Question about Nikon COOLPIX L3 Digital Camera
Electrical power felt when hook usb camera to computer
I can't touch my camera without filling electrical power thru the body when is connected to PC using usb
  • 797 Answers
This may be a similar problem as was in the Nikon L4.
https://www.nikondealernet.com/sal4/
Call Nikon and see what they say.
Posted on Jul 25, 2008
Whirlpool awe 2217
Sound like your earth ground isn't hooked up.
Sep 01, 2014 | Washing Machines
I can not get a signal thru the usb port from a video camera. It works on a tv.
check computer to make sure usb port is actually hooked up to the motherboard. Alot of times premades (computers purchased already put together, i.e. emachine, acer, gateway etc) will not actually plug the front usb's into motherboard... also check connections in computer to make sure usb is the correct type. I think there are a few different types of usbs.
Aug 02, 2012 | Video Cameras
I USE TO HAVE A LAPTOP AND WAS ABLE TO DOWNLOAD MY PICTURES WITHOUT PROBLEMS. NOW I AM BACK USING A TABLE TOP COMPUTER, I HAVE THIS OTHER CABLE WITH A YELLOW & WHITE MALE IN-PUT AND THE OTHER END FITS...
Yellow and white pins cable is called AV Cable, it is to hook camera with TV. It wont hook camera with computer.
You need USB cable to connect camera with computer. Required USB cable is available in Sony Accessories Store under following part number..
319698101 .... CODE (USB 5P) CONNECTION
Thanks.
Jun 22, 2011 | Sony Cyber-shot DSC-S700 Digital Camera
How do i connect my camera
It depends on the camera model. Most cameras come with either a docking station you put the camera on, and connect through USB to the desktop, or have an USB port - usually a mini-USB port - on the camera body, maybe covered by a panel or patch to keep it dust-free. Sometimes the panels are colored so that they're difficult to spot - Canon 990IS's for example are on the right side, around the lanyard hook, flush with the body and must be pried open with a fingernail.
If you have neither USB port nor docking station, the only way to connect the camera is to purchase the appropriate memory reader. For example if your camera records on a SD card, you need a SD reader. They cost usually less than US$20 and are quite straightforward to use.
Have a nice day
Jan 15, 2010 | Dell Inspiron 530 Desktop Computer
Soon as USB is connected to computer - It freezes up and will not repond until the ipod is reset, using menu and center button. Freezes up also, when IPOD Power Adapter is connected for charging battery....
check your usb drivers are upto date
using the latest usb driver. its your pc that is at fault
not the ipod try connecting to another pc.
Ray
Oct 01, 2009 | Apple iPod touch
Unable to acquire picures from camera to pc
Go into the add hardware wizard with the camera connected to the usb port and power on.
Go thru the procedure and it should start working...
Mar 30, 2009 | Panasonic Lumix DMC-FZ7 Digital Camera
Canon EOS Digital Rebel XT will not connect to computer.
Please discard that the USB port or the USB cable are defective. You can do it if you try to hook your camera in other personal computer using the same USB cable. If it works, then follow the next instructions.
Connect your camera to the PC thru the USB cable and turn it on.
If you are using Windows, go to the Control panel - System - Hardware - Devices - and check if there is any device that was not recognized by Windows. Such devices are marked with a yellow question mark.
If so, get into the device item and with right mouse click, select to update the device driver.
If there was not unrecognized device, then you can unistall your USB port driver and then run a change hardware status to recognize the USB port again, then run the update driver routine.
Regards,
Feb 07, 2009 | Canon Rebel XT / EOS 350D Digital Camera
Ipod not getting connected to itunes nor getting charged, and please recommend which ipod converter to download. Thank you in advance my ipod is not charged, when connected to a computer
hello!
if your IPod touch is not connected to itunes, please try the ff:
Check the iPod touch Display
-- When you connect iPod touch to your computer, the iPod touch should display an image or message on the display
-- If you do not see any image, check some basic troubleshooting here: http://support.apple.com/kb/HT1737
-- If you see a message on the screen, this indicates that the iPod touch does not have sufficient battery charge to operate and will need to be charged for several minutes before it can be recognized in iTunes.
Verify Windows PC System Requirements
--iPod touch requires iTunes 7.4 or later
Check USB Connections
-- iPod touch requires USB 2.0 to function properly
-- Try connecting iPod touch to a different USB port, preferably a port that is built-in to the computer instead of an external USB hub. Connecting iPod touch to your keyboard's USB ports is not recommended.
Restart your PC
-- In some cases, your computer's USB ports may become temporarily disabled or you may experience other software related issues. Restarting your PC is an easy troubleshooting step that may resolve this issue.
Verify iPod touch Driver/Service Installation
-- iPod touch requires two important pieces of software to operate properly on Windows. First, the driver must be installed; for iPod touch the driver is USBAAPL.SYS. Second, Apple Mobile Device Support must be installed as a Windows Service.
May 08, 2008 | Apple iPod touch
USB Connection
I fixed my problem of my HTC touch not Syncing with my phone thru the USB cable.
Go to
Start, Settings, System, Power, Advanced and select/enable the option that says "When device is turned on, do not charge the battery when connected to the PC."
If it still does not work at first then disconnect the USB from your PC/device, wait a few seconds and then plug it back in.
You'll suddenly see your phone and your PC syncing.
Hallelujah!
-Nina Sarkar.
Jan 24, 2008 | HTC Touch P3450 Smartphone
Will not transfer to computer
Does the computer after connecting recognises the Camera thru USB connection/ If the camera is not recognised please update the device driver bfor the camera. It should solve your problem.
Nov 19, 2007 | Nikon COOLPIX L3 Digital Camera
Nikon COOLPIX L3 Digital Camera Logo
19 people viewed this question
Top Nikon Cameras Experts
Steve
Jeff Marcus
Are you a Nikon Camera Expert? Answer questions, earn points and help others
