TDK dvd+r home copied disc
Just bought a new Acer computer with NTI cd & dvd version 7.7 on it. OS is vista premium.
Bit of a newbie but I can understand copy rights on store bought cd or dvd's but how come I can't copy a home recorded audio tdk dvd+r disc?
Keeps coming up as unrecordable. Can't even copy it to hard drive.
Any solutions I should try?
Thanks in advance for ANY assistance.
  • 1 more comment
  • Maggie Stevens Dec 02, 2007
    Thanx for the response. I'll give it a try and let you know.
  • rebels13 Jan 20, 2008
    i am havivg same problem too! not sure on checking drives can someone help me please
  • robin1810 May 24, 2009
    I have a similiar problem - have acer laptop & nti Cd&dvd maker gold version
    when inserting CD it says disc unrecordable
    Can anyone help?
  • 270 Answers
Check drive properties inorder to verify whether ur drive support +R dvd
Posted on Dec 02, 2007
Operating system not found
No, you won't get the OS to automatically install on the new drive. The OS is not stored in the BIOS chip (or a similar permanent location inside the computer). You will need an OS install disc (not an upgrade disc). Windows Vista Home Premium or Basic was the original OS on most of the Acer Aspire 4530 series. Acer appears to have drivers for the system for XP through Windows 7 to get the hardware to work. You will need to have these most of these ready before you install your OS. Put them on a flash drive or optical disc using another computer.
This computer may work with Unix as well. However, driver issues may be a factor. You can try most versions of Unix from a CD (LiveCD) to test it out.
When you get a new hard drive, install it into the laptop. Then put the OS disk in the optical drive bay. Boot to the optical drive. Follow the directions for formatting the hard drive and installing the OS. (Of course you will need a drive that doesn't have a higher capacity than the BIOS supports.) The motherboard needs to recognize the drive.
If you find a member of a Windows User Group, they may have Windows install discs available. The license number on the label of your computer will probably work as your license key. (The key for a computer like this is locked to the CPU and motherboard; unless someone upgraded the OS to Windows 7 or downgraded to XP, this should be the key you need.) Use the information on the label to obtain the correct version of Vista (the Basic install disc may not work for installing Home Premium). You also need to match the 32-bit or 64-bit install disc (and the service pack you need).
I hope this helps.
(An Acer recovery disc wouldn't help you. Most of those are completely locked to the original hardware (including hard drive) and look for the recovery partition that was on that hard drive.)
Dec 05, 2012 | Computers & Internet
Windows Installation Disc VS Windows Upgrade Disc -NOT THE SAME-
Having Trouble Booting To Your Windows Upgrade Disc?
...Upgrade discs aren't bootable discs. To repair a windows installation, you must use either a system repair disc or, better yet, a windows installation disc (genuine Retail/OEM discs are pretty much your only option to completely reinstall your windows operating system, unless you own a previous full installation disc of a previously released Windows version (such as XP or Vista), in which case you could install that windows operating system and then upgrade to a newer windows OS like windows 7. however if you ever need to reinstall windows 7, you would either need to reinstall the older windows OS, then upgrade to the newer one.
If that isn't clear, I'll sum it up....
Let's say you bought a computer, that computer had windows xp home edition. Maybe you wanted to upgrade from Windows XP/Windows Vista or Windows 7?
Well in order to switch from Windows XP/Vista to Windows 7, (or even from Windows 7 home premium- to windows7 Pro or Ultimate), then you must either:
A) Buy an upgrade disc and upgrade to the newer desired version.
B) Or, Buy a Retail Copy of the version you want to install. (keep in mind that a retail Windows 7 disc can be used to perform an upgrade rather than to competely wipe the hard disc and perform a clean install (delete partitions, reformat, and perform a new windows installation), if you so choose.
The bottom line is, you cannot Install a fresh clean copy of windows using an upgrade disc. OEM (Original Equipment Manufacturer) and Retail Windows Operation System Installation Setup Discs are "Bootable Discs". Windows Upgrade Discs are NOT bootable. (unless one where to "modify that particular disc, which is not legal).
on Jul 06, 2010 | Computers & Internet
I could not upgrade neither windows XP, Windows 7 of this Product Model: GT5662. Would you assits? Thanks.
