Question about Optoma H30 Multimedia Projector
Size of Projection
I have an Optoma projector for a rear view screen which is in my office window. In order to line up the projector with the screen and not have it in the way of staff or customers we have had to mount it around 15' or so from the screen and just cannot get the size to reduce to the size of the screen which is 50".... Can anyone tell me how to do this? ..... or not, as the case maybe. I wondered if the distance was the problem?
Thanks for any help and advice anyone can offer.
  • 563 Answers
Hi Jez
Distance is definitelly your problem here - the lens can only reduce so much. You will have to move the unit.
Posted on Apr 02, 2008
My projector is projecting upside down and backwards
That is because it is set up for rear projection.
Enter the menu and select which ever view you require.
Mar 29, 2011 | Optoma EP721 Projector
My tv a Optoma RD65 made a popping noise, then the screen whent black.
most likely a faulty power cord not sending enough power to the TV or the projectors, for projections, bulbs for plasma, burnt out
Mar 01, 2011 | Optoma RD65 65" Rear Projection HDTV
I have a Optoma EP721. It now projects verticle lines on the screen background. How do you eliminate the verticle lines ?
It sounds like you have a projector which is in need of professional repair. You should eliminate source material problems first though by checking the projector with alternative input sources, ensuring that you also check the cables, and various inputs on the projector.
If the lines are present on all the inputs then the fault is internal to the projector. This will require professional repair. The first point of contact should be Optoma at (UK) or (USA). They should be able to give you an idea of ow much it may potentially cost to have your projector repaired and (most importantly) check whether it is under warranty. Most Optoma projectors ship with 3 year warranties these days.
Feb 19, 2011 | Optoma EP721 Projector
I use OPTOMA ex 532 with windows 7 32 os the projector working properly but in pc screen not displayed the projection screen
You have three option to view projection screen on your PC SCREEN:
1. Use "Y" cable to connect the projector and pc screen at a time.
2. Use "Video Splitter" to connect projector and pc screen at a time.
3. you can use a VGA cable to connect your pc screen with your projector VGA OUTPUT. here I show you the pictures.good_help_4.jpggood_help_5.jpggood_help_6.jpg
Jan 20, 2011 | Office Equipment & Supplies
I have an OPTOMA H27 projector, I am experiencing problems with the quality of the video images displayed. I set the focus by using the internal menu as an image reference. However when I view DVD/Video...
if u are using the composite video the try component video. composite video will dive u a dull image than component one. also check the distance between the projector an screen.Make sure the projection screen is between the required distance 4.9 to 40.7 feet (1.5 to 12.5 meters) from the projector.
Dec 30, 2010 | Optoma H27 DLP Multimedia Projector
Optoma RD-50 DLP has dark vertical shadow on right side of screen
turning off the main can be very harmful to rear projectors if you dont wait for the cooling off period, for instance when you turn off the tv from the remote, the fans inside are still on in order to dissipate the heat given out by the lamp. as a result some of the lens inside the engine may have burns-in caused by excess of heat.thus leading to shadows on the screen.
hope this helps
please rate me!
Mar 19, 2009 | Optoma RD50 50" Rear Projection HDTV-Ready...
Ep716 has vertical line
Jul 23, 2008 | Optoma EP716 Multimedia Projector
Help me please Optoma HD72 DLP
In the menu you can change the phase of the signal or the tracking. In Menu - Setup
Jul 05, 2008 | Optoma HD72 Multimedia Projector
Optoma EP721 - reverse image
Go to menu, select Projection and choose your desired projection scheme (Desktop, ceiling mounted, behind the screen, etc.)
Jun 03, 2008 | Toshiba TDP S3 Multimedia Projector
Optoma H30 Multimedia Projector Logo
127 people viewed this question
Top Optoma Office Equipment & Supplies Experts
color wheel light...
Are you an Optoma Office Equipment and Supply Expert? Answer questions, earn points and help others
