Question about Whirlpool LBR4132JQ Top Load Washer
How do we removing the back panel?
Hi, thank you so much for helping us. :).
We need to get to the belt. We have removed all visible screws and the screw that held the hot and cold water 'input'.
near the top on both sides are two indents with metal that looks like we are to slide the metal panel up to remove it. But the front top hood looks to be in the way. so we have really a few questions. please.
How do we remove the back panel?
Do we have to remove the front hood and if so how do we do that also?
Thank you ever so much anyone who can help us.
Sincerely,
Cedar's Mommie.
Thank you all so much. it turned out we had to remove the nobs on the controls then unscrew two screws in the back of where the knobs were then careful, slowly lift while moving forward this cover. when it came off then was found two slots where the back cover had two parts of the back slide under with a tiny screw holding all in place. removal of this screw and we were in the back of the washing machine.
thank you so much for your kindness and you time.
Michele
Posted on Jul 21, 2008
    Scholar:
  • 154 Answers
You may not have to remove the panel you may be able to see the belt just by laying the washer on its side or its back the belt should be clearly visable running from the motor to the bowl of the washer. Is the back a timber or metal one. because there shouldn't be any screws up the top holding the back and some washers you can't get the back off. Whats the make and model
  • jeff moore Jul 21, 2008
    sorrty make and model up top
    you should be able to just lay it down on side or back side is better because of drain belt should be right in front may have a plastic cover over it for safety find the motor should be at the back of the washer and belt runs from there to the bowl
Remove Back
Most larger TV's are screwed around the edges and at the bottom and are pretty obvious so I presume you are dealing with a smaller set. First remove the stand and all visible screws on the back and check around input points like scart and HDMI for securing screws there. Once all the visible screws have been removed try to pop the back off as you would on a remote handset starting from the middle of a side, go slowly and with care, some sets are very tightly clicked into place
Jan 11, 2016 | Televison & Video
Hotpoint tcl770 belt split
all you need to do is remove front panel pop the top off remove the two screws on the in side pull the panel up. Now you have access to dryer changing the belt is a pain if you have big hands but they give you room to get one of your hands in there
Nov 16, 2011 | Washing Machines
I have just purchased a used LG washing machine Model number WM2277hw. The door boot or bellow needs to be replaced due to visible and SMELLY mold/mildew. What part do I need to buy to ensure that I am...
The part number for that door gasket is 4986ER0004F.
Yes, you can replace it, it is held on by a spring clamp on both the cabinet, and the tub. The spring on the cabinet can be simply removed with needle-nose pliers. The easiest way to remove the inner spring without LG's special tool, is to remove the front panel. To do this, remove the top panel by removing 2 screws on the back, and sliding the top panel back. Then the control panel needs to be remove. Remove the dispenser drawer. Remove the 2 screws that are now visible where the dispenser drawer was. Then on the opposite side, on the back of the control panel, there is one more screw. Remove this. The control panel will now come off. It will require some prying on the upper edge to snap off. Now open the washer door. Remove the 2 screws by the door lock. Now go to the bottom of the unit. Open the drain trap door with a flat-blade screwdriver. Remove the one visible screw, and then pull the plastic housing out, There should be one more screw on the bottom. Remove it. Now go back to the top of the panel, Remove the 4 screws holding it on, and the panel will now fall forward towards you. USE CAUTION! Edges are sharp! Unplug the door switch harness plug. Now you can access the rear spring ont the door gasket. It can be removed with a pair of needle-nose pliers. The gasket will just pull off... Now reverse everything, and you are done!
May 16, 2011 | LG WM1814CW Front Load Washer
Need to change the belt
Hi, You need to remove the two screws at the lint screen. Then use a flat blade srew driver and insert it in the gap between the top and the front panel. Pry the top upward.
Locate the screws inside the front panel in the upper corners. After these have been removed, the front panel will come off lifting it up.
Now you can see the tub and the belt. If you have the wrapper the belt came in, you should be able to string the new belt. I hope this helps. If I can assist you mmore, please let me know.
Thanks
Vic
May 21, 2009 | Kenmore 64852 Electric Dryer
How to get into the cabinet? I have a Kenmore Dryer that hums but the drum won't turn, maybe belt! Model # 110 62942100 thanks, tom
Kenmore dryer belt
  • UNPLUG DRYER
  • remove lint filter
  • remove two screws in lint filter panel securing cabinet lid to filter frame
  • with putty knife or other blunt blade, depress clips ~2inches in from the front corners of the lid to release cabinet lid
  • tilt lid up
  • remove 1 screw from each side 1/3 the way down
  • remove cabinet front and door
  • motor bearings tensioner are all visible
  • lift out drum forwards
  • check support rollers felts and nylon glide bearings for wear
    (worn bearing surfaces are the most common cause of belt breakage, and you dont want to do it again next month)
  • make sure tensioner is still installed in cabinet base, sometimes breaking belts pull them out
  • loop belt around drum at prior wear marks
  • reinsert drum
  • pull tensioner to end of travel against spring
  • loop belt around motor pully and tensioner
  • relax tensioner
  • rotate drum by hand to make sure belt wont jump off.
