Question about Jensen SSR-2000 SIRIUS Radio Receiver
Ssr 2000 interface error
  • expediter Dec 02, 2007
    second problem how to restore memory on ssr 2000
  • BaylorBelle Apr 25, 2008
    My Sirius radio's face says "Interface Error" everytime it's on. What's wrong with it and how can I fix it?
The interface error is a problem with the hand held part that changes the channels. The cheapest way is to buy another whole radio on ebay (there's a guy who has a bunch of them for like $10 each) and just swap out the hand held portion. You don't have to run the wire all the way to the downlink unit in the trunk b/c there's another connector up near the front so you can just unplug the handheld part and plug in the new one.
Posted on Sep 28, 2008
How to clear e004 for ir3170
The SSR has a short circuit.The DC controller PCB is faulty.The SSR used to drive the fixing heater is found to have a short circuit.The error must be reset in service mode COPIER - FUNCTION - CLEAR - ERR.
Feb 21, 2013 | Canon imageRUNNER C3170I Color Copier
Tip
ERROR codes Canon 6650
Canon 6650 E000 Thermistor E001 SSR E002 Thermistor, ht. Lamp thermal fuse or SSR E003 Thermistor, ht. Lamp thermal fuse or SSR E005 Fuser cleaning belt E010 Main drive problem E020 Toner motor, toner level sensor, toner hopper sensor E030 Counter E050 Duplex problem E203 Scan home problem E210 Lens home sensor E401 Document feeder paper pickup motor E402 Document feeder belt clock pulse problem E403 Document feeder main motor clock pulse problem E411 Document feeder sensor problem E500 Sorter/copier interface problem E500 An error is identified in the communication between the sorter and the copier E510 The clock signal from the motor is absent for 250ms or more E510 Sorter motor drive E513 The clock signal from the motor is absent for 250 ms or more E530 Sorter home sensor E530 The home position sensor (P17) fails to go OFF when an equivalent of 2560 pulses of the motor drive command has been generated E531 The stapler unit swing sensor (MS9) fails to go ON within 500 ms after the motor drive command has been generated. MS9 fails to go back OFF within 1000 ms after it has gone on E531 Stapler swing sensor E540 The lead cam home position sensor (P12) fails to go OFF within 2000 ms after the motor drive command has been generated. P12 fails to go back ON within 2000 ms after it has gone OFF E540 Sorter lead cam home sensor E541 Sorter lead cam home sensor E710 DC controller board E711 DC controller board E712 Document feeder problem
on Jan 19, 2010 | Office Equipment & Supplies
Tip
ERROR codes Canon 6150
Canon 6150 E000 Thermistor E001 SSR E002 Thermistor, ht. Lamp thermal fuse or SSR E003 Thermistor, ht. Lamp thermal fuse or SSR E005 Fuser cleaning belt E010 Main drive problem E020 Toner motor, toner level sensor, toner hopper sensor E030 Counter E050 Duplex problem E203 Scan home problem E210 Lens home sensor E401 Document feeder paper pickup motor E402 Document feeder belt clock pulse problem E403 Document feeder main motor clock pulse problem E411 Document feeder sensor problem E500 Sorter/copier interface problem E510 Sorter motor drive E530 Sorter home sensor E531 Stapler swing sensor E540 Sorter lead cam home sensor E541 Sorter lead cam home sensor E710 DC controller board E711 DC controller board E712 Document feeder problem
My cannon immage400s printer error e004 switch main off and on please solution me
the SSR has a short circuit.
1. the SSR has en error
2. the DC controller PCB has a fault.
Description
- the fixing heater remains on
- the fixing temperature has increased abnormally
May 26, 2010 | Canon imageRUNNER 400S Copier
How to release the 004 code error
This is a detected fault in the SSR
The Solid State Relay (SSR) has a short circuit, or the DC Controller is faulty.
The SSR is used to drive the heater circuit, and if a fault is detected, the copier is locked out for safety and fire prevention.
If you are not qualified, you should have a competent technician look at this.
Make sure you have fixed the fault before you think about resetting the error code.
After you have remedied the fault, and the device is safe, the error can be reset in Service Mode.
CAUTION
the error must be reset in Service Mode (COPIER>FUNCTION>CLEAR>ERR).
When you are sure it is properly repaired and safe, you can enter service mode by:
  1. Press user mode key (*) on the control panel,
  2. Press the 2 and 8 keys at the same time,
  3. Press the user mode key (*)
Be careful. Close observation will be required.
May 12, 2010 | Canon imageRUNNER 5000 Copier
Error E062-0001
please change SSR unit
Sep 23, 2009 | Canon imageRUNNER 2000 Copier
Not able to start my machine dure to error below
The SSR has a short circuit. The DC controller PCB is faulty.
0000 The SSR used to drive the fixing heater is found to have a short circuit
(hard circuit detection).
The error must be reset in service mode (COPIER>FUNCTION>
CLEAR>ERR).
Jun 20, 2009 | Canon imageRUNNER 5000 Copier
Canon copier error message "error001"
"E000" Low fuser temp. (Heat lamp, thermoswitch, thermistor, SSR) "E001" High fuser temp. (Thermistor) "E002" Fuser temp. too low "E003" Fuser temp. too low "E004" SSR, Fuser temp too highchange thermistor in fuser
Aug 27, 2008 | Office Equipment & Supplies
Jensen SSR-2000 SIRIUS Radio Receiver Logo
90 people viewed this question
Top Jensen Audio Players & Recorders Experts
 Grubhead
Grubhead
Don Hart
Are you a Jensen Audio Player and Recorder Expert? Answer questions, earn points and help others
