Question about E-Machines eMachines Desktop PC
Doubles computer is showing the same line of information in the tool bar areas twice
  • koolkat Dec 01, 2007
    I replaced my home m page and the problem was gone. thank you for your time and input.
    Novelist:
  • 150 Answers
Hmm, not sure exactly what the problem is. Where are the toolbars, what application?
Posted on Dec 01, 2007
SOURCE:
Why does Xerox 7335 truncates output from Oracle PDF?
It may not be the printer and I did some research on Oracle and this seems to be a common issue.
I pulled this information off an Oracle knowledgebase it may not resolve your issue and there is more info on the following site if you want to investigate further:
http://docs.oracle.com/cd/E23943_01/bi.1111/b32121/pbr_uxprt009.htm#RSPUB75727
NOTE:
If you're printing to the Xerox MFD with a PS (postscript printer driver) you could try installing and printing using the Xerox PCL driver for your computers operating system. If you printing reports from a mainframe this may be an issue at the mainframe level in which case I would engage your companies IT department for assistance.
Any one of a number of possible causes may account for the truncation of fields.
  • Check the field and determine if it is allowed to expand.
    1. In Oracle Reports Builder, double-click the field in the Paper Design or Paper Layout view to display the Property Inspector.
    2. Find the Horizontal Elasticity property.
    3. If it is set to Fixed, you should change it to Variable or Expand.
    4. Run the report to the printer.
    5. If it still truncates, it could be that the field requires multiple lines.
    6. Return to the Property Inspector for the field and check its Vertical Elasticity.
    7. If it is set to Fixed, you should change it to Variable or Expand.
    8. Run the report to the printer again.
  • If the right most fields on the page are always the ones truncating, it could be an issue with the printable area of the printer. If you are using a PCL printer, then you will have to estimate the size of the printable area and resize your margins accordingly:
    1. Open the report in Oracle Reports Builder.
    2. Go to the Paper Layout view.
    3. Click the Margin tool on the top tool bar. A thick black line appears indicating where the body of your report ends and the margin begins.
    4. Click and drag the black line to the left approximately 0.5 inches.
    5. Save and run the report to the printer again.
    6. If necessary, repeat steps 4 and 5 to determine approximately where the printable area boundary is located and then ensure that your report body fits within that area.
  • If you are using a PostScript printer, you can get the printable area boundary to appear in the Paper Layout view as follows:
    2. Choose File > Page Setup.
    3. Verify that the margins are small and that the orientation is correct.
    4. Click OK. The Paper Layout view should now be able to read the boundary.
    5. Go to the Paper Layout view.
    6. Click the Margin tool on the top tool bar. A thick black line appears indicating where the body of your report ends and the margin begins. A black hashed line also appears indicating the boundary of the printable area.
    7. Ensure that the thick black line is inside of the black hashed line. If it is not, click and drag the black line inside the printable area.
    8. Click the Margin tool to leave margin mode.
    9. If necessary, reposition your fields to fit within the new body boundaries.
    10. Save and run the report to the printer.
  • For PCL, if it is still truncating, try using a fixed space font instead of a proportional font. Sometimes PCL printers have problems interpreting proportional space fonts and it leads to truncation. You should try using a fixed space font, such as Courier, and possibly font aliasing.
    Note:
    Default layouts are built against a generic printer. Each printer has its own printable area. As a result, you may have to reset the report to fit the printer. Ideally, if you know the various printers you will be using, you can design the report from the start to fit the printer with the smallest printable area.
Mar 10, 2015 | Xerox Office Equipment & Supplies
Tip
Where to find driver versions in Windows
Windows is a versatile operating system environment, and there is almost always more than one way to access information. If you need to see what version of a specific device driver you have, there are two main ways to do it.
- System Information
The System Information utility contains a lot of information about your computer. You can find out everything from the maker of your BIOS to what print jobs are currently pending.
System Information can be accessed through the Start menu (Start > All Programs > Accessories > System Tools > System Information). In Windows Vista or Windows 7, you can also type it in the Search bar.
You can view driver versions under either the Components heading -- where all of the driver info is displayed on the last line for each component -- or the Software Environments heading -- where all of the drivers are listed individually under System Drivers or Signed Drivers.
- Device Manager
The Device Manager is your one-stop shop for everything related to your computer's devices and components. For each device, you can view its current status, its driver version, as well as a basic troubleshooter.
To access Device Manager, type "devmgmt.msc" into the Run bar (or type "device manager" in the Search bar). When it opens, your devices will be broken into categories; just expand each category to see the individual devices, and double click on a device to view its properties. Driver information can be found under the Driver tab.
