Question about Zebra LP 2844 Thermal Printer
Zebra lp 2844 thermal printer
My printer prints bar coded invoices. When I push the print button. It is supposed to print 3 duplicate invoices. Now I will print an invoice, a blank, an invoice then blank etc... What do I do?
thanks,
Perry
  • 57 Answers
It sounds like it needs to be re gapped. Try this:
1. Make sure that printer power is off.
2. Press and hold the feed button.
3. Turn printer power on.
4. When the status light blinks, release
the feed button.
5. The printer advances the media to
measure and verify the length of
individual labels or tags. The printer
then prints a status summary and
remains in diagnostic dump mode.
6. To begin normal operation, tap the
feed button. The printer prints "out of
DUMP" and advances a label.
Posted on Apr 24, 2008
I need to print labels and bar codes without installing the zebra driver.
This printer supports EPL if it is a true 2844 not a 2844-z. If you want to print to it directly from programming you can to it that way.
Jul 29, 2015 | Zebra LP 2844 Thermal Printer
My printer cannot detect the gap between the labels.one bar code is printed on 2 labels.
did you try to calibrate the printer yet? Procedure is the following:
- switch off printer
- switch on again WHILE pushing green button
- release button after first flashing of led
- printer starts calibration process
- after printer finished calibration press green button again once to feed another label and leave dump mode (important!)
- printer prints "out of dump"
Now try to print from your software again. I hope it helps!
Sep 03, 2011 | Zebra LP 2844 Thermal Printer
Zebra lp 2844 prints a blank test page
possible was reset to factory defult and the darkness is to low, press the button until flash 5 times and let run untill see the dark print. then press the buton again. Try to print again (flash 1x)
outher possibility is the ribbon in on other way.
other possibility is the labels need to use ribbon (Thermal Transfer), and the printer is run out from ribbon.(run as Direct Termal.
Aug 17, 2010 | Zebra LP 2844-Z Thermal Label Printer
My ups thermal printer zebra lp 2844 wont print labels properly
press button until flash 7 times to calibrate, turn off, tur on again if pressist, check the setings from the driver, if thei correct. ajust if necessery.
Jul 05, 2010 | Zebra LP 2844 Thermal Printer
Zebra LP 2844 Prints 30 pages of junk instead of a Dazzle mailing
Turn off the printer and place your finger on the green feed button. With the button depressed, turn the printer back on. Let the light flash2.gif (ONLY!) four times and release the button. Printer will cycle through 2-3 labels. Press the feed button one more time.
You've just set the printer back to factory default.
Jul 23, 2009 | Zebra LP 2844 Thermal Printer
Zebra LP2844 thermal printer
open the unit and on the front top you will see a thermal print head, (looks like a shiney bar) using an alcohol based solution clean the head, you prints should be much clearer now.
xbm
Nov 07, 2008 | Zebra LP 2844-Z Thermal Label Printer
Printer won't print
check for paper jam and the ink.
green flashing lights means it try to print but something is holding it back.
Oct 14, 2008 | Zebra LP 2844 Thermal Printer
Zebra LP 2844 prints blanks
If the printer is printing nothing but blanks, try another roll of labels.
If the printer is printing blanks in between labels, it probably needs to be gap sensed. You can do this by:
1. turn the printer off.
2. hold the feed button down and then power the printer back on while still holding the feed button down.
3. release the feed button when the light flashes.
4. the printer will then regap itself
5. when the regapping is done, press the feed button once. It will print on the label that it is 'out of dump'
6. the printer should then be ready to go.
May 03, 2008 | Zebra LP 2844 Thermal Printer
Zebra LP 2844 fuzzy print
1. Clean the print head with cleaning pen.
2. Adjust print speed/darkness in software.
3. Check the media and verify that print surface is facing up.
4. Check that correct thermal media is in use.
Apr 23, 2008 | Zebra LP 2844 Thermal Printer
Zebra LP 2844 Thermal Printer Logo
781 people viewed this question
Top Zebra Office Equipment & Supplies Experts
Dave Busselle
Level 1 Expert
Marvin
Marvin
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Zebra Office Equipment and Supply Expert? Answer questions, earn points and help others
