Question about Garmin StreetPilot C330 GPS Receiver
Which Maps Are Loaded?
Sent my 2 year old C330 back to Garmin to have a dead battery replaced. They opted to send me back a brand new unit. How can I tell if the new unit came loaded with the new 2008 maps, or do I still have to purchase same and load them myself?
  • tayloch3 Apr 05, 2008
    Is v8 the 2008 update?
  • mahi6804 Apr 12, 2008
    address for shipping
    Problem Solver:
  • 4 Answers
From your Where to?/View map screen press on the box wrench to access the settings menu. Once at the settings menu press Map, then press Map Info and you should see that you have City Navigator North America NT v8 or whichever one is loaded.
Posted on Dec 21, 2007
It wont turn on at all
How old is the unit, more than 2 years? has the battery been run dead more very often? If so it may need a new battery, if this is the case it must be sent back to Garmin, the battery is hardwired into the unit and not consumer replaceable.
Dec 27, 2011 | Garmin nuvi 1300 Car GPS Receiver
The internal battery is dead. How do I replace the the old battery with a new one. Please explain how to open the battery compartment and how to install a new lithium-ion battery.
The internal battery, that only Garmin can change. It would cost $125 just to send the unit in if it needed work outside of the warranty period.....hopefully the battery will last about five years.If you get it replaced from Garmin. If still you want to void the warranty and get it opened then there is step by step images shown how to open the unit.But that actually damages the unit. Click this link directly:--- There are total 26 images showing step by step procedure.Click on each image and continue disassembly. http://content.techrepublic.com.com/2346-22_11-178052-6.html?tag=content;leftCol ---------------- Thanks. Keep updated for any more query. You can rate this solution and show your appreciation.
Aug 10, 2010 | Garmin StreetPilot C330 GPS Receiver
My Garmin street pilot C330 was purchased about 2 years ago. Lately, it has begun giving a message, Low battery. I have had to charged it up on my computer 2 times in the last 2 weeks. What is the problem?...
2 years is generally about it for the battery on the C330.
You most likely need a new battery.
Charging it on or off does not matter.
Run it with the back light on a dimmer mode to increase battery life for now.
Sep 06, 2009 | Garmin StreetPilot C330 GPS Receiver
Low Battery after using it
I had the same exact problem about three years ago when mine was new. I sent it back to Garmin and it took some convincing on my part to get them to replace the mount and cable for the car. The first time I sent it back they only wanted the unit back, not the mount. Same problem when i tried the replacement unit. I called service again and told them that I was sure it was in the cable from the cig. lighter socket and that I was going to send the whole system back. They said ok and when I received it back from Garmin the second time I had anew mount and it has been fine since. By woodtick
Mar 08, 2009 | Garmin StreetPilot C330 GPS Receiver
Dead battery on Garmin StreetPilot c330
The silver faceplate snaps off (there is a tab at the top of the screen); remove the silver faceplate, remove the 4 screws to open the unit. The battery is located on the back half, and is conected to the circuit cards with a balck and red wire through a small connector that also as two brown and white wires for the speakers.
Dec 15, 2008 | Garmin StreetPilot C330 GPS Receiver
Dark Screen
The screen uses a CCF like florescent tube and that may be going bad. I don't know if it's replaceable as the screen is one unit with the light built in.
Jul 08, 2008 | Garmin StreetPilot C330 GPS Receiver
New unlock code
Which GPS unit do you have? The C330 does not have PIN code capability. Did you send your unit to Garmin for repair? PIN codes are set by the user, not given by Garmin.
Mar 14, 2008 | Garmin StreetPilot C330 GPS Receiver
Garmin c330 GPS
Hello, I have had 7 Garmin units and 4 of them where streetpilots like yours.
You can try a reset of the unit. This will restore the unit and you might loose any favorites etc that you have stored. Here's how you do a reset.
"With the unit off, place your thumbnail in the groove located under the Garmin logo on the face plate, gently pull off the face place. Press the reset button and turn the unit back on."
Try this and see how the unit works. If it still gives you the same problem then your unit needs repair. I have sent in at least 2 units to Garmin for repair in the last 2 years.
Thanks
Feb 19, 2008 | Garmin StreetPilot C330 GPS Receiver
Old map installed in new unite
I googled garmin c330 software update and went to a garmin site for this same purpose. I had no problem getting a current update (within the last year) and at no charge. There is also a user forum that is very informative. I travel extensively and have used mine for a year now. I wish I had bought it sooner Ray
Dec 18, 2007 | Garmin StreetPilot C330 GPS Receiver
Street pilot
There is a reset button on the unit
Aug 14, 2007 | Garmin StreetPilot C330 GPS Receiver
Garmin StreetPilot C330 GPS Receiver Logo
99 people viewed this question
Top Garmin GPS Experts
Marvin
Marvin
Steve
Will Halftowaite
Are you a Garmin GPS Expert? Answer questions, earn points and help others
