Home | Sennheiser | PXC 250 Consumer Headphones | PXC250 headphone cab...
Sennheiser PXC 250 Consumer Headphones
Problem for Sennheiser PXC 250 Consumer Headphones
PXC250 headphone cable ripped out from electronics box
By jmagee99 on Aug 15, 2009
I would like to repair the unit but I've got six wires & two screens with no idea where they terminate within the unit. Harold Dale has posted info on a similar repair (how to repair the jack lead) and says it would be much more difficult to repair the headset cable. I want to give it a go rather than ditching the unit but can't without wiring info. Can anyone help?
Best Solution
posted on Aug 20, 2009
Very Helpful)
mgueffroy
Rank: Guru
Rating: 91%, 204 votes
Usually red is right and green is left leaving copper as ground. All manufacturers have their own color scheme so another way to do it is obtain some alligator test leads. You will need 3 in this case. Clip the clips to the replacement plug ( the leads come in different colors if you need to avoid confusion ) Then clip the other ends of the leads to the head phone wiring connections. The wiring usually goes into the left headphone first from the plug and is soldered to a pad. From the pad there will be wires that go through the headband to the right headphone. By comparing the colors of the wires you should be able to trace them. Whatever colors go to the right headphone will be right signal and ground. The remaining wires will be left signal and ground. The ground wire will be common to both left and right headphones. I mentioned the test leads so that you can plug the replacement plug into a stereo signal source such as a headphone out on your stereo amp and using a low volume setting, try different combinations until you get the right one. You can pan the signal left and right on the amp. This is in case you don't have a volt ohm meter. The meter makes the tracing a lot easier. There is a video here that also might help:http://www.metacafe.com/watch/1045725/how_to_solder_how_to_repair_headphones/ Let me know how you make out. It all sounds complicated but the worse you can do is wire your phones out of phase. Unless you are using high volumes to test them you shouldn't hurt them otherwise.
Was this helpful?
Yes
No
1 person thought this was helpful
Popular Solutions for Sennheiser PXC 250 Consumer
Questions and Unsolved Problems for Sennheiser PXC 250 Consumer
Do you recommend Sennheiser PXC 250 Consumer Headphones?
Answer
Answer
power light comes on but noise cancellation does not work.
Answer
Hi, I have a problem with the noise canceler; when I turn on the noisegard it has static and a... (More)
Answer
Purchased from Amazon.com in Jan. 08, These have been great, except Monday they broke. The switch to... (More)
Answer
I have SHP 8900 Headphones. I managed to break the 3.5 jack end of the cable so i was wondering how... (More)
Answer
Buzzing appears in one head piece after 15minutes of use. Does not appear when first used
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Sennheiser PXC 250 Consumer...:
Top Headphone Experts
Rank: Guru Guru
Solutions: 689
Experience: 30 Years of professional repair and design.
Ask Me
Find more Headphone Experts
Top Audio & Video Equ... Repair
(888) 737-1752
XBOX360 & PS3 REPAIR EXPERT SERVICE We can...
xbox360 fixer
(888) 399-5512
EverGreen Electronics is the ONLY Apple iPod and...
Apple iPod Service
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
