Question about Oreck XL2600 Vacuum
Oreck XL My Oreck just turned off in the middle of vacuuming and I smelled a burning smell. I am thinking that if I can take it apart and remove whatever turned it off, it will run again.
  • Enrica Nov 30, 2007
    I took it apart, and the belt is intact. I put it back together again and it turns on but the belt is not moving.
  • Anonymous Mar 15, 2014
    my oreck xl vaccum will not turn on anymore
    Problem Solver:
  • 9 Answers
Your roller brush is probably bound with hair and is not able to move
Posted on Dec 06, 2007
SOURCE:
Oreck vacuum cleaner stop and burn smell
sounds like hair or string or something like that is wrapped around the beater bar(the long brush under the head that brushes the carpet) keeping it from turning. The belt that drives the bar is getting hot because the beater bar is stuck.
Aug 12, 2014 | Oreck Vacuums
Just replaced the roller on my oreck XL, and it is smelling like burnt rubber
If the roller bearings are starting to seize the the belt may be slipping
I’m happy to assist further over the phone at https://www.6ya.com/expert/howard_977676954994c5b2
Oct 25, 2012 | Oreck XL Ultra Bagged Upright Vacuum
When its in use there is a burning odor
If it is a rubber smell, the belt is slipping and should be repalced. If the smell is a sharp electrical burning odor, the motor brushes are sparking and the motor may be damaged.
Jan 22, 2011 | Oreck XL Ultra Bagged Upright Vacuum
My Oreck XL 9100HA started smoking (white smoke) when I vacuumed. There is a burning rubber smell. How do I check/change (if appropriate) the belt? I have no User manual, nor can I locate one on the Oreck...
It sounds like the belt has been damaged. You can get another belt from yoru local Oreck store. You can even take it in to the store to show them what happened. Purchase another belt and replace it. (It was very easy when I did this, so hopefully the belt is all you'll need too.)
Best of luck!
Apr 18, 2010 | Oreck XL Ultra Bagged Upright Vacuum
Oreck XL intellashield smells hot and smoky when operating. New bag and belt and no clogs. About a year old.
If it smells like burning rubber with white smoke its the belt make sure the brush spins freely. If its a electrical burning it will smell real bad you WILL be able to tell which then its a motor issue you can remove the bottom plate 5 phillips head screws opposite the motor youll see 1 screw remove it pry the duct out and look to see if there's anything stuck in the fan if not its the motor its self
Dec 17, 2009 | Oreck XL Ultra Bagged Upright Vacuum
My oreck XL7 smells when it's on. Smells as if it's the motor. Had the Oreck for 4 years but hardly used it?
The smell is probably from the belt. When they are worn and stretched they can start to smell. You can get replacement belts for your model here:
Oreck XL7 Replacement Belts
Nov 10, 2009 | Oreck XL Ultra Bagged Upright Vacuum
My Oreck Vacuum cleaner keeps burning up belts. I
I am having the same trouble. I bought the vacuum new in October 2007 when my wife and I purchased a newly constructed home. Since it is only two of us, she only has to vacuum once a month. I have taken it in three different times and get the same story. It needed a new belt. Mine has white smoke coming out of it and smells like burning rubber. I contacted Oreck and got no results. They refused to let me discuss this with Dave Oreck, stating that he nevers talks with customers! Gary Neeble
Jun 05, 2009 | Oreck XL2000 Bagged Upright Vacuum
I put a new belt on my oreck xl and it is burning through why?
The problem you are having is that the brush roller is not spinning freely when the belt is not on. if the end caps of the roller can be removed, clean the dirt & carpet fiber out and test. if it can not you just may need to replace the roller
I’m happy to assist further over the phone at https://www.6ya.com/expert/robert_b96ba3f038cf317c
Feb 01, 2009 | Oreck XL2600 Vacuum
Burning smell
I had burning smell and some visible smoke which I tracked down to the handle area. The mains socket at the bottom of the handle had burned out. When I pulled the plug out I noticed that the prongs were blackened and scorched. I will replace the socket.
Nov 02, 2008 | Oreck XL Ultra Bagged Upright Vacuum
Oreck XL2600 Vacuum Logo
315 people viewed this question
Top Oreck Vacuums Experts
Gerry Harvey
Gerry Harvey
john h
Are you an Oreck Vacuum Expert? Answer questions, earn points and help others
