Question about OEM Systems Car Audio & Video
I Need the toyota 58806 head unit pinouts so i can connect my mp3 or install blue tooth adaptor can any one help
SOURCE: RJ11 pinout info needed
hth.......
Posted on Dec 31, 2007
SOURCE: Conecting Blue tooth phone to acer laptop
Visit this link to download the bluetooth driver http://support.acer-euro.com/drivers/notebook/as_5630.html
Posted on Jan 06, 2008
SOURCE: Bluetooth problem
I have an lg sprint muziq and I cant get my blue tooth headset connected. The phone can't read or see the blue tooth head set
Posted on Jul 04, 2008
  • 287 Answers
SOURCE: i need instructions how to connect my h350 blue tooth to my lg cu400 cell phone
With the headset power off, press and hold
the Call button for 6 to 10 seconds until the
blue indicator light turns on and remains
steadily lit.
Note: The blue light will flash as you press and hold the Call
button. Continue holding down the Call button until the blue
light is steadily lit.
Note: If you let go of the Call button before the blue light is
on and steady, ensure that your headset is off before trying
again.
The default PIN or passkey is 0000 (4 zeros)
You need to enable bluetooth on the phone and go into pairing mode, search for devices or similar
HIH
Posted on Jul 12, 2008
SOURCE: Acer veriton 7100 front panel audio pinouts
gfexcel  vga drive
Posted on Jun 26, 2009
Alpine firmware update
Can't be compatible, because the plug is the 30 pol. not the lightening plug.
First make sure the cable is compatible, then check if you Alpine can work with it.
Doesn't have the Alpine blue tooth already?
Jul 17, 2014 | Alpine Bnib - Cde-111r Cd/mp3/usb Tuner
How do i take out my radio from my toyota corrola
The Toyota Corolla has been around long enough that many owners find themselves needing to replace the factory stereo. Installing a new stereo in the Toyota Corolla gives improved sound and updated features. Swapping out the stereo in the Toyota Corolla takes basic tools and less than an hour. This article covers models from 1990 to 2000.
Open the hood and remove the negative battery cable from the terminal. Apply the parking brake and place the car in "D."
    > Remove the trim from around the stereo by prying with your fingers at one corner. Some early models have two screws at the top of the trim piece to remove first. Allow the trim to hang on the drivers side of the dash if it's connected to the cigarette lighter.
    > Locate and remove the four screws holding the stereo in place. Pull the radio out of the dash and disconnect the wires from the back of the head unit.
    To install
    > Connect the wiring harness adaptor to the original harness and let it hang from the dash. Slide the new stereo into the Toyota radio mounting kit, which is a thin metal cover and secure it per the manufacturer's instructions. Most adaptors have screws to hold the stereo in place, however some have clips, which engage automatically.
    >Plug the wiring harness adaptor and antenna wire into the back of the new head unit and push the entire assembly into the dash. Reconnect the negative battery cable and turn the radio on.
    > Ensure all of the stereo controls and speakers are working. Secure the radio in the dash with the original four screws and replace the trim.
Dec 05, 2010 | 1990 Toyota Corolla
How to pair Motorolla 550
Please allow me to help you with you Blue tooth head set.
Step 1
First power on the headset you do this by sliding the call button towards the microphone.
After a few moments, the indicator meaning the "light" will be steadily lit in blue to indicate the headset is good to go in pairing mode.
Step 2
1. On your phone press the menu button then locate connection or device "phones are diffrent" at this point you need to turn on the blue tooth on your phone.
2. The phone should find the Motorola H550
3. Select OK or YES to pair you headset with your phone.
4. Enter the pass key: 0000
5. Press ok
Hint: Once the phone is paired with the headset the indicator will flash blue.
Now if the unit does not pair then you might be using another unit with this phone so please make sure you disconnect all blue tooth units and try the steps again.
If you have any questions WE can help please get back with me.
Thanks for using Fixya.com "We have a solutions for everything"
I hope this solution was VERY HELPFUL!
Have a Great day
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
Oct 29, 2010 | Motorola Mobility H550 - Bluetooth Headset...
Hi, my problem is with my nokia bh-214 headset.. when i try to connect it asks for a passcode.. i didnt get on with the unit and have tried the recomended codes like 0000, 1111, 9999, 1234, none of...
when you are pairing the head set and phone make sure the blue light is flashing on the head set witch the blue tooth put the blue tooth on the phone when asked put 0000 they should pair
the head set has to be charged to us it
Sep 07, 2010 | Nokia BH-214 Bluetooth Stereo Headset
Any idea how to turn the bluetooth on on a sony
No code should be nessicary but you due need to make sure your have the actual blue tooth adaptor for the sony unit itslef its says blue tooth ready but you have to purchase the adaptor for it
Mar 05, 2010 | Car Audio & Video
My wireless adaptor isn't working. I have an Acer travel mate5720 which has a switch on the front for blue tooth & wireless access. Bluetooth works ok but the Wireless adaptor won't i have checked in...
This model does have wireless. I had a similar problem a little while ago, I plugged the unit in to a wired connection, and on it's own, disabled the wireless adapter.
Go to start--> control panel--system-->hardware-->device manager
look under the "network adapters", there should be a wireless adapter or 802g something something, right click on this item and click "enable".
You should then be able to browse for wireless networks now.
Jan 06, 2010 | Acer TravelMate 5720-6635 Notebook
Need bluethooth for sony vaio vgn-n365e laptop
WHen you say blue tooth do you mean you want to hook it up to your home wireless network? if so you can buy a USB blue tooth adaptor to run on your computer. IF it does not have a USB slot you willl have to buy a rs232 port with usb adaptor or blue tooth adaptor. There is a difference between a blue tooth that you hook up at your home and a blue tooth that you can connect anywhere on line, for instance verizon wireless has a large area to use a blue tooth connection to the net but it costs you money. With the verizon plan you can use te net anywhere you can get a signal just like a cell phone. the blue tooth will allow you to connect to unlocked services for instances many hotels and cafes have wireless acess for free all you do is connect it up. If you need more help let me know and I will be glad to tell you where you can buy it and how much it costs.
Nov 20, 2009 | Ovens
Bluetooth problem
Jul 01, 2008 | Motorola Mobility HS850 Consumer Headset
Car Audio & Video Logo
369 people viewed this question
Top OEM Systems Car Audio & Video Experts
xxxxxx xxx
Marvin
Marvin
Are you an OEM Systems Car Audio and Video Expert? Answer questions, earn points and help others