The Device Manager can also be found in the Computer Management console, which you can get to through the Control Panel, under Administrative Tools.
on Jun 03, 2010 | Computers & Internet
My Intel RST is NOT running every time I boot up each day. Your answer didn't solve the problem. It shows in Services, it is running and on Automatic??? This just happened recently...
open control panel and select administrative tools
now select services
find intel rapid storage...
double click and open go to startup type and select automatic and click ok
Dec 05, 2014 | Microsoft Windows 7 Home Premium 64BIT...
HOW DO I UNINSTALL ASK.COM ,I CANT USE MY EMAIL?
IE 11
1.tools
2. Manage Add-ons
3. Tool Bars and Extensions
4. double click on the ask tool bar entry and click the disable button.
5. double click on the ask shopping tool bar and disable it also.
You can also enable and disable search providers here as well.
Apr 25, 2014 | Microsoft Windows 7 Home Premium 64BIT...
I have a problem with word normal.dot, I think normal.dot file is corrupted is this possible by a virus ?
1. Double click on My Computer.
2. Click on the Tools menu in the top menu bar.
3. Click on Folder Options...
4. Click on the View Tab
5. Click on the little button next to "Show hidden files and folders" (in the Advanced Settings box)
6. Click OK.
7. Double click on Local Disk (C:)
8. Double click on the Documents and Settings folder
9. Double click on the folder with your user name
10. Double click on Application Data. (That folder will be dimmed)
11. Double click on the Microsoft folder.
12. Double click on the Templates folder.
13. Right click on the Normal.dot file and delete it
14. Now you need to hide your hidden folders again
15. Click on the Tools menu in the top menu bar.
16. Click on Folder Options...
17. Click on the View tab.
18. Click on the little button next to "Do not show hidden files and folders" (in the Advanced Settings box)
19. Click on OK.
20. Close all the open windows and you are done!
Every time you open Microsoft Word, you go to a blank page. That blank page is called Normal.dot. If you ever open Microsoft Word, and you don't get a blank page, then your Normal.dot file has somehow been changed. If you have this problem, follow these steps
Jun 13, 2011 | Microsoft Windows Vista Home Basic Edition
Connecting to the internet
Start with the TIP
http://www.fixya.com/support/r7957741-sylvania_synet07526_owners
Please follow the detail below.
It is looking for a password (WiFi Network Key) You have to double click on the little computer icon down in the right tool bar area, the one with the two side radiating arcs, and possibly has a small red X under it. The red X indicates that it is NOT connected. When you double click on that icon a window called RT28701 opens up, then you click on Wireless Information tab, then you cursor down to the name of your WiFi and high light it and click the connect box. Then another window opens up called Network Properties. Uncheck "The key is provided automatically" box. This will allow you to type in your "Network Key", the password that protects your network from outsiders. This "KEY" was set up when you installed the router on your server computer. If this does not work at first, turn the machine over on it
Feb 02, 2011 | Sylvania G-Netbook
Shows i am connected but will not allow us to use internet even if we connect to it directly
It is looking for a password (WiFi Network Key) You have to double click on the little computer icon down in the right tool bar area, the one with the two side radiating arcs, and possibly has a small red X under it. The red X indicates that it is NOT connected.When you double click on that icon a window called RT28701 opens up, then you click on Wireless Information tab, then you cursor down to the name of your WiFi and high light it and click the connect box. Then another window opens up called Network Properties. Uncheck "The key is provided automatically" box. This will allow you to type in your "Network Key", the password that protects your network from outsiders. This "KEY" was set up when you installed the router on your server computer. If this does not work at first, turn the machine over on it's back and using a toothpick, insert it into the little hole about an inch diagonally from the right corner of the data plate, this will re-load a new copy of everything including the WiFi RT28701 driver. sometimes this driver gets confused. See my TIP at: http://www.fixya.com/support/r7350901-fix_synet07526_wifi_flashing
This will give you some more options
Dec 27, 2010 | Sylvania G-Netbook
I cannot download a family CD on my computer. there is no tool bar with file etc
Unlike a camera memory card, a regular data CD may not auto open/load into your computer. You need to insert the CD into the CD drive while the computer is running,. It should automatically open Windows Explorer and show the contents of your computer. The CD drive will be an item listed. double click on the drive (probably D:) to show it's contents. Then copy any files from the cd to your documents or photos folder.
Sep 07, 2009 | Microsoft Windows? Vista Home Basic...
"Windows Expolorer in not responding" on Toshiba with Vista
just go to start and then i believe it acessories system tools then to system restore just go to a time where it was working
Jul 18, 2008 | Toshiba Satellite A135-S4527 Notebook
E-Machines eMachines Desktop PC Logo
24 people viewed this question
Top E-Machines Computers & Internet Experts
Ekse
Steve Allison
Steve Allison
Thomas F. Schneider
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
