Question about Brother IntelliFAX 1270E Plain Paper Fax
After static shock, keypad on fax machine is not working...everything else ok
Yesterday, 11-29, someone got a really bad static shock from the fax machine (have been getting shocked since the weather's colder). Immediately after
that happened, the keypad stopped working. There is a dial tone in the handset, and we can receive faxes, but none of the buttons on the machine are
working. We tried unplugging it, waiting and re-plugging it, twice. Nothing changed. None of the buttons make any noise, and none of the buttons being pressed show anything on the display. The display just shows
  • Anonymous Feb 25, 2009
    On our 3rd fax machine / called brother and they sent a refurbished after taking a credit card to assure they get my inop machine back.
    Each fax lasts approx 4 days.
    We have a surge protector on the outlet so I tend to think it is something w/ the machine.
    Scholar:
  • 159 Answers
Most office machines are properly grounded and don't suffer from static problems as severe as this. The machine is not repairable. Before you replace the machine, make sure that your electrical outlets are properly grounded. Then buy a line conditioner that will protect against this.
Posted on Feb 27, 2008
SOURCE:
Can't get fax machine to work. I need to enter ECM mode on the machine so I can receive faxes but on the report print out it's saying mode G3. I can send faxes but can't receive them. Please...
Doubt if you need to set up the fax with ECM ( error correction mode )...a lot of fax's come with ECM these days set to ON. Don't know why because in the majority of cases the phone lines are of good enough quality that its not necessary. However, that said; I would suggest you pick up your handset and listen to the dial tone on the phone/fax line and listen to see if you are hearing static noises...if you do then its likely you have a bad line and should report it to your phone provider.
If the line is good, then I would ask you to try and make a phone call off your fax machine(assuming it has a handset) and again listen to the sounds off the line. I would then get someone locally with a fax machine to send you a test page to see if the machine works from a different number/location.
Jan 06, 2011 | Office Equipment & Supplies
Fax machine will not receive a fax
try switching the fax with a phone and calling... that phone with your cell... see if you have static... if you have static on the line... then call your phone company and have them fix the line... or try putting a magnet filter on the line... next reconnect your fax and call... if your phone line is ok... and it just keeps ringing.... adjust the ring wait time to 2.... if thats doesn't help... you have a bad mainboard...
I’m happy to assist further over the phone at https://www.6ya.com/expert/norman_d2fa496dce30c65d
Dec 10, 2009 | Brother IntelliFax-2820 Laser Fax
Incoming faxes do not print, fax report reads 'power fail' and diplay reads 'low memory' - Can you help?
First, does the machine print normally from a computer or when making copies?
If so, then most probably you have enabled a private receive fax mode. In this mode, faxes are not printed immediately upon receipt (to prevent unauthorized people to read them), but are stored in memory, waiting for an authorized person to come and print them, providing a PIN (password).
To print the faxes stored in memory, do the following:
- press FaxMenu
- using arrow buttons select "receive"
- press OK
- using arrow buttons select "print faxes"
- press OK
- using the alphanumeric keypad enter the PIN/password and press OK
THe previously received faxes should print..
SOmeone must have turned this option on, so ask that person what he/she entered as the PIN.
Dec 04, 2009 | HP Laserjet CM 1312NFI Color Printer
Cant type in fax # or use any buttons on fax machine
Usually it's a static shock that kills the control panel. You need a new control panel PCB.
Aug 06, 2009 | Brother MFC-8440 All-In-One Laser Printer
Muratec MFX1500 - "please call service" message
You probably have a faulty heater lamp or thermostat or thermistor on the exit side of the machine, and so it is not warming up and so giving you the error. check if it is warming up inside the machine where it says hot, but be careful just in case it is really hot( it should be above 100degrees celcius over there). You will need parts for sure.
Mar 18, 2009 | Muratec MFX-1500E Plain Paper Laser Fax
I have a lexmark 2600 and I can't get it to send my fax.
Try attaching another regular phone to the phone line and see if your line from the wall is working first. Then you need to check the cable from the wall to the machine. If all is good, your modem may be bad. Hope this helped!
Mar 12, 2009 | Office Equipment & Supplies
Can't receive faxes.
ok if you got a conformation sheet it should say someware on it OK or NG if you got an OK then it went If that is the case then the line should be good... I believe you have a setting that say manual recive if the grenn light is lit next to that setting it will not pick up automatically it should be off
Dec 11, 2008 | Canon LaserClass LC 8500 Plain Paper Fax
No message recorded. Static when in use.
It sounds like you have damage to an internal component of your phone.
HERE is a link to the manual, if needed.
Jan 23, 2008 | AT&T ATT-1855 Corded Phone
FAX PROBLEMS.. HP Officejet 4315 All-in-One
after selecting FAX answer mode press the OK button to accept the changes.
Oct 20, 2007 | HP Officejet 4215v All-in-One Printer
Brother IntelliFAX 1270E Plain Paper Fax Logo
123 people viewed this question
James Cagle
James Cagle
Jim Keysor
ctnozil
