It seems that the NumLock is accidentally hit. You have to look for the Fn key. Usually its blue or white and on the lower left portion of the keyboard.
Hit Fn followed by the Numlock key. This should release your keyboard from numeric to alphanumeric.
NUMBER LOCK You have press the NumLk key (number lock) and this changes the right hand keys to a number pad. Press the NumLk key (also doubles as the ScrLk key to toggle the Number lock). it is near the F12 function key. When the NumLk has been enabled a LED light is turn on to indicate this function has been selected. Press the NumLk key again to turn off the Number Lock.
The NumLkkey has been pressed andthe letters on the righr hand side on the keyboard has been converted to a number pad. The NumLk key also doubles up as the ScrLk key, this is located near the F12 function key. Whenyou press this key to turn on the Numlk a LED will light up to indicate that the Number Lock has been pressed, press this key again to turn off the Number Lock and the NumLk LED will switch off and you will be able to type letters again.
You more then likely have the number lock on look for a key that has a num lock(or numlk) on it if its a laptop it is more then like the letter key that has numbers on them. look for a key on the lower left hand side of the key board that has fn on it hold that key down and then press the key that has num lock or num lk on it and that should fix the problem.
This should be a simple fix, look at your keyboard, you should have a function key and if you look at the number pads above the top row of letters there should be either a numerical symbol or a key pad, your keyb board is simply using several keys as an extended numerical keypad. If you look closely at the letters there are small numbers on them. To fix hold down function key and pressing the keypad button. You can also try pressing the number lock.
Look for the numlock light somewhere near the keyboard. It's the light with a drawing of a lock with a 9.
If it's lit up. turn it off by pressing the numlock key.
Turning it back on will activate the number keypad (consists of 9-11 keys in the middle of the keyboard). So instead of getting letters, numbers appear.
Hope this is your case. Kindly rate me if the issue got fixed.
