Question about Polaroid FLM-4234BH 42 in. LCD HDTV
Polaroid LCD The blue light comes on the the tv does not turn on?
  • 3 more comments
  • sybill Dec 26, 2007
    got tv for Christmas. Used it with Wii for a couple of hours, watched tv for about an hour, now no picture, just blue screen
  • jemoore Dec 31, 2007
    I had the same problem with a 37", 14 month old unit. I found that by unplugging the unit momentarily, the TV would then come on after pressing the remote ON button. It progressively required more and more power off cycles for the TV to come on --- then finally it would not work any more. It would appear that it might be a relay failure that applies power after the remote turns the unit on. After the one year warranty period, I fear that this Polaroid unit is a throw away item. Any help will be appreciated before it is canned.
  • buttersbee Mar 06, 2008
    I have a polaroid 32" LCD TVthat I have had for around 1yr 4mo and it is doing the exact same thing. It would only take one try to turn on then a couple of tries then eventually you would have to unplug it because the power light goes blue then gets dimmer and blinks and it wont even show the polaroid sign or anything.
  • sgarza May 19, 2008
    flm-4234bh 42 in.
    Turns on watch for ablout 13 minutes then it turns itself off. Tries to flash back on but can't.
  • LJ2008 Jul 25, 2008
    I have the Polaroid 42" LCD HDTV and when I turn it on it will stay on for a few seconds and the screen is black. I have unplugged it from the wall and plugged it back in with the same results. I can hear the program and no picture. Is there a quick fix or am I out of luck. The TV was just purchased in Nov. 2007. Please help!!
    Problem Solver:
  • 5 Answers
It seems to be a bad power supply and you will need to have this replaced in order to get it working
Posted on May 12, 2009
I turn on my Tv and only last 6 min then, he sceen is black an the blue ligth is on and only i can hear the channel what can i do?
Posted on Nov 13, 2008
Sybill change tv input
Posted on Dec 26, 2007
SOURCE: 37" polaroid lcd tv won't turn on
I have the same problem, very unreliable, just tried solution posted on this board and it worked. Turn on - while LED Bliinks push the channel button - also tap back a few times not too hard not too soft - possible problem(s) here, as suggested on tyhis board, capacitors (sic?), poor soldering connection, (In which case tapping might make it worse, but if you have no pic, nothing lost nothing gained), good luck, repair work suggested at about 200 bucks on this board.
Posted on Mar 02, 2008
  • 192 Answers
SOURCE: polaroid flm373b wont come on
Try the following fix posted by stiv0. It worked for me.
http://www.fixya.com/support/r741402-polaroid_flm_373b_lcd_tv_black_screen
Posted on Jul 18, 2008
It worked. I replaced the two bad capcitors on the control board and presto. Thank you for solving this. I just about threw away my expensive HDTV, but for only 20 bucks it now works. I hope we can let more people know.
Randy
Posted on Oct 16, 2008
Here's the fix:
http://www.fixya.com/support/t293971-37_polaroid_lcd_tv_turn
I had the same problem with mine. Replaced the capacitors and now it works. When you open the back of the tv up, the problem is with the 2 capacitors on the upper left of the top card. Mine didn't look damaged except for a very, very slight bulge on the top. If you've never soldered anything, you might want to take it to someone who has, otherwise, it's a pretty simple fix. I was surprised I could do it so easily.
If the warranty is still good, make Polaroid replace it. They make shoddy products and should pay for it. And never buy another Polaroid again.
Posted on Oct 30, 2008
  • 5 Answers
SOURCE: how to disassemble polaroid TLA-01911C lcd tv
1) Take the foot off the stand and with a long philips screwdriver remove the single screw that is at the top of the leg (inside leg). Then with the tv facing down lift straight up on the leg.
2) remove the two screws comming from the back of the tv along the bottom edge.
3) With the tv face down on a soft surface ( towel, bedspread, ect).
4) Be carefull with this step it this tv gave me some difficulty and I am experianced with this proceedure. Too much pressure or forcing it too hard will break your case. The back of the tv has a lip which inserts into the face.The face has tabs that lock into slots in the lip of the back. Carefully pry between the face and back pannel (I used my thumbnail and a 1" plastic putty knife.) and slide along the seam until the locking tabs pop loose. Continue sliding your instrument along the seam until all tabs are loose.
5) The back of the tv lifts off of the face leaving all electronics in the face of the tv.
That gets you into the tv. what you do from there is up to you, Good luck;)
Posted on Mar 19, 2009
I have a polaroid 15.4" LCD TV. The blue light
i think this can repaired, change the lcd tv screen it will work, your lcd was broken at all
Jan 22, 2011 | Polaroid TDA-03211C 32 in. LCD HDTV
37" Polaroid HD LCD black display but appears to be "on"
The power supply board was having problems before.That the board,where the power a/c cord plug into it Now might also the Tuner board are dead too.The tv Tuner board,that the board where the tv broscast signal cable plug into it.That the Tuner board.Tries Websites like shopjimmy.com,Ebay.com to buy a refurbish power supply board for the replacement to see if solved the problem,not probally will have to buy the refurbish Tuner board for the replacement too.
Jul 13, 2010 | Polaroid FLM-3734B 37 in. LCD HDTV
Blue LED light comes on but nothing else happens when turned on
It can be the main board or the power supply, look at the power supply first since it is easier to get to, look for burnt parts, bad capacitors, etc.
http://en.wikipedia.org/wiki/Capacitor_plague
Please post back what you find
Nov 28, 2009 | Polaroid FLM-323B Television
Tv wont turn on, but have light on fornt of lcd tv? How do I get the power bac on? Has a red light. TV should have blue light when tv is turned on. The light stays red. Why wont it come back on with the...
You are only have 5v standby circuit working, the problem can be in the main control board (not sending signal to turn on the main power supply sections) or the main power supply sections are bad.
Nov 05, 2009 | Polaroid 3211TLXB 32 in. LCD Television
Polaroid tlx-03210b lcd tv tv will not turn on
Yes I think that would be the problem, aswell as some dry (cracked solder joints). A bad cap is usually bulged on the top and looks like this:
http://www.auroracomputer.ca/images/bad_cap.jpg
hope this is helpful!
May 07, 2009 | Televison & Video
Polaroid tlx-3210b tv will not turn on the red light comes on and the blue light comes on when you hit the power button but still no picture or sound have to unplug tv to turn off blue light. contacted...
Symptom shows that Mani Board is bad in your TLX-03210B Polaroid TV and need to be replaced. I do not see problem of capacitors in power supply board. Problem seems in system control section of TV that is located on main board.
Click Shop Jimmy as it is best source to obtain boards of LCD TVs.
Please call Shop Jimmy for main board availability as currently its out of stock.
Hit "add a comment" button for further query / info.
Thanks.
Apr 30, 2009 | Televison & Video
TV won't turn on
I have fixed many polaroids, the problems is most of the parts are contained in one self contained control box. it sounds like your power board is not funtioning. contact polaroid and let them know about your problem and see if you can get a new control panel. the contol panel only has one connection and 3 screws to replace. hope this helps.
Apr 08, 2009 | Polaroid FLM-4034B 40 in. LCD HDTV
Polaroid FLM-4234BH 42 in. LCD HDTV Logo
572 people viewed this question
Top Polaroid Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Polaroid Televison and Video Expert? Answer questions, earn points and help others
