Question about Onkyo TX-SR803 Receiver
Trouble with the hooking up wiring for receiver, DVD/VCR combo and satellite to new DLP TV.
I just bought a 65"DLP tv and I'm trying to hook my DIRECTV satellite, combo DVD/VCR to my Onkyo TX-DS484 receiver. I don't have any volume coming from my new TV, only sound through surround sound speakers. Mute is not on. Is there a wiring diagram beside the one in my Onkyo owners manual. It doesn't have anything about satellite connections. Thanks for your assistance. jeff
    Habit-Forming:
  • 9 Answers
Jar50, lacking model numbers for your TV and Satellite, I would suggest connecting your DTV Satellite OPTICAL out to your 65"DLP. Connect your 65"DLP OPTICAL out to your Onkyo TX-DS484 OPTICAL in. If you are using the DIGITAL COAX, just substitute the instructions above from OPTICAL to COAX.
Hope this helps.
Posted on Aug 31, 2017
techman
  • 3130 Answers
SOURCE: no surround sound
So your saying that you have no rear channel. Some recivers use a single stereo output ic for both sides on the rear speakers. you could have a defect with this IC . Anther thing Im sure you check3ed the obvious ie : the switch is on suround sound? If there is a front to rear fader is it in the middle? Good Luck
Posted on Jun 04, 2006
  • 151 Answers
SOURCE: Zone 2 on Onkyo TX SR805 inoperable
HI pull down the flap on your amp and you will see buttons for zone 2 settings,press zone2 then level up this should work.
hope this helps .
CABLE GUY.
Posted on Aug 05, 2008
SOURCE: new home theater setup- no signal at tv using onkyo tx=sr605
This might somewhat help. Today I went back .. I went HDMI out of the Cable box and DVD player into 2 of the TVs HDMI ins. The digital audio out from each, straight to the receiver and things are working ok. All speakers are working OK. Sound isnt as loud or crisp but unfortunately I found no other solution.
Posted on Jan 06, 2009
  • 15 Answers
SOURCE: Onkyo ht-r530 Receiver troubleshooting
the 7.1 sound not all the movies has that feature and u need to emulate it, doit in the dolby digital ex and the speakers must sound.
try the volume for the SBL or SBL maybe are to low.
decrease the volume for all the speaker less the SBL, SBR and check it out.
Good Luck
Posted on Jan 12, 2009
taran_2005
  • 10515 Answers
SOURCE: No surround sound from my PS3 through the Onkyo 5100. Video OK
Unfortunately only the higher end Onkyo Reciever pass audio over HDMI for sound. 605,705,805,905 exc. Your reciever will carry Video over HDMI but you will need a digital optical cable for sound.
thanks.
Posted on Jan 24, 2009
How do I hook up the DVD/VCR to cable box and Vizio HDTV?
both should be hooked directly to tv
VCR side of combo should be hooked up with composite video(yellow, red, white wires) to video 1 input
DVD side of combo should be hooked up component video (red, blue, green wires and red white for sound)
cable box should be hooked up HDMI or component to TV if HD or composite video if SD
hope this helps
good luck
Mar 13, 2011 | Samsung DVD-V4600 DVD Player/VCR
How to hook up dvd/vcr combo to a tv with dish satellite
Run the line level outputs (red,white, and yellow), from the satellite receiver into the "In" terminals on the dvd/vcr...then run the line level outputs from the dvd/vcr to the inputs on the tv
Dec 27, 2010 | Philips Magnavox DVD/VCR Dual Player
I have a DVD1001 DVD VCR combo how do I hook DVD combo to my tv
Use output of combo player to input of TV. Use what ever available input you have left on you TV. HDMI or Component input is best, but others will work.
Dec 30, 2009 | Insignia IS-DVD1001 DVD Recorder/VCR
Would like to record from my tv to my magnavox dvd/vcr combo box
If I understand your request right, You do not have cable or satellite box.
You can not record from your TV. You use the TV as a monitor from the dvd/vcr combo box. What the box receives is what shows on the TV. So you will have to have a digital convertor hooked to the (antenna in) dvd/vcr combo box, (antenna out to the tv antenna in) Depending on the antenna you are using that is on the other end of your cable-in coax connection this will hook to your antenna in on the digital convertor box. If your cable is hooked up and operating correctly and directly to the tv that is digital ready you probabbly have a good picture. When the vhf/uhf signal was transmitted you could go from the dvd/vcr to the tv with no problem. But now that the signal is digital and the tv is set for digital the dvd/vcr will not pass a digital signal to the tv. Best suggestion, you have to get a digital dvd/vcr receiver. If you have more question please contact me.
Mike
Jul 25, 2009 | Philips Magnavox DVD/VCR Dual Player
We are unable to get video (picture) on our TV, when we hook up to our new DVD/VCR combo. The combo doesn't have an S-video port and our TV does. We get perfect sound though.
Your TV should also have a regular composite video input jack (yellow) in addition to the s-video input. Use that input instead of the s-video. The video won't be quite as clear as with s-video, but you have to work with what the combo gives you.
Apr 22, 2009 | Zenith C27A24T 27" TV
Getting Surround to work
The easiest way is to hook up your DVD/VCR combo directly to the back of your Sharp LCD TV, then run a component audio output from the TV to the audio input in the back of the receiver. Make sure you hook up your front, center and rear speakers correctly to the receiver, then go through with the speaker calibration steps - per manual, then it should work with no problem. Good luck!
Marc
Sep 07, 2008 | Sony STR-D665 Receiver
Hooking up a dvd/vcr player
The easiest way to connect the unit is via coax. You can come out of your satellite receiver via the "Out to TV" on the back of the receiver to the "In from Ant" on your DVD/VCR combo. You can then connect another coax from the "Out to TV" on the DVD/VCR combo to the "Ant/Cable" input on the back of you TV. Make sure the satellite receiver and the vcr are both modulated to the same channel, normally channel 3.
Dec 31, 2007 | Emerson EWF2004 20" TV
I can't hook it back up
Is your DVD player a DVD/VCR combo? If so, hook the "tv out" (sometimes called "ant out" ) to the "ant in" on the DVD/VCR, then hook the "ant out" of the DVD/VCR to the "ant in" on the tv. Then make sure the DVD/VCR and TV are on the appropriate channel (3 or 4).
If it's NOT a combo, or these instructions don't work for you, i will need pictures of the inputs/outputs of the devices.
Nov 08, 2007 | DISH Network DVR-625 DTV Receiver /...
Connecting VCR/DVD combo
Put the Tv on Channel 3
Jul 11, 2007 | Sanyo DS25390 TV
Onkyo TX-SR803 Receiver Logo
130 people viewed this question
Top Onkyo Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you an Onkyo Audio Player and Recorder Expert? Answer questions, earn points and help others