Thanks
Fame !
May 04, 2009 | Kenmore 63942 Dryer
How do i change my tumble dryer belt on a beko thanks
Just changed the belt on a Beko DRCS68W and its a real pig! Remove the top panel and loosen all screws on complete back panel having removed circlip holding the drum spline on to the back panel. You will also need to disconnect wires/leads on top right inside panel to give you more space. Once you have done this you should be able to ease away the back panel far enough to get the new belt around the drum and over the drum spline in the middle. Then the tricky bit - getting the belt tensioned on to the motor drive spline. I did this before securing the drum and back panel, which gives a bit more flexibility. I also used about 15ins of 15mm copper pipe to ease the belt down over the motor spline. Hard part was getting the back panel back lined up with the screw holes as the belt tension distorts the casing. Finally hit on the idea of lying the machine on its side so the weight of the drum is pulling away from the motor and helping to line up the screw holes. Two and a half hours later job done! I guess if I ever did another it would be a whole lot easier but still not the type of job I relish!
Mar 06, 2009 | Dryers
Need to inspect tumbler, belt etc. Hoe do I get
Unplug the dryer.
Open the door.
Remove the 4 visible screws.
Raise the hinge side of the door and remove the door,
The front panel will pull out.
Remove 2 screws on the top right and left of the cabinet just under the top panel.
Raise the top.
You will also have to remove the front drum support. 2 screws right and 2 screws left.
Mar 01, 2009 | Maytag Neptune MDE5500AY Electric Dryer
Can't Put Belt On
You have to remove the front of the dryer to
access the drum. First unplug the dryer.There are screws at the bottom of the front to remove the lower section. Once you remove that you can get to the screws for the door section. The front of the drum rides on the inside of the front panel so when you remove the panel the drum will drop down. Try to keep the drum in place with something to hold it up. Remove the old belt and place the new belt around the drum. Slid the belt back to where the belt used to ride and then loop the belt around the motor and the tension wheel. Make sure the tension wheel is tightening the belt. Hold up the drum and put the front panel back on. You may need a helper to hold things while you do this. Rotate the drum by hand and make sure it moves smoothly. Plug it back in and give it a try. I hope this helps. Any questions feel free to ask. Please rate me so I know if I'm Helping. Thanks.
Dec 30, 2008 | Frigidaire FEQ1442ES Electric Dryer
I am trying to replace the belt but the drum is still attached to the back (I have taken every visible screw out). Should I try from the front? Is there a way of getting the drum unsecured from the back?
Dryers do not open from the back
the screws removed secure parts to the inside of the case
carefully replace them.
to opent the front of the dryer
unplg dryer
type I: maytag:kenmore stackable:speedqueen:
  • remove 2 screws from bottom of front panel, swing front panel out at bottom and unhook from dop
  • remove door switch wires from switch
  • remove front panel set aside
type II: Kenmore:whirlpool:ge:frigidaire
  • remove 2 screws in lint filter holder
    depress spring catches at corners of top cover
  • lift top cover at front
  • remove 1screw each side 1/3 way down
dryer internals are exposed and easily repairable
examine back panel to ensure that nothing is detached from screw removal
assemble in reverse order
Note:
while the dryer is disassembled, examine felts rollers and glides for wear, most common cause of belt breakage, if there is any wear, replace.
examine fan, fan housing and ducting for lint that got past the filter screen.
Oct 28, 2008 | Dryers
DRYER HEATS ,BUT DOESN'T TURN
FIRST UNPLUG UNIT!!
Remove 2 screws by filter area on main top.
Grab back of dryer and pull top forward while holding dryer in place with knees. Do this to pop up top on front left then front right. Remove 2 screws holding front panel 2 side panels. They are at top front of side panels, inside.
Pull front panel out at top and pull up to remove front panel. Put belt around drum with grooved side toward drum.
Nov 11, 2007 | Whirlpool LGR3624JQ Gas Dryer
Whirlpool LBR4132JQ Top Load Washer Logo
147 people viewed this question
Sal De
Marvin
Marvin
Gerry Harvey
Gerry Harvey
