SE shows on the display
Hi, i have a wesinghouse mastermind 708 7kg capacity. as soon as i turn it on, the water fills up and then it stops & shows SE on its display. what's SE?
    Brigadier General:
  • 4,090 Answers
Water Sensor Error. You need to have this changed as it has failed
Posted on Aug 15, 2009
Testimonial: "thanks for ur feed back, the water line had rust in it and had blocked system the flow of cold water :) prob fixed thanks..... "
  • nailsbyrosal
    nailsbyrosal Sep 08, 2012
    Hi how did you fixed it? I;m struggle with my machine. Keep SE blinking...so annoyed
SOURCE:
Lg top load washer keeps filling and has to be manually stopped but it will drain when put on the spin cycle.
HI,
From your description, it sounds like there may be a problem with the inlet water solenoid valve(s). They can stick after several years of use. The se valves are located in the machine, just inside where you connect the water hoses.
Jul 25, 2015 | LG Washing Machines
When turning on dishwasher it just fills the base with water, tried manually draining and pressing reset buttons to no avail
Most dishwashers kick on a valve to fill with water.
There's a float in there somewhere that triggers the shut off to the filling water.
Once water reaches this cut off level the pump should be throwing water thru the wash arms.
If base isn't filling to capacity...Id look to the drain valve.
If it fills to capacity and stops...the pump may be out or something is obstructing it.
Hope this helps...
Jul 30, 2011 | Neff 24 in. S5453X1 Built-in Dishwasher
I have a Westinghouse Mastermind 711 Front Loader Washing Machine which is flashing OE and the clothes inside are very wet. Can you please let me know what this flashing OE means....Many Thanks, ELena
Hello & Welcome to FixYa
OE is a drain error and is displayed when the washer is unable to drain water. Please check the drain hose and drain pump filter for any clogs to clean the error. Please get back to me if you have any other questions.
Kevin
May 27, 2011 | Westinghouse Washing Machines
Miele W1926 check inlet light flashes at the end of rinse fill. When the fill ends, the light goes off. I cleaned all 4 filters at the intake hoses. The problem still exists. What does it mean?
Hi dear.It sounds like you'll need to change water inlet valve very soon.Because,machine waiting water level to be reach,in specific time frame in chosen program parameters to be get completed.If that does not happen,then it starts giving fault indication.Indication stops after fill,because task been competed & computer disregards the fault.If that won't happen then machine going to get stop completely & indication will carry on.Chage the water inlet valve if you can.I hope that helps. Thanks.
Jul 25, 2010 | Miele W1903A Front Load Washer
Need to know fuel tank capacity and tire sizes please
The fuel capacity should be six us gallons. Sorry I can't help on the tire size.
May 05, 2009 | 1996 Yamaha Royal Star XVZ 1300 A
My washer machine is filling up with water but will not stop
hi..the problem may be due to two reasons.
one is your washing machine will not be fully
automatic,it may be semi-automatic.In that case
the water will not stop automatically after reaching
its capacity.other problem may be there will be some
short in the wire in an fully automatic machine which
could have lead to this problem.
check it out.
thank u.. rate me..
Feb 05, 2009 | Frigidaire FWS833A Top Load Washer
I have a 4 year old Maytag Performa washing machine. Regardless
Hi!!! You seem to have a bad water level switch..If you turn on the water and water just fills in and doesn't stop then you have a bad water level switch..If you just turn it on and water enters then you have a bad water valve..Good luck..
Jan 03, 2009 | Maytag Washing Machines
I have a mastermind 708 7kg front loader and SE is flashing and maching won't work can you help please
Ihave a mastermind 708 7kg front loader and the SE is flashing and machine wont work can you help please? Thankyou
Aug 03, 2008 | Washing Machines
Water Just Keeps Filling!
replace the water inlet valve, the valve that the black hat and cold lines connect to
Apr 19, 2008 | Kenmore 3.5 cu. ft. King Size Capacity Top...
Washing Machines Logo
291 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
Marvin
Marvin
