Question about Kenwood Car Audio & Video
Kenwood kvt-617dvd in the kenwood kvt-617dve it says in the manual something about hooking up a thirty party gps i have a magellan how do u do it?
No enciende mi dvd kenwood kvt-617
Posted on Mar 16, 2010
Yellow cord cut on the Kenwood KVT-617DVD
the yellow wire is supposed to go to a constant power source. the radio will not work without it being connected.
Oct 12, 2009 | Kenwood KVT-617DVD Car DVD Player
Kenwood KVT-617DVD - Rear Camera Option Not Working
Since "...everything else is working..." indicates that there is no blown fuse or chances are nor any hardware is at fault.
When the battery was disconnected, the Kenwood KVT-617DVD may have suffered a memory failure and would require a reset.
Have you tried doing a reset? It's a small recessed button near the bottom right side of the font panel underneath the protection panel (right of the Joystick Track/Station Key & above the Eject Disc Key). Pressing the reset button should restore the Kenwood KVT-617DVD to default factory settings. Of course this will also remove any special programming that you may have such as favorite stations, etc.
You also posted "...Parking brake requirement...bypassed..." this is only to allow the display to be always ON. This is the green wire that must be grounded
You need also to check that the "Reverse" wire/trigger is also bypassed that is to set the "...camera...full time...rear view mirror and back-up monitor for the truck camper..." This is the pink wire that must be attached to the ACC of the vehicle's Ignition Switch. Alternately, it may be connected to the red wire of the Kenwood KVT-617DVD.
If the reset does not correct the problem, you may need to run the setup menu again following the user's manual. Should you need a copy, it is available on line here. Pls verify that you set R-Cam Interruption to ON & R-Cam Mirror to Reverse. This is better explained with appropriate illustrations in page 69 of the User's Manual.
Hope that this be of some help/idea. Pls post back how things turned out or should you need additional information.
Good luck and kind regards.
Dec 10, 2007 | Kenwood KVT-617DVD Car DVD Player
Having trouble with my kvt-617dvd car stereo
after disconnecting battery asking for code and i cant find remote help
Aug 26, 2009 | Kenwood KVT-617DVD Car DVD Player
Does the kenwood kvt 617dvd have a brain bulit in or not
no it dont i have one for this unti not sure if it works thought bought it off ebay with my kvt-715 but they say the hideaway wont work it so i need to find one for my deck and this one as no wire harness either
Jul 10, 2009 | Kenwood KVT-617DVD Car DVD Player
Kenwood KVT-617DVD sound issues
the wireing off the brain is connected wrong, ok look at the wires and now disconnect your remote wire from the amp remote now connect the second blue wire to the remote wire going to the amp, now your sound should be right
Jan 21, 2008 | Kenwood KVT-617DVD Car DVD Player
Kenwood KVT-617DVD
hi kenwood go's off when i put it on to dvd
Jan 16, 2008 | Kenwood KVT-617DVD Car DVD Player
Kenwood kvt-617dvd
tie the green parking brake switch wire to ground
Nov 30, 2007 | Kenwood KVT-617DVD Car DVD Player
BYpass kenwood kvt-617dvd
Ground the Green "Brake" wire to your frame. This will fool the system into thinking that your brake is engaged.
Oct 12, 2007 | Kenwood KVT-617DVD Car DVD Player
Car Audio & Video Logo
188 people viewed this question
Top Kenwood Car Audio & Video Experts
xxxxxx xxx
Marvin
Marvin
Are you a Kenwood Car Audio and Video Expert? Answer questions, earn points and help others
