28, 2008
    When left to 'charge' for a lenght of time, the red light blinks while the unit ischirping - just no green light.
  • hobbified May 11, 2010
    If you let it charge for a good while, and it "chirps", does the red light stay on steady, or does it flash?
    Problem Solver:
  • 8 Answers
Then I'd say it's a reasonably sure thing that the green light is just burned out, The lights are supposed to be off at first, then red when there's a partial charge, then green when there's a full charge, then flashing between red and green when the "battery saver" kicks in. If you're seeing off, then red, then off, then flashing red, then that means everything in the charging circuit is working perfectly, there's just no green light.
Posted on Jan 29, 2008
My vivitar auto thyristor 550 FD wont turn on
If the corrosion was from alkaline batteries you may use a damp cloth. But before you do that, try using a wooden pencil with a red rubber eraser. This is likely to remove the corrosion without risk of introducing water inside the flash.
Jan 30, 2014 | Vivitar Cameras
How to use vivitar zoom thyristor 285 with nikon D80 digital camera
DO NOT ATTEMPT TO USE THIS FLASH ON THE CAMERA OR TEHTER BY WIRE. THe voltage will destroy at least the built-in flash function of your camera. either use a radio slave, an optical slave or you can use it on camera if you use a WEIN safe-synch (approx. $70 USD). If you do not have the users guide for the flash, it can be GOOGLED. Search for "VIVITAR 285 users guide"
Dec 14, 2010 | Nikon Cameras
What is the diff between a vivitar 285 and a vivitar 285hv?
285 has high trigger voltage(+250v) ,where as 285 HV has less than 5.5 volts trigger voltage (which is safe to be used for any digital SLR2_bing.gif). 285 HV has a Thyristor circuitory.
Mar 31, 2010 | Cameras
285, red/green lights blink, whines on start up, but won't fire
Hi Dave,
Try shorting out Center Pin to Outside Metal Contact after the light turned green. This must fire the flash.
If not, could be the flashtube /or trigger are defective.
Do you have a DVM?
atdlee@netzero.com
Feb 14, 2010 | Vivitar 285HV Flash
Vivitar 285 not working
You don't need a Manual.
In 285 HV there is only one Power on/off switch.
If that switch is on and batteries are new Alkaline (like duracell-no chepo )or fully charged and working rechargebles,and yet the ready light do not come the flash has defect inside.For sure.
Jul 27, 2009 | Vivitar 285HV Flash
Need a Vivitary Thyristor 285 Flash Owner's Manual
Well give me a few days to look in my endless piles of stuff and I might have one I can scan for you.
epace@juno.com
Apr 21, 2009 | Vivitar Cameras
How do I know if Vivitar 285 fryed my camera
camera sync terminal wont work with even canon recommended flash.This can be the way to test your camera got damage.
Apr 14, 2009 | Canon EOS 450D Digital Camera
Vivitar 283 charges but fails to flash
I had the same problem with my early Vivitar 283 flash.  I discovered that the thyristor on the trigger board tested as an open circuit.
Trying to find a replacement for a 30 year old thyristor semi-conductor proved to be fruitless.
My solution was to purchase a broken, late model Japanese 283 flash off of ebay and transfer the trigger board to my early Japanese model. The late model thyristors could handle more heat.
Problem solved.
Mar 15, 2007 | Vivitar 283 Flash
Vivitar 285HV Flash Logo
1,422 people viewed this question
Top Vivitar Cameras Experts
Steve
Are you a Vivitar Camera Expert? Answer questions, earn points and help others
