Question about Mitsubishi WD-62525 62" Rear Projection HDTV
WD-62725 lamp issue
How do you reset the lamp
  • Kevin Ford Nov 30, 2007
    I changed to lamp, but the lamp light goes to a solid red after about a minute. I can hear the fan, but no picture or sound.
  • tollstation Dec 08, 2007
    I have a Mitsubishi Wd-62525. I just changed the lamp. Everything went well for about 4 hours. Then when I shut the T.V. off, the fan stayed on all night. The following morning I turned it on, only to find that the red light was
    on and there was no picture. There is sound. What is the problem?
Same thing on mine, it will power on and has the red light. If I reset the tv it will power on run for a minute or so then go back to the red light. This is after I changed the light bulb and the and tv worked for 2 days then I got the same thing.
Posted on Dec 13, 2007
    Genius:
  • 1,153 Answers
Do tv not work?
Posted on Nov 30, 2007
Replaced my lamp, when i push power it powers up for a few seconds then shuts off and the red lamp button comes on again.. wd 62725
Thats usually caused by failed capacitors on the Power board. The mitsubishi repair kit called the V26 Chassis DLP DM / Power repair kit will often repair that. Its available from www.tvrepairworld.com and contains the capacitors and the CD with repair instructions.
Nov 05, 2010 | Mitsubishi WD-62725 62" Rear Projection...
WD 62725 timer light continusly flashes green TV won't turn on! Push reset button as soon as you release it ,it starts flashing again. Unplug TV 3-4 Hours No help.
The V26 DM repair kit from www.tvrepairworld.com will usually repair that issue. The kit contains the replacement capacitors and the step by step instructions on CD
Dec 07, 2009 | Mitsubishi WD-62725 62" Rear Projection...
MITSUBISHI WD-62725
Time to replace the lamp, this is a simple process that 98% of tv owners / consumer can do on your own,you do not need a technician to do this, there are simple instructions on how to do this in the owners manual and / or some of the mitsubishi's have instructions right on the back of the tv set where the lamp access door is.Good luck!
Nov 24, 2009 | Mitsubishi WD-62725 62" Rear Projection...
My television is cutting off and takes forever to restart. the green light stays on. I have tried to reset the tv. same ol thing. replaced the lamp its not that. a big blue screen pops up before shutting...
Hello! If you haven't replaced the lamp before, I recommend you do it, since it's already 4 years old. If you already replaced it, there is a possibility you might be having a ballast issue. The ballast is the board in charge of sending all the power to the lamp so it can light up. www.discount-merchant.com/?Click=48427 These part are not that expensive and will get your TV up and running.
Nov 18, 2009 | Mitsubishi WD-62725 62" Rear Projection...
Mitubishi WD 62725 - Ballast Problem??
the capacitors on the power board are the most likely the cause of the problem.
Jun 21, 2009 | Mitsubishi WD-62725 62" Rear Projection...
Lamp Issue with Mitsubishi WD-62725
Hi I am Vortash it sounds as if the actual fault is in your ballast circuit this is the circuit that fires up the arc on the lamp and sends the signal to the main board that the lamp is running , if this is faulty no signal is received by the board and the lamp light comes on when this happens there is usually still sound but not always as sometimes the problem affects the power supply also .. this is a job for a trained engineer as voltages at the ballast are sometimes in excess of 25000 volts at first arc that then settles to a lower voltage to run ... regards Vortash
May 30, 2009 | Mitsubishi WD-62725 62" Rear Projection...
WD 62725 Timer geen light keeps blinking
Here is how you fix the problem. Turn off the power to your TV for 10 seconds, then turn on. Next, take a paperclip and push in the reset button for 10 seconds, then release and wait until the light stops blinking - may take up to 5 minutes - be patient. Then turn on your TV as normal and your problem will be fixed.
May 26, 2009 | Mitsubishi WD-62725 62" Rear Projection...
Mitsubishi WD-62725 constant blinking of green light
Check the lamp to see if it is damaged(this is in your owners manual for removal)If not please contact me for more info
Mar 24, 2008 | Mitsubishi WD-62725 62" Rear Projection...
Mitsubishi WD-62525 62" Rear Projection HDTV Logo
131 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
