First thing to check is the position you are wearing it. Ideally, if you imagine your waist as a clock with 12 to the front then the perfect position is on the belt line at between 9 and 11 or 1 and 3.
The reason for this is because the shock of your foot hitting the ground travels most noticeably up the front of the leg and so the pedometer is right in the path of the impact.
It will give you the inconsistent reading if worn on the back or middle front (12 O' Clock).
If it's still reading incorrectly then you could be looking at a fault in the pedometer itself.. Check the position first though...
The engine coolant temperature (ECT) sensor is a variable resistor, that measures the temperature of the engine coolant. The powertrain control module (PCM) supplies 5 volts to the ECT signal circuit and a ground for the ECT low reference circuit. When the ECT is cold, the sensor resistance is high. When the ECT increases, the sensor resistance lowers. With high sensor resistance, the PCM detects a high voltage on the ECT signal circuit. With lower sensor resistance, the PCM detects a lower voltage on the ECT signal circuit. If the PCM detects an excessively low ECT signal voltage, which is a high temperature indication, DTC P1114 sets.
Conditions for Running the DTC
The engine run time is more than 5 seconds.
Conditions for Setting the DTC
The PCM detects an intermittent high ECT sensor temperature while the engine is running, and the run time exceeds 5 seconds.
Action Taken When the DTC Sets
The number below refers to the step number on the diagnostic table.
