Question about HP Color LaserJet 2600n Printer
Shadows on prints
The printer leaves a shadow from text/graphics repeatedly down each page. Each page has a faded "copy" of the above text repeated down the page. I have tried to use the utility cleaner many times but it does not help. The problems occurs less, the more the printer is used throughout the day. Replacing the toner does not solve the problem either. How can I stop this?
  • 6 more comments
  • bwhitty Dec 04, 2007
    How do I fix or replace the Fuser from the HP 2600N?
  • bwhitty Dec 05, 2007
    I have experience with electronic repairs, including laptop repairs, but have never attempted a printer. I do not think it will be overwhelming if I have an idea of what I'm looking for and how to get to it, as well as the tools required. Also, can the fuser be fixed, or do I have to buy a new one, and if so, where do I obtain a new one?
  • J Milanette Dec 18, 2007
    Definite ghosting on all pages of documents - especially on color documents. Changed out the black toner cartridge - no change. Wiped down the transfer belt - some improvement, but not much. Any other ideas?
  • erikv Dec 18, 2007
    I have similar issues...ghost printing...how can I replace the fuse?
  • DebLK Jan 03, 2008
    Also have the same problem - what do I do?
  • pickstick Jan 23, 2008
    I also have the same problem.....could someone help me with this please!?!
  • Anonymous Mar 14, 2014
    Hi, our printer is leaving a faint shadow on each page?
  • Anonymous Mar 24, 2014
    toner refilling
  • 56 Answers
Hi, The problem your having sounds like a Fuser . The Fuser will cause printed text to give a ghosting look down the page were it repeats itself.
Posted on Dec 03, 2007
  • WILLIAM MONDY
    WILLIAM MONDY Dec 04, 2007
    Ok well first off have you ever done any maintenance or repairs on a printer? I will be more than happy to walk you thru the steps but I just don't want you to be overwhelmed by replacing the part?
Faded print
using the D-pad on your printer, scroll down the menu until you get to "maintenance"
Press OK
Scroll down to "clean printhead"
press OK
The printer will now make some noises and after about 30 seconds will say complete.
Now scroll down once more to "Print test page"
press OK
load paper and press the start button
Iff the printed page looks ok...job done. If still faint, repeat the above steps once more.
Nov 18, 2013 | Kodak ESP5250 All-In-One InkJet Printer
How do I get rid of shadows on my printing from my HP Photosmart C3180 printer? There is an extra shadow behind EVERY single piece of text. It makes the whole page look blurry. It isn't as if t
I have a Canon printer. Whenever pictures or text gets a double or blurry image I open the printer solutions menu. It sounds as though there is a problem with inkjet alignment. By clicking the realignment button the printer will automatically realign the jets. I usually test the alignment by printing a page from that program. All the line segments should line up.
Jan 01, 2013 | HP Photosmart C3180 All-In-One InkJet...
Hp LaserJet 1012- prints shadows and repeats text/ figures...
just clean and calibrate your printer be sure your head cardrige is aalso clean and or new.
May 26, 2009 | HP LaserJet 1012 Printer
Printer output has shadows, blurring, streaks, lines, poor color
Seem like blocked hole(s) on the color print head...
Most likely if there is a deep clean option then do it (may need a few times to unblock a hole or never).
Also get the printer physically cleaned up if you can see dusts inside (vrtical lines on color bars).
Mar 20, 2009 | HP DeskJet 9800 InkJet Printer
MINOLTA QMS magicolor 3100 printer, repeat shadowing
Рthe rechagin corona in imije unit is demeged change it
Mar 12, 2009 | Office Equipment & Supplies
Dell 5110cn Printer Printing Blue Shadows
I did the following and it has stopped printing "shadows". I don't know if it was one solution or the other (or both) that worked.
1.On the face of the printer press the "Menu" button>Admin Menu>Maintrnance>Color Reg Adj>
Auto Correct>Yes
2. "Menu" button>Admin Menu>Maintrnance>Clean Developer>(Pick problem color)>Yes.
Hope it helps
Aug 16, 2008 | Dell 5110cn Laser Printer
My copies and prints are blurred with shadows
That was the Solution that the ink cartridge required a replacement
Aug 13, 2008 | HP OfficeJet 7310 All-In-One InkJet...
Shadows on prints
The comment from Kasmodan2 is true it can the toner cartridge, but is most cases it is the fuser. I repair HP laserjet machines day in and day out to replace the fuser is easy.
  1. Turn power off
  2. Open cover at right hand side rear
  3. Remove data cable
  4. Open top cover remove toner cartridge and press button on right hand side and slide the right hand cover off
  5. Open the back cover and lower the door all the way down
  6. Remove the two silver screws
  7. Take out the paper tray as this will be easier to remove the back cover
  8. Pull the back cover from the bottom and should unclip be careful not to break this cover.
  9. Once open then you will see the fuser unit unplug the connections and remove the screws then slide out the fuser unit
  10. Refit the new fuser unit plug in all the connections and reverse the above process
  11. Turn machine on and test if all good the machine will work fantastic if there is a constant red light repeat above and check connections if still red light then the new fuser faulty and not heating up.
Hope this helps all of you
Thanks J
Dec 04, 2007 | HP LaserJet 2100 Printer
Text "ghosts" or shadows
Replace Drum or blade(if possible) will fix on most types of copiers/printers, or rarer it is cause of fuser.
Oct 19, 2007 | Ricoh Aficio 1013F Copier
HP Color LaserJet 2600n Printer Logo
1,018 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
