Question about HP PSC 2110 All-In-One InkJet Printer
Printer color problem
Photo color copy comes out with bands of blue and pink and yellow
    President:
  • 4,402 Answers
The ink cartridge cleaning process can be performed even with the alignment message showing in the display. Follow the steps below to perform an ink cartridge cleaning process from the front panel:
  1. On the front panel, press Menu or Setup (depending on the model).
  2. Press the Right Arrow (>) until Maintenance or Tools appears, and then press the Enter or OK .
  3. Clean ink Cartridges should appear in the display. Press Enter or OK to begin the cartridge cleaning process. A page will be printed during the cleaning process with all of the colors on it. If any of the colors or the black are missing, faded, or streaked on the alignment page, there is a ink cartridge problem.
Posted on Dec 18, 2007
SOURCE:
I have never used the Photo ink Cartridge #58. It intal pic shows putting it where the black one goes-does this mean I would use the color and the photo one at the same time instead of the black one?
Yes correct.The photo cartridge has to be inserted, where you install black cartridge.The photo cartridge gives finishing touch to the photos which you print.The actual photo comes from the color cartridge only, but for lightness and darkness, the color(ink) from photo cartridge gets used.In photo cartridge there are three color ink, that are light pink, light blue and grayish black.In color cartridge there are three color ink, that are pink(magenta), yellow and cyan( blue).------------- This are the details.Thank you for using fixya.
Mar 24, 2011 | HP Deskjet F340 All-In-One Printer
Brother Printer-copy-scan-photo capture Model DCP-110C After replacing black ink and yellow ink, still says yellow ink low, and will just print out pink menu items, no message. I cleaned it 5 times. ...
place the printer cartridge into a small amount of water to make sure the yellow is flowing out. Let me know what this finds and try it again if yellow comes out.
Also, what exactly did you clean, the metal contacts?
Jul 03, 2008 | Brother Office Equipment & Supplies
Printer won't print yellow
Either theyellow is finished or the nozzles are blocked. Try cleaningthe nozzles of the cartridge.
May 26, 2009 | HP PSC 2175 All-In-One InkJet Printer
My color on my printer is coming out too blue
Sounds like either the color cartridge is out of yellow or the color cartridge is not working properly.  First step would be to change the color cartridge.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/larry_1fe25e09c54eece2
Dec 14, 2008 | Kodak EASYSHARE 5500 All-In-One InkJet...
Printer S400 won't print out blue and pink ink
Hi..
The nozzles have gone bad...it needs to be serviced or replaced...i appreciate your efforts yoy put in to fix the problem thats best we can do after all its a machine.if the printer is in warranty contact the manufacturer.
Regards,
debroy
Nov 25, 2008 | Canon S400 InkJet Printer
Prints all yellow, with some blue and black, no brown
the problem is very simple the magenta ink the cartridge is over or the head is been blocked from where the magenta ink comes out,
because red colour requires ---yellow plus magenta(pink)----to make it red.and ----dark yellow plus magenta(pink) -------- for brown colour.
Nov 22, 2008 | Canon PIXMA MP780 All-In-One InkJet...
Printer will only print in purple/pink,enstalled new colour cartridge configured as required,still no change. help thank you
Print out a calibration sheet, either from the menu, or press photo and cancel at the same time. Your calibration sheet is probably missing a color. You should have black, blue, yellow, and magenta(pink). If you're missing any of these colors, your printhead is clogged. Try doing a printhead cleaning. Print another calibration sheet, if the color is still missing, you need a new printhead. Call Kodak.
Sep 30, 2008 | Kodak EASYSHARE 5300 All-In-One InkJet...
Pink copies
Most printers is run by 4 colors black and the colored is basically yellow red blue. (or may called it magenta cyan etc)
1. One of you colored ink runs out that why you cant make any colored.
2. Or one of the basic color might be clog up, dry or simply empty.
3. you need all the 3 colors to make all the colors available.
e-mail me at [email protected]
good luck
Apr 08, 2008 | HP PSC 1410 All-In-One InkJet Printer
Color images printing in stripes
yes clean your ink well manually
here is the service manual for your printer
http://www.nodevice.com/manual/newmans/1164257699mp750780smpdf/get13922.html
it has trouble shooting and step by step repair instructions
Aug 28, 2007 | Canon PIXMA MP780 All-In-One InkJet...
HP PSC 2110 All-In-One InkJet Printer Logo
110 people viewed this question
Clive
Clive
Ekse
Thomas F. Schneider
