Question about Canon I990 InkJet Photo Printer
Epson CX 9400 fax ink cartridges.
I got a CX9400Fax as a replacement to a CX6600 that "reached the end of its useful life". It was only 1 1/2 old and the authorized repair place wanted $100.00 to change the waste ink pads. The CX 9400 takes 4 of the epson #69 cartridge. I bought some of the generic ones and the printer will not accept them. Is there any way to override this monopolistic system so I can use the less expensive ink cartridge? If epson's price were a little more reasonable I would use them but they are so overpriced.
  • rakulack Dec 01, 2007
    Paul,
    Yes the size and everything seem fine. When I put in the replacement, it says it can't recognize ink cartridge. I put an epson cartridge back in and it will charge that and then will work. If I take out the epson, even though it is not empty and replace it with the generic one. It again says it can not recognize it and goes back to the replace ink cartridge. I have used these generic for years in the 3200 and the 6600 and they worked fine other than having to click a screen that said the cartridge is different every time before you could print. The epson cartridge number is the 69 series or TO691, TO692, TO693, TO694. I had ordered the replacement for these but I see now that the the CX9400 is not listed as one of the units that the generic will fit even though it is the replacement for this number. Is there something in this printer that is engineered so it will not accept anything beside an epson or is there a special type of replacement that must be used?
    Thanks for the quick reply, I did some more searching and found an ink cartridge that lists the CX9400Fax at 4inkjets.com. I emailed them asking them if the Epson CX9400 will definitly
    operate with this replacement. They are priced at 5.99 each. or about 43.00 for a 10 cartridge assortment. I assume I will probably get another window asking me to ok the use of non-epson cartridge. You mentioned that you were concerned about he ink quality. Is there really than much difference and if so, what is the best source for the generic with good quality inks.
    Thanks, Roger
  • 4,102 Answers
Hi i dont think the problem will be with the replacement pads as they wouldnt make them if they did not work your unit shouldnt be able to tell their not originals anyway.
The only reason people tend to buy originals is for the simple fact that you might get a poorer quality of print from the cheaper ones.
Up till now i have had no problem using the cheaper ones i havnt got exactly same unit as you but it sounds like they are not fitting in the unit properly.
Do you still have the ones you took out because if you do you could try putting them in again just to see if the unit exepts them ones or not this way you would eliminate problems with the unit itself.
Check that they are deffinately the same and make sure they are fitted properly if you are sure the unit is working then the problem is with the pads.
Make sure the ones you brought are exactly the same as the old ones the problem shouldnt be the brand as this is what they make the cheaper ones for whilst im waiting for your reply i will look for a manuall for your unit and tell you what i find out ok.
Let me know how you get on and i will try and assist you further ok........
Posted on Nov 30, 2007
  • paul proctor Dec 01, 2007
    Hi again the printer should accept the replacements at least by putting the original one back in you know that the printer is working as it should be and that the problem is deffinately with the cartridge itself, i rang up a friend who know nore about this than i do he said that if the replacements dont cover your exact model number then the printer wont let you use them as you said it didnt list your model on the replacements their has to be a cheaper version out their that will work in your unit.
    But at least the problem is only the cartridge and not the printer if the replacement you have brought does not cover your exact model you wont be able to use them.
    What i will do is look and check if their is deffinately a cheaper replacement for you make and model number if i find them i will post back a message and tell you the outcome.
    If the printer accepts the genuine one then the replacement you brought doesnt cover your model number.
    Their is no way round this as you cant reprogramme the unit itself i will look for you but if their is none you will have to stick to the genuine ones but im sure you can get replacements for all makes and models but will check to be sure sorry couldnt be anymore help i will let you know what i find out ok
    Hi as for the quality i have never had any problems but have heard of people that have brought the copys and they have problems with print quality but this is only rare and you might get one bad cartridge out of every 1000 or so so its nothing to worry about i always buy cheaper versions and have never had any problems at all.
    As this cartridge specifically list your model then the chances are you will have no problems but obviously the first ones you brought must be slightly different inside as the unit wont recognise them.
    I cant see you having any more problems now you have found ones that cover your model number but if you do come unstuck post back and i will help you the best i can hope all is fine now
I have been using my A700/mk25 for six month and recently it has been making a whislting noise when I inhale.
the whistle noise is some thing loose (torn o-ring) inside the second stage. this is covered under warranty. scuba pro offers a parts for life program which is no cost to you if 1st & 2nd stage with a computer are bought at one time. just pay service labor. the whistle noise will be repaired are replaced free under 1 year.
Dec 23, 2012 | Scubapro Mk25 & A700 High End Regulator By...
Error component life
printer counter must have reached its limits. you can find a resetter tool online for this brother printer cartridges
Nov 12, 2011 | Epson Stylus CX6600 All-In-One InkJet...
The projector came on for about 10 minutes and then shut off
Welcome to FixYa.
The projector could be overheating or the lamp has reached its end of life.
Solution:
1. Clean or replace the air filter. 2. Check the lamp run time. If the lamp time has reached its end of life, replace the lamp.
Use the manual to do the above steps. Keep me posted.
