Question about Sony FD Trinitron WEGA KD-36FS130 36" TV
Sony Trinitron KV35V36 Glass Chip
My one year old threw a rock at our T.V. screen, causing 3 small "nicks" in the outer surface of the glass. These nicks create a small dark spot in the picture when the set is turned on. Any ideas on how to fix the Chip?
    Scholar:
    New Friend:
  • 67 Answers
Fill in the spot with clear epoxy from radio shack. Place shipping tape over the epoxy and turn the screen up if possible to make the repair flat. Wipe off any excess epoxy as the tape is applied. The break refracts the light from the screen away from you and makes it appear dark. Remove the tape after the epoxy sets. Do not open the unit up. The aquadag can hold high voltage for up to a month. There should be no danger of breaking the crt itself if you're careful. Over time, recycling the power on and off may make any cracks propagate but if there are none now it should be ok.
Posted on Nov 30, 2007
    Problem Solver:
  • 17 Answers
Your best bet if you dont have a warranty on the tv is to get it repaired shouldnt be more then 150.00 you dont want the risk of having to fix something else if you get into the tv.
What would cause the glass tray in the microwave to shatter
  • The glass tray had a hairline crack or stress fracture that was not visible
  • It got a little too hot in one area
  • The expansion from the heat caused the fracture to expand and therefore crack and break
An accidental bumping of the microwave plate on the countertop while going from the microwave to the dishwasher might set up the above situation. The spoon your seven year old left in the mac and cheese might have arced and nicked a small piece of the glass. Whatever the cause, microwave trays break and they break for a lot of reasons.
All foods cooked in the microwave produce heat. Microwaves themselves are not hot, but the foods cooked in a microwave get hot - some much hotter than others.
Even though most microwave glass trays are tempered, they are not designed to hold up under high temperatures. You will see most microwave trays stamped with the words "For microwave oven use only" This is to let us know that it's probably not a good idea to use the trays in a conventional oven.
Any air pockets, cracks or gaps in the glass can enlarge under heat. Since glass isn't very receptive to being stretched, breakage can occur.
for more you can read on this link
http://www.ebay.com/gds/Why-did-the-glass-tray-in-my-microwave-break-/10000000003014864/g.html
Aug 27, 2013 | Goldstar Microwave Ovens
I have an LG glass cook top stove. It is just 3 years old. While cooking pancakes on a flat pan, the top cracked down the middle..what could have caused this
Only a couple things would cause this First if it is to tight in the opening. Next is there was a small crack on the edge somewhere and when it heated up or the slightest vibration expanded it similar to a small chip in a windshield that grows over time.This could easily happen during installation if not being very careful. And finally is a defect in the material, This is probally unlikely but possible look at the glass very carefully for flaws. If you find any see if LG will repair for free.
Jun 18, 2010 | LG Cooktops
Chip on the screen of our hdtv
This depend on whether its a glass front or one of the perspex faces. Depending on the size of the chip and if its glass there are companies who specialize in using glass resins to repair chips. Windscreen repairers use this material.
If its perspex it is doubtful that any resing or glue will make it clear enough that you wouldn't notice it when viewing. It is possible also to have the whjole glass replaced, but it is not cheap. Insurance ( household) will cover this if you have it.
please rate my help++++Thanks for using FIXYA
May 07, 2010 | Vizio VW32L 32 in. LCD HDTV
How do I replace the back window?
Remove the black vinyl trim from the edge of the glass. Remove broken glass & urethane adhesive from the metal pinchweld leaving a thin layer (approx 1/16") of urethane for new new urethane to adhere to. Vacuum broken glass. Prime nicks to the metal to protect from rusting (also insuring a good surface to bond to). Attach vinyl reveal molding to glass (unless it's a "T" shaped push in type - it would install after the glass is set). Clean and prime the replacement glass. Apply new urethane adhesive. Set glass in place.Slide the metal joint cover in place on the molding (at bottom in the center). Clean outer surface of glass. Allow for safe drive away as noted by urethane manufacturer.
Sep 25, 2009 | 1995 Oldsmobile Cutlass Ciera
GE Microwave/Convection Oven - Door Glass Just Exploded!!!
This happened to us 3 weeks ago with our 3 year old Kitchenaid microwave. Several hours after its last use it just shattered. In doing research I discovered that this has also happend with GE microwaves, all 3 years old. The cause seems to have been a batch of defective glass supplied by a third party. Whirlpool was very quick to cover the cost of the replacement, even though our microwave was out of warrantee.
