Question about Gateway Wireless-B PC (wbm-120)
Gateway pc, windows vistsa, cant connect to router
I have a new gateway pc
it can see my wireless router but can not make a connection
it will not accept the encryption key when I type it in
..so i can not establish a connection to the internet
  • carpenter1 Jun 23, 2008
    Im picking up plenty of wireless signals,but my laptop say "wireless adapter is not working"No internet!
    Problem Solver:
  • 16 Answers
Try using 'Network Magic' free download from their site. I find that this product makes connecting easy. You do not need to purchase the PRO version, the free will work fine for connecting.
If that does not work, log into your router using a wired pc and check if MAC addressing is enabled, if it is you will need to update the table with your new laptop's MAC.
If not, disable security and test to see if you can connect, if you still can not then you may have a issue with the pc. If you can, then check to ensure that the encryption you are using is supported by the PC's wireless card.
Turn reset the password on the router, re-enable security and try again.
Posted on Dec 07, 2007
SOURCE:
I just got a new router and can not connect it to my linksys wireless card on muy laptop
Does anything else work with the new router? What are the wireless card and the router? What set up did you use for the router address and how did you find it? If nothing else works with the new router, then it is fairly safe to assume that the new router is not set up correctly or is not functioning. The usual problem is to get the addresses that the LAN is using to match up. The default address on the router should match the gateway address in the first three sets of numbers out of the four sets 192.168.1.1 is a typical address. If the address of the gateway is 10.0.0.1 they will not see each other until someone tells them to look in that group of addresses. The router is talking to 192.168.1.x addresses while the gateway is providing 10.0.0.x addresses. So one or the other has to change or the managing PC must tell the LAN to look for both. The easiest is to set the router up so that it is in the same range as the gateway so they see each other. To do that you need the address of the gateway. You might have to contact your service provider to find out what it is. If you have Windows 7 and can connect the PC to the LAN using an Ethernet cable, do so. If you can connect to the internet, click on Control Panel, then 'View Network status and tasks' under 'Network and Internet'. When the window comes up, click on 'Full Network Map' on the right side. The resulting map window will display the address of each part if you hover the mouse pointer over the icon. Look for an address like IPv4 Address: xxx.xxx.xxx.xxx in the icon that the internet world connects to. This is the gateway address. Whatever the gateway address is, the router needs to be similar in the first three sets of numbers and the last set must be different. (There is another way, but this is the easiest to describe.) Now connect an Ethernet cable from the router to a PC. Open your browser and type the address of the router into the browser like 192.168.1.1 on the address bar, a window will appear and ask for a user name and password. Use the default user name and password for the router. So if the gateway is 10.0.0.1, set the router's address to 10.0.0.191 or to some other number less than 255 in the last set. Then, change whatever else needs to be set up, Save and exit. It should now have access to the internet over the router. If you need to go back into the router again, the new address 10.0.0.191 will have to be used instead of the default and the new password if you changed it, so write all of this stuff down.
Feb 08, 2011 | Computers & Internet
I want to use my d-link router with my new acer laptop but cant connect to the router. Windows says it is a router connection problem. It can locate the router just wont allow me to connect.
1.In Control Panel, click Network and Internet Connections, and then click Network Connections.
2.Right-click the Wireless Network Connection, and then click Properties.
3.On the Wireless Networks tab click Add.
4.In the Wireless network properties dialog box, enter the SSID "(Name of the connection) ex. dlink1234" you configured for your wireless gateway
5.Fill in the rest of the fields, including the necessary authentication and encryption information based on the configuration of your wireless gateway. (WPA-TSK, WPA2-TSK, WPA-AES and WPA2-AES)
6.Click OK and your home network will be added to the list of preferred networks.
if you have a firewall in your laptop try to disable it. example Eset Security antivirus Firewall. Disable the Firewall.
