Question about Kenmore Elite HE4 Electric Dryer
Help i cant get my led open on my washing machine.it a kenmore elite .it shut off iin the middle of a cycle and all the light were on .i unplugedit now it does nothing no power .nothing
    Scholar:
  • 146 Answers
Check your circuit breaker. Even if it doesn't look tripped reset it anyhow. Try that first.
Posted on Dec 22, 2007
SOURCE:
Won,t work just flashing blue light
Cycle light flashes, but machine wont start - Kenmore Elite ...
https://www.ifixit.com/.../Cycle+light+flashes,+but+machine+wont+...
iFixitThe Kenmore Elite HE3 is a washing machine by Kenmore. ... Whatever cycle I choose, the light just flashes and holding the start button ... I don't seem to have a black pin....the normal wash button just keeps flashing and won't let me start or .
The good ol' Whirlpool Lid Lock Flashing Light Problem - ApplianceBlog
www.applianceblog.com/.../42456-The-good-ol-Whirlpool-Lid-Lock-Fl...
Dec 11, 2013 - 10 posts - ‎3 authors Red Lid Lock light flashing intermittently when you try to start a cycle. ... Mode -- Lid Lock won't work, nor will anything that requires the lid to ... Once the lid has locked the second time, the washer ... shuts down with the lid lock blinking; go back into diagnostic codes and look for shifter or speed sensor errors ...
Nov 26, 2015 | Washing Machines
My Kenmore Elite Ultra Wash Dishwasher keeps shutting off before entering the cycle. I have repositioned dishes, even emptied it, changed cycle and tried everything. When I press the start light flashes...
I too had problems with the Kenmore Elite (aka Bosch). The issue was solved by replacing the Lock Sensor on the door. After replacing the sensor the dishwasher has been working. Hope this helps.
Oct 08, 2013 | Kenmore Elite 24" Built-In Dishwasher with...
Machine just died in middle of cycle. will not
first of all take the waste pipe out from the back of the washer which goes to the outside drainage,make sure you have a bucket to catch all the water that comes out,the lower the pipe the faster it will come out,then you will be able to open the door,and the problem that you have with it stopping in middle of cycle is that the bushes are worn on the motor,these are easy to replace and cost about £10.00
Jun 07, 2009 | Kenmore Elite Oasis 27052 Top Load Washer
I have a Kenmore Elite Washer that does not complete the wash
The timer should be checked/replaced.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Jan 12, 2009 | Kenmore 22422 Top Load Washer
Kenmore elite washer problem
sounds as if you have a drain issue, most common cause of fault is theres something stuck in the pump housing. remove the lower acess panel(3 screws along the bottom of the forn of unit) youll gain acess to the pump housing, remove the large cover to the "button trap" by uncscrewimg the cover, it will be righthin front of you in the center of machine when cover removed, im sure youll find your blockage within there
Oct 29, 2008 | Kenmore Elite 45986 Front Load Washer
Kenmore elite front load washer
I HAVE A KENMORE ELITE WASHER AND IT STOPS IN THEN MIDDLE OF THE CYCLE AND DOESN'T RISNSE. THE DISPLAYS SHOWS F21. CAN YOU LET ME KNOW WHAT THIS MEANS?
Sep 22, 2008 | Kenmore Elite 45986 Front Load Washer
Stopped in middle of cycle
Read other postings about the filter housing located underneath the machine. Clean it out first. We had this problem for a while before the machine finally refused to run anymore.
Jun 20, 2008 | Kenmore Elite 45986 Front Load Washer
Washer kenmore elite calypso 21086
promblem with the lid switch is it happing durning the drain spin cycle
Jan 20, 2008 | Kenmore Elite 21086
Kenmore Elite HE4 Electric Dryer Logo
57 people viewed this question
Top Kenmore Dryers Experts
Marvin
Marvin
jimorris77
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
