Question about Garmin iQue 3600 GPS Receiver
My ique 3600 does not respond
The unit turns on but if you touch the screen with the pen it won't respond. I don't use it for about a month but stays in the cradle. I don't know what to do.
  • Anonymous Dec 15, 2007
    HAVE THE SAME PROB.
    ANY IDEAS?
Try resetting the unit and calibrate the screen. The problem is that the screen is not calibrated.
Posted on Dec 31, 2007
SOURCE:
I have a Garmin iQue 3600, I was changing the battery, when opened the unit the switch marked rec esc on the side of the unit flew apart.I need a diagram of how to reassemble it. Thank You
iQue 3600 Undo engl.V.6 Release
Hallo -
I mistakenly IQUE3600 my system 5 at the english version 6 updated, now I have a white screen,
there's nothing more.
Please help
If your IQUE -Problem is not reparabel - I would sale it, for repair my
If your Garmin is beyond repair, I would rate this unit as a spare part for my broken
Buy
Wenn dein Garmin ist unreparierbar, ich würde dieses Gerät als Ersatzteil für mein kaputtes
kaufen
Oct 26, 2010 | Garmin iQue 3600 GPS Receiver
IQue 3600 won't respond properly to stylus. Responds if you touch one item down the lists. Example, to OK something, you have to touch right below the OK. It just recently started this, Maps display...
I solved the problem by re-calibrating the screen. Go to the home icon on the screenn tap preferences, date and time, then tap digitizer. Then follow the prompts and tap exactly on the target Xs.
Thanks!
Oct 01, 2009 | Garmin iQue 3600 GPS Receiver
Dark screen on garmin ique 3600 pda
Turn the unit on and try holding the on/off button down for three oe four seconds.
Mar 13, 2009 | Garmin iQue 3600 GPS Receiver
1 iQue 3600 no Installation Disks or anything else.
You can download for free the installation disk software from www.garmin.com. You can also download a base map, but may have to buy maps from Garmin for more detailed maps/charts. You may need the serial number of the unit to unlock the maps, this is on a paper sticker under the gps antenna.
Mar 06, 2009 | Garmin iQue 3600 GPS Receiver
Ique 3600 antenna reception problem
How long does it try to find the satellites? If it trys for a half hour of more with no results, the antenna may be broken. I have read in other forms that people have added an external antenna and their units would then work, evfen with the built in antenna broken.
Feb 25, 2009 | Garmin iQue 3600 GPS Receiver
Screen replacement for GarminiQue 3600
I have a 3600 that worked perfectly until i hit the "UPDATER" icon at Garmins suggestion, it fried something but the screen and the rest of the unit are in great shape........ I could not shut the unit off so I took the batter out, the screen is fine, if anyone want it for 40 bucks, drop me a line......... [email protected]
Nov 04, 2008 | Garmin iQue 3600 GPS Receiver
Fritzed Unit when antenna up
I have a similar problem but I can't turn the GPS off at all, even when the antenna is down. As far as the power on/off cycle, I found another link on this site that said to turn off WAAS while the GPS is off then when you turn it on the unit will not power cycle continuously. You loose the WAAS feature but the GPS and unit still works.
Jan 24, 2008 | Garmin iQue 3600 GPS Receiver
Ique 3600 can not charge thru cradle and car unit but only thru travel charger, using the pin connector (Green light does not appear when using the main connector on ique 3600, although hot sync and...
Solved:Opened the iQue and used a heated knife to cut horizontally into the + pin and it comes like a U, upside down, from the circuit board, and the exterior side of it was broken. Used tiny plastic and sealant in the hollow space inside the connector and soldered thin copper wire (used for exploding dynamite) from the horizontal part towards the exterior.
Nov 16, 2007 | Garmin iQue 3600 GPS Receiver
Screen Display Problem
Do hard reset? See Owners Manual.
Call Garmin they are very helpfull
Garmin USA 1-913-397-8200
Tech support 1-800-800-1020
1-888-442-7646
8am to 5pm Mon -Fri
Garmin Europe 44 1794-519944
Garmin Taiwan 886 2-26429199
Oct 27, 2007 | Garmin iQue 3600 GPS Receiver
Garmin IQUE 3600 unable to HotSync, Windows XP
I think I have solved this problem.
Try this:
Go to my computer, right click -> Properties -> Hardware -> Device Manager.
Locate your IQUE 3600, or Palm.
Now, if your palm has a Yellow Exclamation mark on it, that means that your computer is not recognizing the Palm. Select
Driver details. Re-install the driver off the "Setup CD" that came with your IQUE 3600.
This worked for me.
Sep 21, 2007 | Garmin iQue 3600 GPS Receiver
Garmin iQue 3600 GPS Receiver Logo
75 people viewed this question
Top Garmin GPS Experts
Marvin
Marvin
Jean-Luc Steffann
Sheldon Dedek
Are you a Garmin GPS Expert? Answer questions, earn points and help others
