Question about Sony KP-51HW40 51" Rear Projection Television
Red screen I have had this model for one year now and worked just fine. about 3 months ago I noticed red horizontal lines that became more and more apparent. Now the screen will turn completely red after 1 minute. When I shut it off, for a few minutes, it comes back normal and within a minute again (or shorter) goes back to red. If the TV has been off for a few hours, we get about 10 minutes of normal viewing before it turns completely red again. I am not sure what to do now.
  • ggautier Dec 02, 2007
    Actually the answer was already posted and I did not realize it. I opened the front like instructed and played with the 3 knobs at the front bottom of the tv to adjust the convergence. I was able to fix the problem in less than 15 minutes. I started having the problem because my kids kept running into the tv with their bicycles. The tv actually gives me a clearer picture than I had in years now. Thanks anyway
    Problem Solver:
  • 17 Answers
sounds like a picture tube problem its a problem that probably cant be fixed only by a professional
Posted on Nov 30, 2007
Led tv showing horizontal red lines
Horizontal lines syptom is always related to its LED back-light section. Check and repair it first; if you can. Contact any service technician. In most cases, this fault might be of its display panel itself, because, most models of the Samsung TVs, the T'Con and LED drive system circuit are built in part of the display panel. If so; the repair will be almost impossible. Replacing the display panel will be the only remedy. As you know, it will be best to buy a new Tv; instead of replacing the Display Panel of any LCD TVs; as the cost of the panel + repair charge will come around 80% price of a new Tv. Check and confirm the fault is with its Display Panel. If yes; get rid of it. The decision is yours.
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Line, faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault to an extent.
Dec 02, 2015 | Samsung Televison & Video
All screen is red
IF THE SCREEN IS ALL RED WITH VIDEO VISIBLE AND RETRACE LINES. ADJUST SCREEN CONTROL IN THE FRONT FOR THE RED TUBE ONLY. TURN CONTROL COUNTER CLOCKWISE. IF THAT DOESNT DO IT THE TUBE CAN BE REJUVINATED.
Nov 19, 2008 | Samsung HCL4715W 47" Rear Projection...
Diagonal white lines...
Thats the first stages of the 3 red lights ,the white lines are vertical sheering caused by the vga chip.Microsoft now give 3 years warrenty for the 3 red light error plus if you have only just had it back from Microsoft then it will have deffo got a year on it anyway.
Jun 08, 2008 | Microsoft Xbox 360 Console
Toshiba 51h85c rear projection screen is red!!
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Jan 14, 2008 | Toshiba 51H84 51" Rear Projection...
Red lines on screen
REPLACE THE CONVERGANCE IC"S.STK392
Dec 23, 2007 | JVC AV-48WP30 48" Rear Projection...
Red lines, green lines, now static!
Uneven colors with multicolored lines in the center of the picture and/or flashing, C9A37 and C9A38 both 3300 UFD 10 V part # 181P732040 on the Power PCB (part # 930B921002)
Nov 27, 2007 | Mitsubishi WD-52525 52" Rear Projection...
Samsung 42" HCM4216W Dim Horizontal line across screen
THIS HAS NOTHING TO DO WITH CONVERGENCE or any of the stk integrated circuits.There are few capacitors close to the vertical output ic, they are usually blue or red (could be 1000uf 50volts for e.g.)That where the problem is
Nov 03, 2007 | Samsung HCM4216W 42" Rear Projection...
KV-32XBR250 Has about twenty Horizontal, Light Red bars aternating
your problem is called retrace lines it is due to 1 supply to red out put is absent 2 problem in red video output 3 loose contact in red output ckt 4 connector loose 5 crt base loose 6 circuit from red output of chroma ic to red video input 7 chroma ic defective regards
Sep 11, 2007 | Sony KV-32XBR250 TV
32 in RCA MODEL NUMBER f32650
TV FINE UNTIL 2 NIGHTS AGO HAVE HAD 4 YEARS, STARTED HAVING A FOGGY SCREEN WITH WHITE HORIZONTAL LINES. HAS SOUND A FOGGY SCREEN WITH WHITE HORIZONTAL LINES. called retrace lines please check 1 screen control on eht transformer is mituned 2 supply to screen of crt 3 supply to rgb video output is absent 4 connector loose 5 crt base loose thanks
Sep 11, 2007 | RCA F32650 32" TV
Green Lines Horizontally
yeppers its a g2 control on the flyback thats gone or drifted out of alighnment or the flyback its self.Try turning the g2 control dowm till those lines fade. If they wont go away then you need someone to check the Picture tube or its componets driving the crt.
Mar 26, 2006 | GE 31GT740 31" TV
Sony KP-51HW40 51" Rear Projection Television Logo
145 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
