Question about Sony WEGA KE-37XS910 37 in. HD-Ready Plasma Television
Vertical Line 4" from left edge of screen
This is type of problem seems to occur in other cases. At first, the line disappeared after the set warmed up. Now, it stays on the screen no matter how long the set is on. I heard that the problem could be due to faulty circuitry. Is there any quick fix for this? Thanks.
  • SonyPlasmaTV Dec 01, 2007
    Are you sure the display panel is defective or is it more of a hunch? If it's the panel, it would be unfixable, but if it's circuitry, it might be worth having it looked at. I know Sony doesn't make plasma screens anymore. It's probably due to Sony's problems with them. Sony used to set the standard, but now they have fallen behind.
  • che82 Apr 15, 2008
    vertical link in the screen lef
Hi...
Your problem is fairly simple to find but more difficult to fix.
Turn the set on for 5 minutes. make sure the black line is showing. Get a hair dryer put it on high speed and max heat. Very gently warm the flat cables connectors one at a time that are attached to the bottom of the display panel. about 1 minute on each should do it. At the same time watch the display in a mirror from the back of the panel. While you are warming one of these connectors usually one close to the centre the black line will dissappear.This is the problem connection. If you can undo the connection very carefully and clean the cable with some contact cleaner and put it back in again you should have solved the problem. All this is done entirely at you own risk. If you think you cannot do it successfully don't try. Don't dissconnect any other board connectors with the set turned on.
All the best from Peter in Australia
Posted on Jan 19, 2009
    President:
  • 1,284 Answers
Sounds like a bad plasma display panel to me. If you notice Sony doesn't make plasmas anymore.
Posted on Dec 01, 2007
Ematic egd103 touch screen work but got line
If the line is vertical, the screen is bad, you may be able to verfy this by pressing on the frame area of the line around the edge of the screen to see if the line disappears. If it does then the connection to that section of the screen has failed.
Feb 09, 2017 | Tablets & eReaders
Vizio VW46LFHDTV10A vertical lines on either side of the screen. I tapped screen and left side lines disappeared.
If you wish to get some details; check the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/ Line faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.
Oct 27, 2016 | Vizio VW46LFHDTV10A 46 in. LCD TV
How do I fix vertical lines on my TV?
Line Defects On Vizio TV Screens - Vizio TV Help
vizhdtv.com/line-defects-on-vizio-tv-screens/
Aug 26, 2015 - If you see a line on your TV screen it might be the result of several causes. Some might be simple to fix and others may actually require you to replace theTV. Pixels on a TVs display panel are organized in groups of straight vertical lines. ...Notice the line defect above is red but they can be white, green, ...
how to repair vizio lcd tv vertical lines then fail - YouTube
? 17:05
https://www.youtube.com/watch?v=YUKMl7_19gk
Jul 5, 2014 - Uploaded by bam6972
how to repair vizio lcd tv vertical lines then fail ... I do know quite a bit, not everything but I do know my fair share about tvs. this tv needed a new ...
TV Repair Help for Vertical & Horizontal Lines on Your TV ...
? 2:47
https://www.youtube.com/watch?v=b0sI7LB4cZE
Apr 25, 2014 - Uploaded by ShopJimmy.com
TV Repair help with troubleshooting lines on your TV Screen. ... I have Vizio M470SL. My TV has .... Why does my T.V. suck Don't buy Rca T.V..
Jan 19, 2016 | Vizio E480-B2 48" 1080p 60HZ LED HDTV
Do you think it is a coincidence that a thin vertical blue line appeared both times when the analogue to digital signal transition was occurring? After the first tower changeover finished it disappear
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Line, faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault to an extent.
Dec 15, 2014 | Panasonic Televison & Video
Led problems
Why do I have a green line on the edge of my screen? If you have a thin green line on the edge of the screen when using an HDMI cable to connect to a cable or satellite box this is usually caused by the box.
To test to see if this is a box issue you will want to take the following steps:
If the TV has a Horizontal position setting in the menu you can adjust the position to see if the line disappears.
You can also change the Wide setting to the Zoom or Panoramic option to see if the line disappears.
If the line disappears you will want to look into getting a different source box.
Your display may be flickering for several reasons. You will want to take the following steps to rule out the most common reasons for the display to flicker:
1. Reseat all cable and connections to the television from your devices. Physically remove the cables from both the television and the device and reconnect them.
2. Check your Advanced Video settings in the Vizio TV menu some of our Vizio televisions will allow you to adjust the following settings under the Advanced Video settings:
Ambient Lighting
Backlight Control
Advanced Adaptive Luma
If you have any of these options available please turn all of them off to see if this resolves the display flickering.
If the above steps have not resolved the issue please take the following steps in the order presented:
1- Power off TV
2- Unplug TV from outlet
3- Press and hold in the power button on the TV for 30 seconds (while it is unplugged from the wall)
4- Release the power button
5- Plug in the TV into a different outlet
6- Power the TV back on
There is also a factory reset option in your menu under the SETUP section. It will say either "reset all settings" or "system reset". We recommend that you reset all settings as well to see if this resolves the issue. If this does not resolve your problem please contact our technical for further assistance.
If the line stays in the same spot when changing the above settings please contact our technical support.
Dec 04, 2011 | Televison & Video
Mitsubishi 46in. LCD
The TCON board at the top of the panel is causing the issue. You will need to replace the whole panel.
When the set warms up, the TCON behaves. Replace the panel now to avoid what will eventually become a permanent line (if not several)
Jan 19, 2009 | Mitsubishi LT-46144 46 in. LCD HDTV
One green vertical line in HDTV Vizio 42
Try changing the H/V position in the TV Set Up menu. You can adjust the horizontal and vertical position of the screen and move it enough that the green line disappears from the screen.
May 18, 2008 | Televison & Video
Toshiba Qosmio G20-117 laptop computer. The display has developed a thin, vertical white line the entire height of the screen about 2cm from the left-hand edge of the screen. Is this a software (screen...
It's a hardware fault, you will normally notice if you push on the screen at the top of the line it will disappear, unfortunately you will have to replace the screen.
May 17, 2008 | Toshiba Computers & Internet
Epson 9800 Prints black dotted vertical line
This is a workaround - I too need a definitive answer. Symptom: black dotted vertical line 1/2 to 3/4" from leftmost image edge. I have begun adding single vertical line to my prints .25" from the left edge of the paper to force the "dots" off my print - this seems to have the desired affect, but it does not answer the cause or provide a true remedy (it will save many of your prints while we wait for complete solution). dkh
Apr 18, 2008 | Epson Stylus Pro 9800 InkJet Printer
A follow-up on my Dell vertical lines issues
I understand that it seems odd that sometimes they disappear.
I have a vertical line on one of my laptops right now that it takes about 3 seconds before it appears on the screen but once it's there. It's there.
I think it has to "warm up" before it comes back.
I used to do Technical support for a company that produced computers with 5inch wide screens, and everytime something with a line was mentioned, "Fix display cable" was the reason.
Because everytime you pushed the screen up to see the keyboard the line disappeared (because the display cable moved) But I digress.
All I'm certain of is that if you change the display cable this will be fixed.
Mar 15, 2008 | Dell UltraSharp 2001FP 20.1" LCD Monitor
Sony WEGA KE-37XS910 37 in. HD-Ready Plasma Television Logo
185 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
