Wont continue after "restart the computer" even after countless attempts restarting the system.
This time after you uninstall the norton antivirus, it's been corrupted your VGA Drivers & etc., I don't know what else have been corrupted after you uninstall.
All you have to do is restore the system or system restore.
If you enter at Windows Safe Mode the restore using checkpoints on your system.
If not then reformat you windows.
Here are the tips on how to use system restore.
Using System Restore
To start System Restore, click Start, Programs, Accessories, System Tools,
System Restore. You'll see options allowing you to create restore points and
restore your computer to a previous time. If you've already performed a
restoration, you'll see a third option to undo the last restoration.
To create a restore point:
To restore your computer:
If you find you need to undo a restoration:
Hope this will you and good luck!
If i am helpful please rate me.
Thank you.
Yboyandrei
Test your PSU or replace it if your power supply units fan is not working your PSU is faulty
One bad lead can cause a computer to continue on a cycle or to shutdown or fail to detect/ boot up a computer hard drive
Test all leads that attach to your hard drive including electrical extensions,IDE,SATA
the leads from your ((motherboard to your hard drive)) make sure they have a secure connection and are not faulty or just replace them they could be faulty
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty even the electrical extensions or just replace them they could be faulty a computer needs its connections to continue its cycle and have an end so any faulty leads will end up with a computer error if this fails to fix the problem
another possible reason could be a memory dump you might be running to many programs at the one time placing to much strain on the CPU also you might not have enough RAM random access memory to check what is running when your computer is running scroll to the bottom toolbar right click select task manager applications and processes if you see something you dont need running select end now to check how much ram you have click start right click on my computer select properties you will see all of your computers details another way to check how much RAM you have click start all programs accessories system tools system imformation all of your computers imformation will be there try uninstalling a few unnecessary programs then click start run type cmd then type chkdsk/r/f which will scan for and attempt to fix any bad sectors and automatically fix any corrupt files on your hard drive this will schedule on a restart don
the leads from your ((motherboard to your hard drive)) make sure they have a secure connection and are not faulty or just replace them there probably old and faulty
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty even the electrical extensions or just replace them they are probably old and faulty a computer needs its connections to continue its cycle and have an end so any faulty leads will end up with a computer error
hope this helps
After following the instructions given, it eventually directs me to the point where i must restart the computer to continue. However, even after restarting it continues to give me the same instructions to restart.
before it prompts me to restart, a pop up comes up and says that the set-up is initializing. once that is done, it then says that norton antivirus is uninstalling another version of norton found on the computer. then finally, it prompts me to restart.
before the PC restart what do you do on your system?
Not sure why you posted this under norton anti virus. This will be a dificult problem to solve. You will need to provide quite a bit of detailed bit of information because there are many reasons this can happen. At what point does it get stuck during the boot process?