Jas247
Aug 03, 2011 | Radio Shack Cinego D-1000 Multimedia...
I switch my CX6600 on but all I get is the exclamation mark light up. |The displau says that par6ts are at the end of their service life. No warning! Anyone help please
That message indicates that the porous waste ink pads inside your product are near the end of their service life. Epson recommends replacing the printer, but if you want to continue using it, I'd suggest having the printer serviced at an Epson Customer Care Center. You may also be able to have the ink pads replaced by an independent service provider and use the Ink Pad Reset Utility to reset the Ink Pad Counter to continue using the printer. However, replacement of ink pads is relatively expensive and may not be a good investment for lower cost printers because the printers' other components also may be near the end of usable life. Hope that helps!
Mar 03, 2011 | Epson Stylus CX6600 All-In-One InkJet...
Parts inside your printer are near the end of their service life. See your printer documentation. _ Epson R200 printer.
Regarding the Epson Artisan 800, I must thank FixYa and ask that the search for a solution be discontinued.Yesterday, I had an unfortunate accident while trying to unclog the print head which had been printing poorly over the last three months. I used a syringe to force a solvent solution through the clogged head. To my utter surprise the supply line exploded with a loud "POP" meanwhile spraying ink all over the place. At this point it was clear that it was pointless trying to redeem the old Artisan 800. Thank you FixYa. Henry.
Feb 27, 2011 | Epson Stylus Photo R200 InkJet Printer
Sharp mx-2300N printer error maintenance required code vk
VK means black developer has reached end of life. You can safly carry on using the copier with this message displayed but over time the copy quality may slowly degrade. You will need to call a Sharp authorized dealer to replace the developer in the developer unit.
Dec 23, 2009 | Sharp MX-2300N Color Copier
Service required error
Ok.. aside from the fact that you've posted under the R300 Epson model thread you're still in luck.
The CX6600 has been documented (by me admittedly) with a complete guide to fitting an external tank and resetting the waste ink counter in the printer.
http://www.octoink.co.uk/store/pages/Epson-CX6600.html
Just to note: This is a commercial site but the information provided is generic and will help you fix the problem.
Feb 15, 2009 | Epson Stylus Photo R300 InkJet Printer
Commercial reach in freezer
Hi scondon15,
I just read this article about the subject you ask about!
How old is the freezer?
Repair or replace?
When to pull the plug on your old refrigerator and or freezer
It nearly always makes sense to undertake simple do-it-yourself repairs,
such as replacing a gasket on a refrigerator or a freezer.
Typically, you'll also find a troubleshooting section for more-serious problems
in the owner's manual.
Should you pay for a repair or buy a new model?
The answer depends mostly on the age of your refrigerator,
how much you bought it for,and the cost of the repair.
Follow these guidelines:
When a repair makes sense.
If your refrigerator is under warranty or less than four years old (three years for top-freezers),
paying for a repair makes sense.
Note that refrigerators under warranty might require service from a factory-authorized technician;
readers have found them on a par with independent repairers.
When a repair might be a wise choice.
If your refrigerator is out of warranty and is four to seven years old,
it might make sense to pay for a repair. Customers generally pay $100 to $200 for a repair.
But you might want to buy a new model even at this stage,
given that today's models are quieter and have added features.
Higher energy efficiency is another plus: Energy Star-qualified models made after April 28, 2008,
are 43 percent more efficient than conventional models built before 2001 and 56 percent
more efficient than those built before 1993.
When it pays to replace.
The repair costs more than half the price of a comparable new refrigerator.
Data also shows that it doesn't pay to fix a less-expensive top-freezer refrigerator
six or more years old or a bottom-freezer or side-by-side eight or more years old.
Thanks to better recycling programs, less than 10 percent
of a refrigerator you replace is likely to end up in a landfill.
Thanks for giving me the opportunity to help!
Please do not for get to give a rating before you sign off!
Thank You, HUUUM
Sep 19, 2008 | Piper Products Freezers
The Epson cx6600 scanner
The service life of a device also called a service cycle can amount to thousands of hours. So go ahead and scan them all, I doubt that you would scan enough to render the unit defective but if you are using a new unit dont worry since it is still under warranty. You can always have the store or the manufacturer replace it. Also, as long as you put the scanner on a stable and level base then there should not be a probelm. Be careful as well when moving the scanner from place to place use the lock under the scanner if you will move it
Message if you need further assistance.
Sep 07, 2008 | Epson Stylus CX6600 All-In-One InkJet...
Make those arragemnets, it needs its waste ink pads replaced and ink clean counter reset via Epson Service software (Eagle)
If you just rest counter you are likely to have ink running loose into printer, there are 8 seperate ink pads in these none of them easy to replace, machine need to be fully stripped to do so.
These macnes count how many cleans they do and stop when figure that epson estimate ink pads are full is reached. It is more ecomical to replace inkjets than to fix, buy a new one with gen inks warranty for same price as repair bill.
Nov 17, 2007 | Epson Stylus CX6600 All-In-One InkJet...
Canon I990 InkJet Photo Printer Logo
221 people viewed this question
old marine
old marine
