I've got a RBS305PD01 Model Whirlpool Oven. This morning the control panel started beeping and I'm getting an E3 F2 error code. Can anyone help me decipher what this means?
SOURCE: F2 E3 error code- Oven won't turn on now
I ended up calling a technician to come out and look at it. He said that the front panel where you push all the buttons went out and I would need to get a new panel.
SOURCE: My whirlpool oven is displaying E6 and F2. It
Your cancel key is defective at this point. follow these steps below?
1. Check keypad connector for firm connection (keypad connects to control
board).
2. Press CANCEL. If error code returns after 60 seconds, replace keypad
(also called touch pad or membrane switch). Some models incorporate keypad
in to control board as one unit. In this case, replace control board (also
called ERC or clock).
SOURCE: Whirlpool RBD305PD has error F2E6 error on control panel
When this code appears and display is going blank too, it is always the control board. The only option is to buy a new one or get it repaired. It can be fixed quickly and reliably. www.fixyourboard.com
SOURCE: Warning codes f2 & e3 on Whirlpool oven
Remove the power from the oven. Open the control panel and unplug the key pad ribbon from the control board. Assemble the control panel back and turn the power on. Wait a few hours.
If the error code came back on, replace the control board.
If the error code did not show up, replace the control panel (the key pad comes as a control panel assembly).
good luck
SOURCE: Displays F2 E6 on Whirlpool RBD305PDQ10 double
I wrote a blog on this topic recently, perhaps this will help you:
appliancejunk.com/blog/2009/11/11/whirlpool-oven-e6-f2-error-code-failure-andor-blank-display-board-not-available/
Best Regards,
Bruce
