Question about Hobart N50 Stand Mixer
Motor is not running now
I am in distraught! I was kneading bread with my mixer when it suddenly stopped turning but the motor was still running. So, I instinctively turned it off. After awhile I turned it on and even the motor was not running. Is this worth going to the repairshop or just dont bother?
I have a Hobart mixer. I too, was kneading bread. I have done this many times before with no problem. This dough turned out to be a bigger load and as the it began to knead I noticed that the mixer was getting in distress. As I was reaching to turn it off it quit and has not run since. I am hoping that it has a reset switch, but haven't found it yet. Any suggestions?
Yes, bigg t, since you work for Hobart, is there any way to get a refurbished one cheaper? If so, email me [email protected]. THANKS!
Posted on Jan 20, 2008
  • 640 Answers
Im a service tech for hobart and repair these mixers often-is it worth repairing the unit?YES it is.I have never seen a motor burn up on these units,i have seen keys sheared and gears broken but thats the extent.There is a overload/reset button that sits on the back of the mixers pedistal,if its tripped when you push it in it will click.when these units need service it is usually from overloading the unit with too much product.Any other questions let me know.
Posted on Nov 30, 2007
SOURCE:
Never used new bosch universal plus making bread started rattling sound
I do not know a lot about this machine. I am a DIY fix anything. It sounds like one of the mounting points on either the motor or the gearing gave way. Regardless it is new, send it back & have it fixed or replaced. Sorry, I know that is not what you wanted to hear, but is safest considering your investment.
Mar 10, 2014 | Bosch Universal Plus 6 Qt Mixer With 800W...
Drive Shaft stopped kneading dough
To give the mixer strength it has planetary gears. Something may be wrong in the gear section
Nov 26, 2013 | Bosch 800-watt Universal Plus Mixer with...
Kitchen aid mixer has a scream when using dough hook.
A little pin or setscrew or key has failed. Maybe a gear has slipped out of place. Anyway, the thing needs to come apart to find out what happened. When taking things apart, line up each item off in a tidy row, put screws in little containers near the part they fit.
Repairclinic.com may have instructions, and probably have the parts.
Nov 26, 2013 | KitchenAid Food Mixers
Kitchen aid mixer overheated
Most of the time this will not be an immediate problem. Let it cool down and do not over work it again. Continuing will eventually burn out your motor and require replacement.
Nov 12, 2013 | KitchenAid KSM50PR Professional Series...
Kitchenaid mixer 600 won't turn on
bread is very tuff on mixers. always buy the strongest mixer that you can afford. im guessing the field in the motor fried.
Feb 07, 2013 | KitchenAid Kitchen Aid KP26M1X 6 Quart...
Mixer arms shake when kneading bread
You have not supplied a model number and the bowl lift models are not all the same. A couple of items you could check, make sure that the bowl retaining clip that engages with the dimple on the pedestal side of the bowl is not broken. Make sure any bolts/screws holding the pedestal to the base or the pedestal to the motor are tight. Even if you supply a model number I can't think of anything else to look at unless the handle is not lifting the bowl up tight enough. I think on some models the arm holds the carrier up with some pressure which would help stop the wobbles.
Jul 13, 2017 | KitchenAid Kitchen Aid KP26M1X 6 Quart...
Used the bread kneading hook, after 10 minutes, smoking
The mixer motor has probably overheated, as proper use and care was not being followed with the stand mixer.
Bread doughs are recommended to be mixed on speed 2 only and never for longer than 7 minutes. With the resistance of a bread dough that is provided against the beater, mixing for over 7 minutes may overheat mixer and cause smoking.
Please consult your use and care guide to refresh your memory about how to properly use your mixer for making bread doughs.
Jun 07, 2009 | KitchenAid K45SS Classic Stand Mixer
My mixer was straining to stir bread dough. Now the motor turns on, but the arm does not rotate.
Did you hear a CRACK sound just as the mixer stopped running? If so, the plastic transmission housing may have failed & destroyed the worm gear and the front and rear bearings and possibly deformed the bearing seats as well. It happened to me. Although these machines are marketed stating that they can knead bread dough, they can't. Mine failed 5 months out of warranty, after only30 batches of Sourdough Bread. Take the top cover off of the mixer and look for the transmission housing near the front of the mixer. If there obvious cracks in it, it is your problem.
Dec 03, 2008 | KitchenAid K45SS Classic Stand Mixer
Mixer stopped turning when I was making bread
You probably have stripped the gear in the head section. It can be replaced, but I would consider this a advanced repair since you need to push steel pins out of the shafts to replace the gears. Use google to find a local repair shop, or fix it yourself if your mechanically inclined, parts are available online (and not that expensive).
Sep 26, 2008 | KitchenAid KP2671 Professional 6 Series...
Hobart N50 Stand Mixer Logo
691 people viewed this question
Top Hobart Food Mixers Experts
Ross Keen
Steve Allison
Steve Allison
Bruce Showalter
Are you a Hobart Food Mixer Expert? Answer questions, earn points and help others
