Sharp INKJET FAX UX-A1000 Logo
Posted on Nov 30, 2007
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Ux-a1000 how do i set destintive ring tone for my fax machine
Soulvisitor
Level 3:
  • Sharp Master 1,113 Answers
  • Posted on Dec 01, 2007
Soulvisitor
Sharp Master
Level 3:
Answers
1113
Questions
0
Helped
929902
Points
3125
Here is your user manual LINK
No ring tone. Can't make or recive a phone call
check the cable has been put in the line socket on the fax and not the tel socket as this is a common mistake and that will stop you getting the ring tone]
SHARP UX-A1000 - sends all BLACK page (to all
Noisy line? is all that strikes true when you ensure me it makes great photocopys, but then you receive OK, very strange, All the mechanisms for doing a local copy is the same as sending a fax the difference is the conversion to phone noise so it has to be electronic, I;d guess lightning/power surge, cant think of much else....sorry
1helpful
Sharp ux a1000. I need to clear the memory. Can
Just unplug the machine.
When the power supply is interrupted (intentionally or due to power failure) the memory is cleared.
Download the manual from here:
http://www.sharpusa.com/files/fax_man_UXA1000.pdf
Cannot Dial Out
Is the phone line plugged into the LINE port?
1helpful
2answers
Cannot answer a incoming call
Make sure that if you DO NOT subscribe to DISTINCTIVE RING that it is set to the OFF SETTING! had to figure this out on my own!
Sharp UX-A1000 Fax Machine Document Feeding Trouble
Problem is most likely caused by a worn paper pick roller. It would be more expensive to repair this fax than to just replace it.
Sharp Fax machine - UX-B700
Try this:
Set the fax machine to AUTO reception. Next, you would want to set the proper settings in your Option Set List. To print a list press the FUNCTION key, the number 2 key, then press the # key until it reads OPTION SET LIST in the LCD screen and press the START key. This will print your list. The following settings should be seen: Number of Rings 1 to 4 rings (setting #2) Dial Mode- TONE (setting #8) TAD Connected- OFF (setting #9) * Quiet Detect Time- 04 seconds (setting #10) * Distinctive Ringing- OFF (setting #12) **
Let us know if this doesn''t fix it... we can go from there!
Maggie B
Sharp Ux A1000
On the bottom there will be a tiny hole which might say reset Press it with a pen or somthing sharp/pointy
Or ring (02) 4321 0080* and they will give you an answer free!
*May Be STD call
Top Sharp Office Equipment & Supplies Experts
k24674
ZJ Limited
ZJ Limited
Norman Weimar
Norman Weimar
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
