Question about Bosch WFMC6401UC
Water Level Is there a way to modify the water level of the Bosch Nexxt 700 WFMC6401UC?
I find that if I use the delicate cycle it uses more water. If I want more water than that I turn it off and back on a couple of times. Then you can change it to whatever setting you want.
Posted on Jan 03, 2008
Can i stack the nexxt 700 series machines?
Hey there, welcome to Fixya! The above answers were pretty helpful, did you fix your problem with them? Did you check the manual for further instructions? You can find a PDF copy here: Bosch Classixx 5 Manual
Jul 10, 2014 | Bosch Nexxt 700 Series WFMC6401UC Front...
I have a Bosch Nexxt 700 Series Washing Machine. We have been emptying our washer by shop vac for a couple months now. Nothing in the pump. Once through the wash cycle it will try to drain and then flash...
Is the pump pumping? Have you cleaned all the drain lines including the discharge hose? You may have nothing in the pump but it could be blocked somewhere else.
Apr 24, 2014 | Bosch Nexxt 700 Series WFMC6401UC Front...
Bosch Nexxt 700 Series Washer, water from cold supply does not dispense into detergent tray
Make sure that the cold supply is on and/or the supply hose is not crimped or clogged. Other than that it can be a control panel issue in the unit itself. But first eliminate the basic things.
Mar 25, 2014 | Bosch Nexxt 700 Series WFMC6401UC Front...
Why is there water (up past the fill line) in the fabric softener dispenser when the wash cycle is complete? I have become accustomed to emptying it prior to each new load? i typically run the load on...
Bosch Nexxt 700 Series WFMC6401UC Front Load Washer
This video will show you how to keep your soap draw clear and how to service the parts
Please remember to subscribe to our YouTube channel for all appliance tutorials
a 4 THUMBS rating is appreciated for answering your FREE question..
Mar 30, 2010 | Bosch Nexxt 700 Series WFMC6401UC Front...
Bosch washing machine not drawing water
you probably have the "burst free" hoses, this machine draws water too fast so the hoses think they burst, change the hoses to the original or get new ones that aren't burst free and this should solve your problem
Apr 29, 2009 | Bosch Nexxt 700 Series WFMC6401UC Front...
Can't get the cabinet back on the base of a sears series 70 washe
What I do is open the lid. I grab the case and look down inside making sure I get the case under the base and on the tabs. Then I tip the case back and make sure I don't pinch the water level fill switch tubing. The back of the washer has plastic spacers on it that allow for a snug fit to the cabinet. The sides fit neatly into those clips with a bit of patience. If you have the front of the base on then the rest is a piece of cake. Snap down the S-clips and reconnect the lidswitch.
Jan 12, 2009 | Bosch Nexxt 700 Series WFMC6401UC Front...
Not draining
Clean out the lint draw and then run vinegar through a cycle.
If this doen't work try CLR. or/and put the drain hose to the lowest level and then put a flexible clear tube down to unblock it.
Use less detergent in the machine. I make my own detergent and I don't have any problems as one of the ingredients in it help keep all lines clear.
If that doesn't solve the problem contact Bosch directly.
Jan 08, 2008 | Bosch Nexxt 700 Series WFMC6401UC Front...
Bosch WFMC6401UC Logo
97 people viewed this question
Top Bosch Washing Machines Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
