Question about Samsung HLN617W 61" Rear Projection HDTV
2 year old Samsung 50" DLP
The srcreen freezes...goes blank. takes about 5 seconds...then goes back to normal. The sound also gets cut off as well during this "reset" Time. the screen freezing happens every 10 minutes...sometimes less. I am using HDMI input for Direct TV. When I change inputs (component video) i get a snowy green screen.
If I unplug the TV, it will work fine...no freezing screen or green snow but that will only last about an hour.
    President:
  • 1,284 Answers
Sounds like a bad digital board to me. Not too hard to replace in those models but, you do have to write down a few settings before replacing it. These settings are available in the service menu. Any questions let me know [email protected]
Posted on Dec 01, 2007
SOURCE:
My Samsung dlp hlr5667wx/xxa has a signal intermittent problem through antenna connection and hdmi connection. what could this be? the light bulb and color wheel has been replaced 6 months ago. the...
Bad smd capacitors on the digital board. There are many and unlike regular capacitors are small and hard to replace. May just want to get a whole new digital board. Try Encompas parts.
Nov 04, 2011 | Samsung DLP HL-P5663W 56" TV
We have a Samsung DLP about 5 years old. We noticed that the fan or some sort of hummning sound was coming from the back louder than normal while TV is on. Then suddenly the picture would start to freeze...
This tv have a colors wheel,hear loud motor noises,humming noises,squiling or grinding noises,have pictures black and white.All these causes are by the colors wheel is worn out, warp rubbing against it motor or fiber plastic glass briddle about to brake aparts.Don't turn this tv on anymore until,u change the colors wheel or u will damage the projection engine.The colors wheel are hard to change for amatur and hobiest.Because involved taking out many machanical parts,before even can come to the colors wheel to take out and change it.The best course to to hire a Tv Tech.to do this job.The price colors wheel part and labors.Awhile back was about $500-550,now??
Sep 10, 2010 | Samsung DLP HL-P5663W 56" TV
I have an HLR5057WAX DLP Samsung tv and my picture freezes often and the tv will sometimes power off. When it freezes it will stay that way for about a minute and usually turn back to normal. Lately I have...
The lamp is usually your first replacement, but a freeze in picture may have to do with the video board or the DMD board. Try the lamp first and see if that fixes it--because you'll need a new one anyway if you're going to keep the television. Make sure to get an OEM Philips lamp for your Sammy. Buy from an authorized distributor.
Feb 04, 2010 | Samsung HLR5067WX 50" Rear Projection HDTV
Screen goes blank for seconds
bad connection, soldering goes old .using soldering iron, locate bad connection and redo them agin
Sep 14, 2009 | Samsung DLP HL-P5663W 56" TV
Samsung DLP HL-R6167W - works fine for about 5 seconds then the screen freezes, sound goes out and then goes black then comes back on by itself and repeats the whole process. No blinking error lights.
There are three possible parts causing the problem. First, the Main or Digital bd is bad, Second, the DMD bd is bad. Third the Color Wheel is bad. You need a trained Samsung tech to have a look at it.
Jul 12, 2009 | Samsung HL-R6167W 61" HDTV
Rca 50 dlp hd50lpw175
Yes but did you find a fuse open and changed it?
Jan 08, 2008 | Televison & Video
Samsung HLN617W 61" Rear Projection HDTV Logo
146 people viewed this question
Jerry Greenberg
Jerry Greenberg
Ekse
