Question about Olympus D-490 Zoom Digital Camera
Pics Appear on My Camera but Not on the SmartCard when I Connect to My Computer
I have a problem similar to the problem posted by DebutStudios.
I have recently taken some photos with an Olympus D-490 Zoom camera. I can review the photos on my camera - (i.e., I can scroll through the photos and view all of them). However, when I remove the SmartCard and plug it into my Edge SmartCard reader that is connected to my computer, the card appears blank. I am able to see the SmartCard with my computer and I've successfully copied photos to it and from it with no problem. I've also uploaded photos with this camera using this method before with no problems.
When I try to review the photos on my camera with the SmartCard removed, I get an error message on the camera that says, "No Card." Does anyone have a solution to this problem?
  • dmiyoshi Nov 30, 2007
    Unfortunately, I no longer have the softward that came bundled with the camera. I would like to upload the photos (that I can see when I view using the camera) to my computer. But when I put the SmartCard in my computer the card appears blank - there are no icons to indicate that anything is on the card.
    The earlier reply to DebutStudios suggested that the photos might be stored internally on the camera, not on the SmartCard. That is why I tried to view the photos without the SmartCard, but that didn't work.
    Sergeant:
    Champion:
  • 298 Answers
Your computer see the card just the same way it see any
other drive it shows icons to represent the files
Thats because thers no card in the camera put
the card in the camera
Did you install the sofrwree bundled with the
camera it might have a viewing & editing program
on the cdrom
Posted on Nov 30, 2007
  • Eugene Merritt Dec 01, 2007
    Bundled software had a progran
    called CAMEDIA Master 2.0
    that would solve the problem
    quickly
    Do you have the serial cable
    and a serial port that you
    can use
    heres the link for the software
    http://www.olympus.co.jp/en/support/imsg...
SOURCE:
Smartcard cannot be forwarded to Terminal Server via RDP
Try re-registering the services on the client computer and see if that fixes it. Otherwise I would consider reinstalling Windows on the client.
Feb 11, 2014 | Microsoft Windows 7 Professional 64 Bit 3...
Instructions how to download pics from a digital camera
connect the camera to the pc using the USB cable; open My Computer - in it the camera will appear as a Removable media; open it and cut the picture files; open a new My Computer window, go from there wherever you want and paste the pictures there.
That is all.
Oct 18, 2010 | Acer Aspire One PC Notebook
My nikon coolpix s3000 wont download pictures to my computer
Hi
I used to have a very similar problem with mien, I couldn't download the pics from the camera. The problem was in the camera that the computer didn't recognize it.
The solution that worked for me was the following.
I bought a card reader ( a cheap one cost around 10$ US)
when I used the card reader
with the camera card I could access the pics without any problem and transfer them as easy as earlier.
if you find a solution to the problem please post it here
Thanks
Sep 02, 2010 | Nikon Coolpix S3000 Digital Camera
How do i get pictures off internal memory onto a computer or sd card
Hi, I have the similar s8000fd and I transfer pics from internal memory by taking out the sd card then connect to a spare usb socket on computer, then switch camera on. To transfer pics from internal memory to sd card - leave sd card in, switch on camera (playback mode), press menu, select copy, select 'internal memory to sd card', 'select frame' or 'all frames'. It should say 'copy ok?' Press OK.
Jul 10, 2010 | Fuji FinePix S8100fd Digital Camera
Trying 2 post pics.........
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program.
May 11, 2010 | Kodak EasyShare One Digital Camera
Can I transfer pics from the camera just by using the port connec
Yes. I understand you?re interested in transferring the pictures from your camera to your computer via USB cable. Please follow the following steps 1: Connect the camera to the computer using the USB cable, U-8. 2: Turn the camera on 3: A window will automatically appear on your display. Please follow the steps given to you by the programme. If no window appears: 3: Go into my documents 4: Find the location of the camera and your pictures 5 Drag and drop from the camera to the computer
Jan 25, 2010 | Kodak EasyShare M853 Digital Camera
Memery card into computer but no pictures
I posted the info below for someone else with a similar problem. I hope it is helpful. Let us know if it is not, Andy If you can remove the memory card and put it into your computer it will see the card. If it does not automatically give you an optoin to veiw the pics. Go to:Start>Computer>expand computer in left pane(your card will have a drive letter and it's name after it i.e.E:\canon sd card.>select your card and look in the different folders, it's usually in DCIM>101 or other ### folders.
Comments: Sep 09, 2009- can you cancel the format. open the folder with pics, then copy them into your documents or picture folder on your hard drive? I have seen these cards do some strange things.
If you still have trouble try rebooting your computer. After restart insert card and try again.
FYI; always let your camera finish processing a picture you have taken before turning it off & never remove the card while camera is on. If batteries2.gif die while processing a photo you can risk losing all pics on card. So download often and replace batteries before they die completely.
Andy
Nov 09, 2009 | Cameras
I found my old dual smart 400 crystal digital camera from years ago and it seems to have pics on it I would like to see. I have no disk for it, is there somehow I can still download the pics off it
Which model? 400, 1200?
Ot has a USB interface on it. Radio Shack has the USB cable ($10) for it to connect to your computer. The camera will appear as a "Removable Drive" ... probably Drive E
Sep 19, 2009 | Cameras
How do I tranfer pictures from camera to computer
First thing is to start the program, then turn on camera, then connect it to usb and it should automatically upload or ask what you want to do.
Jul 07, 2009 | Kodak EasyShare V1003 Digital Camera
Unloading pics easyshare v1003
1. INSTALL THE CD PROVIDED WITH THE DIGICAM ON PC...EASYSHARE...AND THEN CONNECT THE CAMERA TO PC IN CONNECT MODE...IT WILL ASK U TO COPY THE PICTURE ON PC.
2. RIGHT CLICK ON THE REMOVABLE DRIVE WHICH IS SHOWN AFTER U PLUG THE CAMERA IN USB.....U WILL SEE FOLDERS INSIDE THE THAT DRIVE...DUBBLE CLICK THAT AND U WILL SEE THE PICS INSIDE...COPY IT AND PASTE IT ON PC IN THE FOLDER OF YOUR CHOISE
Apr 08, 2008 | Kodak EasyShare V1003 Digital Camera
Olympus D-490 Zoom Digital Camera Logo
87 people viewed this question
Top Olympus Cameras Experts
Steven Wander
Steven Wander
Ekse
Jerry Greenberg
Jerry Greenberg
Are you an Olympus Camera Expert? Answer questions, earn points and help others