Aug 25, 2010 | D-Link (DI-784) Wireless Router
I cant find my wpa
Is your PC or Laptop is connected Wireless to Router, Follow this link
http://www.fixya.com/support/r5198336-details_router_or_network
If your PC is wired connected to the Router, try this
Click on START button
Click on Run ( you will find small window to enter command )
Type CMD ( or COMMAND ) and click OK button
( you will see black window on screen )
Type the command where the Cursor is blinking
IPCONFIG ( hit enter key )
From the list find DEFAULT GATEWAY
Default Gateway is IP address of Router
Open Internet Explorer
Enter the No. you find for Default gateway in the address bar ( without www or .com, just the no. ) - Click Go
You will find the Router page open
Incase if it ask you for username and password - type Username = Admin and Password = Password
Under Wireless settings / Advanced Wireless setting - you will find the WEP/WPA Key
Jul 06, 2010 | NetGear WNR2000 Wireless Router
Cant find my WEP for 2wire331
If your PC/laptop is wireless to Router - try this
OR
If your PC is wired connected to Router, try this
Incase if it ask you for username and password - type Username = Admin and Password = Password ( or the username and password which you have set )
Under Wireless settings / Advanced Wireless setting - you will find the WEP Key
Jul 01, 2010 | 2wire (1000-000005-002) 802.11g/b Wireless...
Cant get to my linksys home page
Is there any computer connected to the router ?
If not then connect the computer to the router.
Check the IP address and the default gateway number.
Default gateway number is the IP address of the router. You will need to use this number to open the router set up page.
Open the Internet explorere. type the default gateway number in the address bar. Do ot type www. or http:// , just type the defaul gateway number and hit ENTER on the keyboard.
if that doesn't work then on WINDOWS computer click START. Go to RUN. in the RUN box type http://192.168.1.1 ( suppose the Default gateway is 192.168.1.1 ) and click OK.
Click here for more information about routers and network
Jan 30, 2010 | Linksys WRT160N Wireless Router
Connection
Connect your broadband router to the netgear router, set your netgear router as "gateway" and put netgear's IP address as your DNS Server and Gateway in your laptop wifi connection.
Mar 21, 2009 | NetGear WGR614 54Mbps Wireless Router...
Modem and wireless not talking
If u r inside a wireless network and internet is ok, u will able to ping both the wireless router gateway and modem gateway. If u cant ping the modem gateway, u can try connect the modem directly to your pc, and test again. U need to make sure the modem is OK, and able to connect to internet. Then only u move to check router. This is due to very often internet access having problem.
Mar 10, 2009 | D-Link DI 514 Wireless Router (DI-514)
Wireless set up problem - no gateway ip or limited connectivity
Connect using Lan Cable
be sure to enable java on your Browser.
Use ONLY IE: some router refuse other browser.
SET your PC on a static IP address on SAME subnet as your router (but of course different IP).
If subnet concept is NOT clear to just just ask here.
When connected with router (on Lan Cable) check every setting (WPA-PSK) TKIP key, Broadcast / Channel etc.
You can also disable every WLAN protection and restore it later.
Activate WLAN connection WHEN you are STILL connected.
Last but not least: SET your DNS IP address = your gateway IP (router)
Feb 07, 2009 | 2wire Wireless-G 802.11g ADSL Gateway
Router login window
To get to the router's log in make sure that your pc is connected to the router either wired or wirelessly, check the status and take note of the default gateway. Type that default gateway on the address bar of your browser. You will then get the log in screen.
Aug 23, 2008 | Linksys Wireless-G WRT54G Router
Laptop wireless connection
Hi .
LImited access no internet service means that Authentication of your wireless network is not up.
You must know what your wireless encryption is and you can check your manual/guide for your router or gateway on how to access it.If you dont have it anymore than you can access your router by using your desktop computer w/c im sure is hardwired to your router.
By using your desktop we need to look for you default gateway by ff the steps below.
For win xp:
Start > run > cmd .... on the Dos window type in ipconfig /all
it'l then show your default gateway . It would look like this .192.168.xxxx
If you have your default gateway , w/c is your routers physical address Open your favorite browser and on the address bar type in your default gateway.It would route you to your routers page. Most routers ask for your username and password.When youre able to access your router you'l have a chance now to view or change your wireless settings.
Hope that helps. Pls let us know if you have further questions or clarifications.
Good Luck .
Cheers.
Jun 14, 2008 | Computers & Internet
Gateway Wireless-B PC (wbm-120) Logo
105 people viewed this question
Top Gateway Tools & Hardware - Others Experts
Marvin
Marvin
john h
Are you a Gateway Tool and Hardware - Other Expert? Answer questions, earn points and help others