Aug 27, 2009 | GE JEB1095 Convection/Microwave Oven
Broken glass on front of plasma tv
Some, but not many have the front glass as a replacement, give me the model number so I can check. Oh, pioneer is getting out of the tv business this year ( soon ) if it turns out that the glass cannot be replaced or even ordered you might not feel to bad. They are one of the best at car audio, they decided to go back to the core of there business---------great idea!!!
Jun 04, 2009 | Televison & Video
Sunroof doesn"t open or close
Section 01-17: Roof Panel, Sliding—Electric 1996 Taurus, Sable Workshop Manual DESCRIPTION AND OPERATION Electric Operation The sliding roof panel (502B98):
  • is available as an option.
  • is electrically operated through the accessory delay relay (controlled by generic electronic module (GEM)).
  • is of self-storing design.
  • requires a specific headliner.
  • utilizes a unique roof console and dome lamp.
  • has an air deflector.
The electrical system operates in the following manner:
  • Two switches control movement of the roof panel.
  • When the SLIDE roof sliding panel switch (15B691) is rocked rearward, the roof sliding outer glass panel (502A82) slides into the storage space between the roof trim panel (51968) and the roof panel, exposing an opening over the front seats.
  • When the SLIDE roof sliding panel switch is rocked forward with the roof sliding outer glass panel fully back in the storage space, the roof sliding outer glass panel moves forward from the storage position.
  • The rear portion of the roof sliding outer glass panel moves upward on two lifter arms near the end of the forward travel, allowing a weather-tight seal when the roof sliding outer glass panel is closed.
  • An AUTO feature allows the SLIDE roof sliding panel switch to be touched momentarily to cause the roof panel to automatically move to the fully open position.
  • When the TILT roof sliding panel switch is rocked forward with the roof sliding outer glass panel fully forward, the rear of the roof sliding outer glass panel pops up to the VENT position.
  • With the roof sliding outer glass panel in the VENT position, rocking the TILT roof sliding panel switch rearward closes the roof sliding outer glass panel.
  • Sliding Roof Panel Does Not Open or Close
  • Open power feed fuse.
  • Circuitry open/shorted.
  • Damaged roof sliding panel switch.
  • Damaged sliding roof panel motor.
VISUAL INSPECTION CHART Mechanical Electrical
  • Damaged roof panel
  • Obstructed roof panel
  • Guide
  • Damaged drive cable(s)
  • Open Power Distribution Box Fuses 1 (40A) or 4 (30A)
Apr 19, 2009 | 1996 Ford Taurus
Cast iron pans
Cast iron cookware is NOT recommended due to the weight and the potential damage it can cause to the glass top surface. There's nothing better than a good old-fashioned cast iron skillet that's been broken in over a number of years of use, but they are better suited for gas ranges rather than electric. I hate it. I have several cast iron skillets that I only use on the outdoor grill, because I currently own a glass top electric range.
Aluminum bottom pans and copper bottom pans heat well, but can leave metal transfer marks on the cook top surface. If the marks are cleaned after use with an approved stove top cleaner, you shouldn't have any problem retaining the condition of the glass surface, however. Stainless Steel seems to offer good resistance to metal transfer, but takes a little longer to heat than aluminum or copper. So...you have somewhat of a trade off. Baked enamel cookware seems to be the best recommendation because it heats wells and causes the least amount of damage to your glass top surface.
IMPORTANT: Make sure the bottom of your cookware is FLAT. If your pans are warped or bowed, this can cause uneven heat transfer on the heating elements and potentially cause the cook top to crack. Most manufacturers will not replace the top if it still under warranty if it is determined that your cookware caused the problem.
A little over kill, but I hope this helps you.
Feb 14, 2008 | Maytag MER5770 Electric Kitchen Range
Sony Trinitron experiences
The screen control inside the set may be on the highvoltage transformer or on the crt socket; either way if you can turn it up just a little clockwise and the picture comes up but doesn't look good you are likely to have a bad tube. Or try tapping lightly on the glass neck and watch the picture as you tap. If it reacts to the tap you have a bad tube. but the turning the screen control is the best test. Turn it the other way the picture goes off immediately. bad tube: too costly if it is available.
Dec 29, 2007 | Televison & Video
Sony Trinitron KV35V36 Blinks Every Second
Picture blinks on/off and audio is still there?? If so it's the crt and a common thing for sonys to go out like that.. You can lower the G2 voltage a bit and that might help for awhile or have the tube rejuvenated by a technician - but either idea is only a temporary fix...
Sorry
Bill
Dec 08, 2007 | Sony KV-32FV1 32" TV
Sony FD Trinitron WEGA KD-36FS130 36" TV Logo
109 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
