Question about Toshiba 20HL85 20 in. LCD Television
TV will not turn on
I've been using this television for over a year without a single problem. I moved into a new house this week, plugged in the set, turned it on and nothing. I hit the power button a few times and it did finally come on once so I hooked up the coax to it, hit the power button and nothing. I haven't had any luck power the set on since.
Toshiba Model# 20HL85
  • syscoman11 Jun 08, 2008
    Same problem. For no reason tv just stopped working.
    Sergeant:
    Champion:
  • 318 Answers
Switches have contacts in side them, and when switches are switched on and off arks are made, has time goes bye, contacts break in side the switches. please channge your switch, with a new one.
Posted on Mar 19, 2009
SOURCE:
We had a really bad storm yesterday with a lot of lightning. our power flickerd on and off a couple times but all of our electronics are plugged into surge protectors. everything in our house is working...
Few mins will not resetting tv and recovering power supply board from it protection modes that quick.Tries tv unplug,replug it back like about an hour later for tv resetting it back to the factory setting.The tv should get out it protections modes and might work again.If tv still have the same problems,than enough high currents got in the tv and kill ur tv power supply board.That the board where the power a/c cord plug into it.Tries websites like Shopjimmy.com,Ebay.com to buy a whole new refurbish power supply board for the replacement.
Jun 30, 2011 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
I moved my TV from my old house to my new house. Before it worked just fine at my old house, brought it to my new house and it just doesn't turn on! Tried different outlets, wires, etc.
Check the power at the plug point. Check the plug of the TV. If there is no life, then you will need to open the TV panel and check for a blown fuse, a circuit break while transporting, a loose connector within the set or a possible damaged SMPS>
check this link below for some tips on the power supply:
http://www.fixya.com/support/r5826301-working_switch_mode_power_supplies
Feb 21, 2011 | Sharp Aquos LC-32G4U 32 in. HD-Ready LCD...
I bought a Toshiba 32 Inch HD Ready Digital LCD TV - 32BV500B yesterday from Argos, Leyland. I tried to set it up and it searched for programmes but did not return and any programmes. It had a blue...
Are you using the freeview tuner, I only ask as it looks like your having a similar problem that I had a few months back. I moved into a new house and plugged in the tv. Using the freeview tuner I wasnt able to get any channels. It turned out although the aerial picked up regular analogue tv it wasnt the correct aerial for freeview.
Aug 17, 2010 | Toshiba Televison & Video
Sylvania 6842THG won't turn on. the tv red light displays when you push the power button you hear a click and then 5 - 10 seconds it goes back off
I have been having the same issue. I unplug the TV for 10 minutes and it usually works fine. I moves all of my A/V plugs to a single power strip and that helped a lot. Since then, the TV went into protection mode only once in 2 weeks. Next, I will use a power strip that includes the cable protection.
Dec 12, 2009 | Sylvania 6842PE 42 in. HD-Ready Plasma...
Tv picture crooked towards bottom right.
I have a philips magnavox and had two problems that I recently fixed using kits from www.TvRepairKits.com. I can't say enough about their kits and help. Without them I would have never been able to fix my TV set myself.
The first problem I had was the TV was looking 3D. After doing some homework I found out that this is a convergence problem. I bought a kit, followed the instructions, and to my amazement fixed it myself.
After building my confidence with the 1st repair I decided to get their CRT fluid kit. This kit fixes the dull video,red video, or bright/halo looking video. If you have a magmavox set that is more than 5 years old your tv has this problem already. It happens on every set. As before I bought the kit, followed the instructions, and now my video looks factory new. Once again I wanted to say thanks to the team at Tv Repair Kits for putting together kits that the average joe can use.
ML
Jul 24, 2009 | Philips 60PP9352 60" Rear Projection...
Tv will not turn on with or without remote
The power supply is broken. You need to replace the capacitors that are bulging inside. I did and now it works fine. I don't have any experience but I did it. Follow what this guy did. http://www.fixya.com/support/t1661054-akai_lcd_tv_power_light_stays_red_turn
Jun 14, 2009 | Akai LCT2721AD 27 in. LCD Television
Power on samsung plasma tv
Where did you move from and to?
Mar 07, 2008 | Televison & Video
No picture, but has great sound
Older television have components that are designed to last for about 10 years. slight movements can cause failures in old Capacitors and loosen connections.
Might sound weird but seriously give the thing a good slap on the side after it has warmed up. if there is any effect AT ALL. take it to a repair man. if not your set may have simply bit the dust and now requires more servicing costs then a new set.
Nov 07, 2007 | Sony KV-36FS100 36" TV
TV won't turn on
sounds like the main board has an issue
Jan 18, 2007 | Samsung LTM1775W 17 in. LCD Television
T.V. turns itself off
before any attempt to deep cause of problem, unsolder first all the tack switches in the front panel of tv.then turn on the tv using remote control observe? cuz maybe one of the switches is stock.if not,proceed to eeprom servicing which is u have to look for service mode of ur tv model to unlock it and reset it to factory value.
Sep 12, 2006 | Philips 32RF50S 32" TV
Toshiba 20HL85 20 in. LCD Television Logo
81 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
