Question about Kenmore 24 in. 17512 Built-in Dishwasher
Wash cycle it takes 2 hours to complete cycle. dishes are very cleal, but it seems 2 hours is a long time.
  • momrules Dec 02, 2007
    thanks for the info, it does seem to be our problem with the water temp. entering the washer. again thanks, catriver
  • rod carmichael Jan 10, 2008
    wash cycle takes forever to complete , dishes are clean after 2 hours. what could be the problem?
    President:
  • 878 Answers
Momrules, it could vary depending on the water entering the dishwasher. On a heavy cycle normal time is about 85 minutes not including thermal holds ( pauses that heat the water). On a normal wash, 68 to 75 minutes not including thermal holds. If the water entering the dishwasher is not at least 120 to 140 degrees the dishwasher will pause in cycles to heat the water before advancing. So 120 minutes is not unrealistic. The heaters in the dishwasher are low wattage and will only heat the water approx. 2 degrees every 5 minutes. Catriver.
Posted on Nov 30, 2007
  • 561 Answers
A lot of modern machines have eco modes, this means they use less energy but take longer to clean. if you need faster cleaning use a non eco mode or do it by hand.
I hope this was useful
Posted on Oct 25, 2011
Gu 120 es
there is a "smartclean" sensor that measures dissolved solids in the water in an attempt to shorten the washing cycle. however if the dishes have much food left on them, then the washer will continue to run untill it gets a "clean" reading, or it reaches the max run time (180 minutes). all energy star dishwasher require the dishes to be throughly rinsed before washing in the machine. trust me, i know how counterproductive this is.
Sep 26, 2013 | Whirlpool Dishwashers
Bosch SHX33A05UC/36 dishwasher seems to run for hours to do a load of dishes. Checked water temperature, drain and hose and all is clean. The rinse and hold cycle times out correctly. Is it a timer or...
No, the problem in not the unit, it is programed to run up to 3-3 1/2 hours for a single cycle. You can select quick wash to shorten this time down, but this is not a problem with the unit. It wants to assure you have clean dishes and hot enough water to complete the program.
In testing one a few days ago, I ran into this same problem, I reread the time charts and cycles and found this to be normal for this manufacture.
I hope this answered your question.
I’m happy to help further over the phone at https://www.6ya.com/expert/gere_bf68e6055dd61249
Aug 13, 2011 | Dishwashers
Machine does not wash an dry dishes some time washes but doesnt dry dishes machine starts up an starts to go through cycle but goes on an on takes ages 2 complete cycle at end of cycle dishes not done
Probably heating element gone, or could be the heating circuit relay on the on board computer.
Not easy DIY jobs unless you are confident.
I found one pin (pin 3) on the relay had blown away, taking with it some of the PCB board, but other have experienced the solder just melting off the pin.
I bought some spare Relays, and rerouted the tracks on the PCB, and it has sort of fixed it - well it heats and seems to be working. The timer is still telling me 73mins instead of 35mins, though the cycle only takes 35mins.
Jan 05, 2011 | Bosch 24 in. SGS45E02 / SGS45E08 Exxcel...
Whirlpool Dishwasher GU3600XTSB 3 - 4 hours to complete washing
Wash time is determined by the cycle you select, the incoming water temperature and the installation location. The new machines will heat the water to a predetermined temperature and it takes roughly 1 minute for each degree of rise, If the incoming water is at 120 deg and the wash cycle wants 165 than it will take 45 minutes just for that one cycle to complete, Factor in an outside wall with poor insulation or lower water temperature and it could take even longer. Eric
Dec 30, 2009 | Whirlpool GU3600XTS Dishwasher
The wash cycle runs and runs.
Most diswashers have a complete cycle that lasts over an hour. The machine fills with about 1.5-2 quarts of water, rinses the dishes for a few minutes, then empties the water, then fills again with new water and rinses for a few more minutes, then empties. This is to get a good bit of the looser gunk off the dishes, and to soften up any other stuff that has dried on there. Then the machine fills a third time, the soap door pops open, and it washes for a much longer time to hopefully dissolve away pretty much anything left on the dishes. Then it empties, and does a rinse the soap off cycle, and usually a final cycle that rinses again with a little bit of rinse agent to help them dry quickly.
The whole process uses about 2 gallons of water.
Sep 14, 2009 | Dishwashers
The dish washer is taking ages to wash and it not clean ing dishes well
ok so If your dishwasher has worked fine in the past but, suddenly, your dishes aren't clean after the dishwasher completes all cycles:
1) Check your water heater's temperature dial to be sure it hasn't been changed recently.
2) Be sure dishes haven't prevented the detergent dispenser from opening properly during the wash cycles or kept the spray arms from turning, the lower arm from rising, or the spray from reaching the upper rack's dishes.
3) During the wash cycle, listen to the spray arm spinning inside. If it seems to be spinning poorly, clean out the spray holes in the spray arm(s) with a stiff piece of wire; wait for the machine to cool, and then remove the spray arm(s) by unscrewing the hub cap and lifting the arm(s) off
Regards Gizokieth
Sep 10, 2009 | Dishwashers
The washing cycle takes 2 hours to complete
Make sure the sani cycle is not selected, or pots and pans, also with the dry cycle most will take about 2 hours, if your dishes are not that dirty use the short cycle. Be sure your water is at least 130 F. Run hot water at faucet before starting the machine.
Feb 27, 2009 | Whirlpool 24 in. GU3200XTP Built-in...
Long washing cycle
sounds like a long time. sounds like it will wear out your dishes before it ever cleans them.
check the manual for cycle times.
could be a bad logic board, too. this happens most often when units are new.
talk to the service center for the unit since its new. they will be able to get right to the problem or send a repairman under warranty.
new units do fail.
good luck
mark
Mar 15, 2007 | Whirlpool GU2400XTP Built-in Dishwasher
Kenmore 24 in. 17512 Built-in Dishwasher Logo
408 people viewed this question
Top Kenmore Dishwashers Experts
vince
D. E. Hev
gbob59
Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
