Home | Keurig | B60 Coffee Maker | My machine only bre...
Keurig B60 Coffee Maker
Problem for Keurig B60 Coffee Maker
My machine only brews 1/2 cup of coffee. I have
By sdebay on Aug 15, 2009
My machine only brews 1/2 cup of coffee. I have de-scaled twice within the last week and I get a full cup of vinegar/water, but as soon as I put in a K-cup I only get 1/2 cup of coffee out. The first cup after decaling may be 2/3 cup, but after that the amount of coffee diminishes. This morning when I put in the K-cup the machine made the noise, but nothing came out. I raised and lowered the area where you put the k=cup again and then it brewed the 1/2 cup. I have had my machine for a year..
Best Solution
posted on Nov 10, 2009
Very Helpful)
maloyjk
Rank: Master
Rating: 100%, 3 votes
The needle at the bottom of the K Cup receptacle is hollow, the brewed coffee flows through it to reach the cup. I'm sure your problem is a blocked needle. Remove the K cup holder and **** the needle out with a paper clip, that should fix you right.
See how I fixed my Keurig B30 at:
http://appliancehalfwayhouse.blogspot.com/2009/11/keurig-b30-mini-brewing-system.html
Was this helpful?
Yes
No
1 person thought this was helpful
Solution #2
posted on Sep 30, 2009
Very Helpful)
sentient46
Rank: Apprentice
Rating: 100%, 4 votes
I had some coffee grounds stuck up in the cone shaped hole that the water comes from at the top. I had to use a very long toothpick but it broke up some of the grounds that happened to get caught up inside. Before doing this, I went through 24 oz of vinager ;) .. the toothpick worked!
Was this helpful?
Yes
No
4 people thought this was helpful
Solution #3
posted on Aug 20, 2009
Somewhat Helpful)
HIRAM517
Rank: Wiz
Rating: 78%, 22 votes
REPROGRAM UR SETTING FOR THE EXACT AMOUNT OF CUP, TRIED THAT ALEAST BE GOING TECH
Was this helpful?
Yes
No
Popular Solutions for Keurig B60 Coffee Maker
Questions and Unsolved Problems for Keurig B60 Coffee Maker
Do you recommend Keurig B60 Coffee Maker?
Answer
Answer
I use 2 Keurig B40's for my display and I need to replace my broken water compartments... please... (More)
Answer
1 yr old b60 model all of a sudden will not brew after it has drawn extra water from the resevoir... (More)
Answer
the information center says "not ready" no matter what I do
Answer
just bout keurig single serve, it made one cup now it won't make another one
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Keurig B60 Coffee Maker:
Top Coffee and Esp... Experts
Rank: Guru Guru
Solutions: 890
Experience: im the jack of all trades but a master of none! and being an old git you get to learn a fuw tricks
Ask Me
Find more Coffee and Esp... Experts
Top Small Appliance Repair
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
