Question about Matsonic MS9158E+ Motherboard
Pin layout ms9158e
Need pin layout for ms9158e power pin
  • 2 more comments
  • cltheroux Dec 03, 2007
    There are no markings on the board .Also I need to get a manual
  • Henrik14 Apr 22, 2008
    Need MANUAL for same MB (without + at end of designation) to connect power switch, reset switch etc. On MATSONIC site this MB is NOT listed, so no drivers nor manuals exist too. It cannot be found by simple search, therefore I and others ask for help. Your answer is NOT helpful in THIS case, so try harder, PLEASE?
  • Anonymous May 31, 2008
    THE SAME WITH OTHER PROBLEM POWER SUPPLY SWITC PINS
  • jgastor32 Dec 20, 2008
    i cannot locate the pin layout for power
    Scholar:
  • 68 Answers
I have found on http://members.driverguide.com/driver/detail.php?driverid=181491 there is zipped file with manuals but ONLY members can download and I cannot become member as I dont have credit card nor PayPal account......
So, can anybody get this and then send to rest of us that need this manuals?
Posted on Apr 22, 2008
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 175 Answers
Yap you can see the lay out on the user manual. like PIn 1-3 or 1-2 like that and the mother board will show which one is the 1st pin.
if you dont have a manual then you need to download it from the manufacturer's site of the motherboard in the download or support section.
Posted on Jan 06, 2008
Need wiring diagram for placement of the internal cables in Compaq Presario SR5410F
Top view photo of the motherboard, of an MSI MS-7525 motherboard made FOR HP by MSI, for a Compaq Presario SR5410F Desktop PC,
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01386897&tmp_task=prodinfoCategory&cc=us&dlc=en&lang=en&lc=en&product=3686678
Also scroll down the page, and click on the + sign to the left of -
Motherboard Layout.
A) 24-pin ATX main power cable:
In the photo, look to the right of the Blue ram memory slots.
The Yellowish/Whitish connector to the right of them, with two columns of 12 socket holes, is where the 24-pin ATX main power cable plugs in.
In the Motherboard Layout it is marked by - ATX1
This is a general example of a 24-pin ATX main power cable, and it's respective connector on the motherboard,
http://www.playtool.com/pages/psuconnectors/connectors.html#atxmain24
Note the middle photo, and the Lock on the side of the power cable's connector. The Lock has a hooked end that goes over a Tab, on the motherboard's connector.
The Lock works like a see-saw on a playground. The top is squeezed in, and this brings the hooked end away from the Tab, in order to remove the power cable.
When assured that the power cable is plugged in tightly, and therefore correctly, the hooked end of the Lock will be over the motherboard connector's Tab.
B) 4-pin ATX +12 Volt power cable:
In the center of the motherboard, under the Processor socket, is the Northbridge chip. (Part of the motherboard chipset)
It is under a finned aluminum Heatsink, that resembles a meat tenderizer's head.
Draw an imaginary line up above it, in-between the Processor socket, and the aluminum finned Heatsink, and go straight LEFT.
See the whitish 4-socket hole square connector?
In the Motherboard Layout it is marked by - JPW1
This is where the 4-pin ATX +12 Volt power cable plugs in. It is power for the Processor. Has the same locking setup as the 24-pin ATX main power cable, and it's motherboard connector.
http://www.playtool.com/pages/psuconnectors/connectors.html#atx12v4
C) In the Motherboard Layout to the top left corner of ram memory Slot 1, (DIMM1), is where the Processor fan connects.
CPU_FAN1
D) In the Motherboard Layout just below JPW1 is where the computer case fan plugs into. SYS_FAN1
E) In the Motherboard Layout - SATA1 - is where the SATA Harddrive data cable plugs into. (Below ram memory slots)
http://en.wikipedia.org/wiki/File:SATA_ports.jpg
The SATA power cable from the power supply, plugs into the SATA harddrive. Note that the SATA power cable's connector, is longer in length than the SATA data cable's connector.
[SATA power cable has 15-pin. SATA data cable has 7-pins ]
Note that both cable's connectors, have an L-shape on the inside.
http://www.playtool.com/pages/psuconnectors/connectors.html#sata
NOTE*
This is what a 4-pin standard Peripheral power cable looks like,
http://www.playtool.com/pages/psuconnectors/connectors.html#peripheral
IF, your SATA harddrive has a provision for a SATA power cable, AND a 4-pin standard Peripheral power cable, ONLY use just the SATA power cable!
Otherwise you will burn up the SATA harddrive. May not happen right away, but I assure you it will happen!
[ A note on SATA.
The beauty of SATA, is that you can plug into ANY SATA connector on the motherboard, and BIOS will see it.
If you plug the Harddrive into SATA 1, or SATA 2, or SATA 3, or SATA 4, connector on the motherboard, IT DOES NOT MATTER.
BIOS will find the Harddrive, or optical drive ]
The Front of your computer is the Front Panel.
The area of contact pins on the motherboard, that the main wires from the Front Panel go to, is the Front Panel header.
In the Motherboard Layout illustration, the Front Panel header is down at the Bottom/Right corner, and is marked - JFP1.
(Right in the very bottom/right corner is JUSB2. JFP1 is right above it)
JFP1. Junction Front Panel 1.
9-pin header. Black rectangle.
5 pins on the Right side, 4 pins on the Left side.
The pins are numbered EVEN on the LEFT side.
Starting on the BOTTOM going UP;
Pins 2, 4, 6, and 8. There is NO Pin 10.
The pins are numbered ODD on the RIGHT side.
Pins 1, 3, 5, 7, and 9.
