1) Remove the platter - just lift up 2) Underneath the platter, you'll see a small lip section 3) Wrap the belt around this lip 4) Put platter back on turntable 5) Rotate platter until you see the motor shaft through the holes on the platter - a brass round looking piece 6) Pinch the belt around the motor shaft. 7) That's it.
1. My deck turns on automatically to spin once the power cable is plugged in. 2. My arm won't lift...
(More)
1. My deck turns on automatically to spin once the power cable is plugged in. 2. My arm won't lift to on to the record but returms to the start point.
I just purchased the turn table and I did not make sure drive belt was looped around the motor...
(More)
I just purchased the turn table and I did not make sure drive belt was looped around the motor pulley completely and I can not get it to rotate
I have the 33rpm setting on for long playing records, and the turntable runs consistently a little...
(More)
I have the 33rpm setting on for long playing records, and the turntable runs consistently a little too fast. I replaced the belt and it still happens.Any ideas?
The speed for the 33 setting spins too fast, and the speed for the 45 setting spins too fast for...
(More)
The speed for the 33 setting spins too fast, and the speed for the 45 setting spins too fast for that selection. Is there a solution? Thanks, Skye
