Question about Mitsubishi WS-55809 55" Rear Projection Television
WS-55809 HD1080
DISH network installed - said 35 HDTV Channels - Our TV has been in storage for 4 yrs., working great - however, it was label at time of purchase HD Ready. DISH said their receiver/tuner makes our TV HD ready? Is that true? of course the repair guy had it on the Animal Channel and it wasn't an HD channel to test.
Do we need anything else to make it HD ready?
    Genius:
  • 1,153 Answers
Nothing but a HD signal!
Posted on Nov 30, 2007
How do I enter the dish network code to hook it up to my tv?
Try this link it will give you programming codes and instructions.
http://www.dishnetwork.com/downloads/pdf/user_guides_and_manuals/Remote_Codes_Web_Page.pdf
Daniel Busa
DISH Network Customer Service
Nov 30, 2010 | Mitsubishi WS-55809 55" Rear Projection...
I am setting up my proview pa-32jk1sa, for the first time. we have dish network, but all my tv says is please scan channels. i have my coaxial plugged into hdtv, and also went to settings for hdtv and set...
chances are that your reciever is outputting conventional NTSC .. not high def ... so you would scan for standard channels not hdtv .. if chanel selection is done by the satelite reciever then the scan will only find one channel 3 or 4 usually (or better yet you can use Svideo or component oututs if it has them .... if the receiver is a block converter that uses the tv to tune channels then you should get more channels detected ..
Jun 24, 2010 | Proview PA-32JK1A 32 in. LCD Television
Get dish network to work with hp SR5505F COMPAQ PRESARIO COMPUTER
You can not change channels on Satellite with your TV tuner card. The satellite box decodes the sat signal (it is sent encrypted) you can run S-Video/RCA/HDMI depending on the video card input, but you will be required to change the channel on the Dish box. The TV card can only change channels on broadcast (over the air) channels, you can attach an antenna and it will use the NTSC tuner to change analog channels (if they are still available) and the ATSC tuner to change digital/HD broadcast channels. This card (from your description can ONLY deal with broadcast TV, You will need a TV card with a QAM tuner for unscrambled digital cable. There is no solution for directly interfacing with Satellite on a PC or Mac (DirectTV or Dish) the signal from the satellite is encrypted and requires (at least for DirectTV, a fairly complicated decryption setup to function, this is handled by the tuner box/card combination. Sorry your setup will not support changing the channel on the PC, you may be able to find some kind of software that can utilize an IR transmitter to change the channels on your satellite box, similar to the way a Tivo or other DVR can talk to cable boxes, but that is the best you will be able to do as far as channel changing.
Jan 09, 2010 | HP Computers & Internet
WS-B55. HDTV Receiver. Suggestions
Have to call DTV and find out if it is worth it. My rear projection TV was built in August 2002. It works very well and with the "digital" image that comes with the provider reception is very good.
Jan 14, 2009 | Mitsubishi WS-55809 55" Rear Projection...
True HD1080
You can use the DVI connection, or the digital HD rca connections on the back. You can also get a dvi to hdmi converter plug.
Dec 09, 2008 | Mitsubishi WS-55809 55" Rear Projection...
27}" Symphonic
Oh ok, make sure in the menu of the tv is set to Air and not Cable.. that should fix your issue.
Sep 25, 2008 | Symphonic ST427FF TV
Pinching in at the sides and has blurry rainbow coloring on top and bottom.
Sounds like a pincushion problem. You can obtain the service manual and free diagnostic upport at the following link. Hope this helps.
http://servicemanuals.vstore.ca/
Jan 28, 2008 | Mitsubishi WS-55809 55" Rear Projection...
Mitsubishi HD1080 TV will not turn on.
On my Mitsubishi WD65-613 it was 4 capacitors on the DM board. They are 1000mf 16v, replaced with 4 1000mf 25v. TV is working great.
Nov 02, 2007 | Mitsubishi WS-65615 65" TV
Entering Service Menu
OPTION MENU "MENU 0170" SERVICE MENU "MENU 0157" CONVERGENCE MENU "MENU 0159, 4 FINE, 5 COARSE, 6 MISC." By pressing Menu then #
Aug 18, 2007 | Mitsubishi WS-55809 55" Rear Projection...
Mitsubishi WS55809 "red" converge problem
Proper description is convergence IC ...part # STK392-570...
there are two in model # WS 55809...replace both.......T.
Jul 30, 2007 | Mitsubishi WS-55809 55" Rear Projection...
Mitsubishi WS-55809 55" Rear Projection Television Logo
114 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