A) Pins 1 and 3 are for the HarDDrive activity LED.
(Light Emitting Diode, so it is a light )
Pin 1 is for the Positive ( + ) wire. If the HDD LED is dim when the harddrive is active, switch the wires around.
B) Pins 5 and 7 are for a Reset switch, IF a Reset switch is used.
C) Pin 9 is N/C. Not Connected. 5 Volt power, and reserved for the factory to use.
D) Pins 2 and 4 are for the Power On LED.
Pin 2 is for the Positive ( + ) wire.
If the PWR ON LED is dim when the computer is on, switch the wires around.
E) Pins 6 and 8 are for the Power On switch.
For additional questions please post in a Comment.
Regards,
joecoolvette
Aug 14, 2012 | HP COMPAQ Presario SR5410F Pentium...
I need to know if the Intel Desktop Board D865GBF/D865GLC on the main power connector, in the pin 18 have -5vdc or NC.
Here is the pin-out for the power connector:
These connections are common for all the motherboards, so there is no reason for looking for intel motherboard's layout. If the power connector has 24 pins (the new motherbords) the 18th pin is "com", id the connector has 20 pins (the old motherboards) the 18th pin is "nc". The Intel D865GBF motherboard has a power connector for 20 pins and a separate one 20 pin connector, here is the layout:
In case you'd like to have the motherboard's product guide here is an official link for you to download it.
In case of a problem or clarification or further details needed, don't hesitate to post me a reply before rejecting my answer.
If you are satisfied, rate my solution with the "thumbs" or (even better) add a testimonial.
Thanks and regards
Please kindly rate this solution
Stelios
direct fixya link: http://www.fixya.com/users/technical114
Mar 19, 2011 | Intel D865GBF Motherboard
Power source for ecm and destination of efi fuse for ford mondeo 2.0 16v mk 1 zetec south african make and a pin layout of ecm
Hello! The ZETEC engine was used in the 1999 Ford Escort...I do not know what year your vehicle is, however the pin layouts are the same...
The Fuel Injector Fuse (30A) feeds the injectors via normally open contacts of the PCM Power Relay on a Red/White wire (which becomes Red at the injectors) on pin #12 of the Constant Control Module...
The wire colors of injector control leads (at the injectors) are..#3=Brown/Yellow...#1=Tan...#4=Brown/Light Blue...And #2=White
Wire colors at the PCM plug are...#3=Brown/White (pin 74)...#1=Yellow (pin 75...#4=Green/Orange (pin100)...and #2=Violet/Yellow (pin 103)...
Size restrictions on attachments do not allow me to send the entire PCM...aka...ECM pin layout to you...
Guru.............saailer
I’m happy to help further over the phone at https://www.6ya.com/expert/david_6df67de3b14de867
Sep 12, 2010 | Ford Escort Cars & Trucks
Swapped my ma785r board to a new case and need the pin layout for power switch and reset switch
ok i dont hqave it but as i buld a lot of used pcs and new ones its usaly goes like this there is a 9th pin and a tenth one missing next to and in a straght line down the way nest to where the missing pin is is the on of under it is the reset pins next to the reset one is the hdd led and that leaves 1 set of 2 pins left if you want e mail me and ill draw a diagram for you hope this helps
Mar 17, 2010 | Computers & Internet
SP283983 001 pin layout
You need to get the motherboard number and look it up at the manufacturer site under support you should be able to download a tech specs for that board showing the pin layout [owner manual may have it too.
Oct 31, 2009 | Computers & Internet
Dell GX270 SATA front panel 34 pin layout
if you are talking about connecting the front chassis connectors to your motherboard then you need to find out the exact model of the MB... im assuming its Intel since its a Dell.
the link below should get you started
http://www.intel.com/support/product.htm
Jun 01, 2009 | Dell OptiPlex GX270 PC Desktop
Power and reset switch and hdd led layout on P4Vmm2 mother board
[10][ 9] Pin 1 = +HDD pin 3 = -HDD LED
[ 8][ 7] Pin 2 = + POWER pin 4 = - power LED (SPD)
[ 6][ 5] Pins 5 & 7 = reset
[ 4][ 3] Pins 6 & 8 = Power switch
[ 2][ 1]
Hope you find this Useful
Dave
Nov 19, 2008 | EliteGroup P4VMM2 Motherboard
Matsonic audio drivers
i have pc with a matsonic-ms9158ep+motherboard i need sound driver
Oct 09, 2008 | Matsonic MS9158E+ Motherboard
Front panel pin layout. I need the front panel pin layout especially for the HD IDE active LED.
Howzit
Trial n Error is your best bet on the control pins panel there are two rows, with the power plugged in,with a screwdriver touch adjacent two pins together at a time starting with the top row then the bottom row, when you touch the right two pins your motherboard will power-up, then place the power-switch plug onto those two pins (the writing on the plug facing innwards toward the mainboard) the two pins for the reset switch and 99.9% of the time located directly next to the power switch or directly above the the power pins on the other row. For the LED lights you will have to just try the different pins and the Power LED will remain on as long as your mboard is on, but to find the LED pins for the Harddrive you will have to plug in your HDD and then when it powers up try the pins and the led for the HDD will flicker on-off, that would be the correct one. Dont worry your mboard will not be damaged by this in any way. Goodluck and let me know how you go. Thanks
Regards
Oct 27, 2007 | Iwill VD133Pro Motherboard
Matsonic MS9158E+ Motherboard Logo
464 people viewed this question
Top Matsonic Computers & Internet Experts
David
David
Computer Links
Are you a Matsonic Computer and Internet Expert? Answer questions, earn points and help others
