Question about Motorola Mobility RAZR V3m Cellular Phone
Motorola v3m cell phone
How Do i Remove the keypad so that i can replace it with a different one?
    Brigadier General:
  • 7,752 Answers
It is best that you have a professional mobile tech ....replace the keypad for you.
Posted on Jan 03, 2008
2 Suggested Answers
SOURCE:
krislil127
  • 55 Answers
SOURCE: Unlock my motorola razr V3m cell phone
try all the defaults the last four digits of the phone number last programmed to the phone then standards defaults for all phones are 9999,1234,4321,0000,1111 if none are successful you will have to hook the phone to a charging station which is at the verizon wireless store I do believe they still have the software if they dont they will need to replace the phone either by upgrade to a verizon phone (two year contract) or activating an old phone you own or bought online elsewhere or got from a friend etc. or insuarnce claim which is fifty bucks and they give you the same model i have to say of all the razors thats the good one so if you do go with insuarnace i wouldnt accept anything else they might throw at you as comparible its not
Posted on Jun 05, 2010
2007 razr v3m can make calls but display screen
problem the solved.What makes the screen of a phone white is when the screen of the phone is damaged or the flex of the phone has cut.
The flex of the phone is attached to the keypad of the phone. They are joint together.
The flex of the phone can get weak due to opening and closing the phone all the time.It might be the flex is weak and it needs to be replaced.
If when replaced and still no display, then it's definitely going to be the screen of the phone that will need to be replaced.
Would advice to prevent more damage on the phone, you can give it to a mobile repairer to check it for you if you can not.
Take care.
Mar 20, 2010 | Motorola Mobility RAZR V3m Cellular Phone
Keypad lights some off
Those bulbs that doesn't light up, i think it is damage. Better replace those bulbs with new one by asking professional help with a qualified cellphone technician.
Oct 15, 2008 | Motorola Mobility RAZR V3m Cellular Phone
Won't power up
Device is bad or needs reset, remove the battery while the device is on and count to 30 then re-apply battery and power on!
Sep 14, 2008 | Motorola Mobility RAZR V3m Cellular Phone
Ph will turn on but keypad won't work
You need to replace your keypad. Frequent use deteriorates the interfacing connections.
Sep 13, 2008 | Motorola Mobility RAZR V3m Cellular Phone
RAZR phone
you should take the phone and have the flexcable replaced or try a keypad flex reflash
Aug 31, 2008 | Motorola Mobility RAZR V3
Unlocking cell phone
check out http://www.hacktherazr.com/ You can enable many of the functions that verizon disabled.
Apr 04, 2008 | Motorola Mobility RAZR V3m Cellular Phone
Motorola V3m keypad problem
open the phone and clean the keypad connector really good
Dec 11, 2007 | Motorola Mobility RAZR V3
Motorola razr v3m keypad problems
Hi Ms. Jackson,
I have seen this happen when the phone is almost full capacity on files. Try clearing up some files by either deleting them or backing them up to PC.
You may also need to hit it with some canned air and isopropyl alcohol to clean the keys up.
Nov 30, 2007 | Motorola Mobility RAZR V3
Razor v3m
go to youtube.com there is a tutorial video there that i found on how to replace the keypad, just search for razr replacing keypad of that sort.
Sep 24, 2007 | Motorola Mobility RAZR V3
Motorola Mobility RAZR V3m Cellular Phone Logo
54 people viewed this question
Top Motorola Mobility Cell Phones Experts
vince
D. E. Hev
Mark Magill
Mark Magill
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