Hello kelvinvu, according to the information that I gathered from this computer model, it has Windows Vista 32 bit home premium installed on it. Windows XP is an older operating system so you can't "upgrade" to it. You could however install a fresh copy (more likely completely erasing all your previous information on vista and data files) or you could upgrade to Windows 7. Since you are using "Windows Vista 32 bit home premium", you have to upgrade to "Windows 7 32 bit home premium" or better. So if you were trying to "upgrade" to Windows 7 Home Basic, it will not allow that since it considers that a downgrade in the Operating System. You should actually be able to pop in the Windows 7 Home Premium CD while vista is running and start the upgrade process pretty painlessly that way. Just access the CD and walk through the menus for upgrading Vista to Windows 7. As a reminder, you must use the 32 bit discs. If you try and use the 64 bit discs (a different operating system as far as windows is concerned) you will have to go through the same process of installing a new version of windows (not upgrade). I hope this has solved your specific problem kelvinvu, have a great day!
May 15, 2011 | Gateway GT5662 Desktop PC
My sony vaio vgn-cr220E was uprraded from vista to windows 7..why does the biult in motion eye camera doesnt work..
You need the Win7 camera driver, check sony support at:
just enter your Win7 operating system (there are 9 versions of Win7), and select the downloads (2)
for your computer camera driver.
Versions of microsoft Win7 - determine which yours is by (these instructions are for WinXP);
START > Control Panel > System > General (tab)
Windows 7 Home Basic 32-bit
Windows 7 Home Basic 64-bit
Windows 7 Home Premium 32-bit
Windows 7 Home Premium 64-bit
Windows 7 Professional 32-bit
Windows 7 Professional 64-bit
Windows 7 Starter 32-bit
Windows 7 Ultimate 32-bit
Windows 7 Ultimate 64-bit
May 14, 2011 | Sony VAIO VGN-CR220E/P Notebook
Acer Aspire 5570 NTI CD&DVD Maker 7 1% missing cannot use Help Has been restored from scratch Vista Home Premium
your dvd and cd drivers are missing try to trouble shoot it under devise manager.
Mar 09, 2011 | Computers & Internet
Says my system does not meet requirements . Cannot download . Running Windows Vista with Service Pack 1
You need to install Vista Service Pack 2 Minimum System Requirements:
  • Microsoft® Windows 7 Home Premium (32- or 64-bit), Microsoft® Windows Vista™ Home Basic SP2, Windows® XP SP3 (32-bit) or SP2 (64-bit), 1 GHz processor and 512 MB RAM
  • 1024x768 DirectX 9.0c compatible graphics card with at least 16-bit color setting, sound card, DVD-ROM drive
  • 2 GB free hard drive space for installation
  • Windows Media Player 10 or higher
  • CD Writer for audio CD and DVD Writer for DVD
  • Internet Explorer 7 and 8
  • QuickTime player version 7.6 for some functionality
  • One available USB 2.0 port
Mar 01, 2011 | Roxio Easy VHS to DVD for PC
Not sure what happened ,lost parts of my os for vista home premium 64 bit ,no sound, not even beepcodes,no text when atempting restore ,limited control in command promt, still have some stuff ,pictures...
Which do you have - Vista Home Premium or Vista Home Basic? The title of this question category and what you said you have doesn't match. I'll assume you had Home Premium 64 Bit. Yes you can upgrade to Windows 7, 64 Bit. Please be aware that there is the 64 Bit and the 32 Bit versions. Check with your OEM of the computer before you upgrade. In the upgrade process, Windows 7 will create a folder called "windows.old" once the install has completed. There you will find the data you had from the old operating system like pictures and documents. Before you do the upgrade, I recommend downloading and installing the Windows 7 Advisor to check on any software and hardware issues - the advisor will list those problems before you can upgrade so that you can make the corrections.
Dec 17, 2010 | Microsoft Windows Vista Home Basic for PC
Can not copy dvds
and DVD43
is what i use and it works great
its free
I would down load this first and try it with the program you have. this breaks the codes
Apr 16, 2009 | Microsoft Windows? Vista Home Premium...
Reinstalling Vista and Acer Tech
The restore disk should be available from Acer Suppport here if they no longer support it then you should be able to get it from
Feb 08, 2009 | Acer Aspire 5610-4648 Notebook
Computers & Internet Logo
175 people viewed this question
David Payne
David Payne
