Question about Kaz Oil Filled Radiator Heater
Heater won't stay on
When i turn heater on it runs for just a few minutes & then shuts off.
  • mattie405 Dec 07, 2008
    Bought this unit about 3-4 years ago and used it twice back then. Took it out tonight and it won't turn on. It lights up for about one second then goes out. Read then online manual but no help there. Why does your furnace always go out on the coldest night and on a weekend to boot. Though this heater would carry me thru until Monday but guess I'll be chilly until the furnace guy can come.
This product does indeed have a problem with the safety switch, that is only supposed to kick in when the unit is turned over. I had a total of 3 units sent to me from Kaz. Each time the unit would work for a short time, then slowly begin to turn off and on. I finally decided to take the unit apart and look for any obvious problems. There is a weighted swivel that will raise a contact point to turn the unit off in an emergency. The contact points would spark off and on, depositing a black carbon on them until they would no longer allow power to pass through. I cleaned the contacts with a fine finger nail file and bent one of the contact arms inward to make better tension between the contacts. This allowed the unit to stay on for longer periods of time. But even with the thermo-stat turned all the way up, the unit does not stay on long enough to heat the room. In effect, what happens is the contacts will continue to ark, putting black deposits on the contacts until you're back to square one. Apparently the unit also has a thermo-stat related problem. I'm sending the unit back again (they only made me send the power cord last time), but will insist on a different model this time. Good Luck
Posted on Feb 24, 2008
    Sergeant:
  • 288 Answers
I am assuming you have made sure its not the thermostat, it sounds like a safety device is shutting the unit down. You didn't give any specific info, but if it is a safety cutting it off you need to determine if it faulty or just doing its job.
Posted on Nov 30, 2007
4 Suggested Answers
stpaulmercan
  • 8 Answers
SOURCE: Heater will not stay light
90% of the time, this problem is caused by either a clogged gas orifice on the pilot light's gas line, or by dust/debris in the pilot air intake, as stated by tradesman1. Start by blowing compressed air through the pilot air intake, both directions. If that doesn't solve the problem, remove the pilot assembly, then the pilot orifice, and blow compressed air backwards through the small orifice. The bottom line is that anything that causes the pilot flame to reduce in size will trigger the oxygen depletion system and that will result in the unit shutting itself off. This is a safety measure. Other possible causes: insufficient gas pressure to the unit, high altitude, defective thermocouple.
Posted on Jun 11, 2009
SOURCE: oil filled heater wont stay on
I was having the same problem and did a search to find this link. This morning when I turned it on, I backed the temperature down to 66 when it first came on (defaults to 70) and it appears to be working now (it's been on for over 10 minutes)
Posted on Dec 18, 2008
SOURCE: paloma tankless water heater won't stay on during operation.
I have a Paloma model RUTG-74PVP, I had the same problem after less than a year. The unit would operate for about 90 seconds and then shut off with an error code of C13. Paloma kept trying to blame it on "lack of combustable oxygen" ,, my unit is in the attic, so we added more soffit vents and an electric attic fan. We still had the problem and Paloma blamed it on the lack of a condensation trap (so I added one), & then on the 1" dedicated LP Gas line (so I had the propane guy come run a water column test). Finally, 4 months later , Paloma had a service man come down (100 miles away) to see what was wrong (He told them to replace it. They paid for the unit and labor. It ran perfect for about 9 months and then started doing it again. So I called the same representative and asked if they were gonna replace this one too? He said nope, it's no longer under warranty. But he did tell me how to fix it this time. It required taking the the whole unit apart and cleaning a ceramic piece in the very back of the heater. It was hard to get to, and it took about 2 hours of disassembling and reassembling. The good news is Paloma will walk you thru it on the phone and once it's was done, my system worked properly again. The bad news is,, it only lasted for about 9 months. So now I need to do it again. I'm hoping that someone will read this and tell me that there is a filter (like a gas filter) that I can install that is easier to get to.
Posted on Jan 31, 2010
I have a toastmaster model 2517 space heater. it comes on for a few minutes and then shuts off and then in a few minutes then comes back on. is that normal for that model? if not,how do I fix it?
it sounds like it is turning off when it reaches the temperature setting you have it at. turn it a little higher and see if it stays on longer.
Mar 05, 2015 | Heating & Cooling
Iaqualink heater shuts down after a few minutes
Does the heater continue to fire if you run it in service mode? If so it probably is an Aqualink issue. I'd call the factory on that one and they should be able to get a rep or authorized service company to see what's happening.
If the heater is also shutting off in service mode the problem may be in the bypass ***'y. This is not an uncommon issue with the Minimax. Too much water is bypassing the heater and the water that does get in is staying there too long, triggering the high limit switch which will shut down the heater.
Dec 25, 2013 | Zodiac iQ904-P iAqualink Pool Only
Heater won t stay lit
check gas pressure sounds like running out of gas meter might be too small
Jun 23, 2013 | Hayward Pool & Spa
The hot water shuts down for a few minuts then
your unit is undersized or you do not have enough gas supply to run the unit properly.
If you have to many water features running or you have to many gas items turn on at the same time it can cause problems.
Apr 10, 2010 | Rinnai Water Heaters
The heater comes on for a few seconds then shuts off but once or twice a week it comes on and operates like a normal heater
Mine does the same thing. I have a gas heater. It will fire up- run for less then a minute then shut off. then 2 minutes later does the same thing. I'm thinking of going with a differeny brand because this is using a lot of gas evertime it fires up just for a minute. if I turn it up it stays on till it reaches the temp then does that on off thing again. i think it is just the so called "feature" Honeywell is claiming to maintain the temp in our home, not realizing it is wasting your gas or electricity.
Feb 23, 2010 | Honeywell Programmable Thermostat Heater
Heaters runs for a few minutes then shuts off.
was working fine refilled it and now it will run 5sec. and kick the breaker on it.It's an old 80's model 35,000 B.T.U. I cleand the photo eye with a cloth no change. Any solution's
Jan 29, 2010 | Reddy Heater-30-55,000 BTU Variable
Gsw heater pilot stays lit, but when the main
It sounds like your main valve. The diaphram may be loose fitting or it has a small leak.
Oct 03, 2009 | Fasco GSW Hot Water Heater Exhaust Draft...
Wont stay lit
when unit lights only runs 10 sec then shuts off
Oct 27, 2008 | Reddy Heater-170,000 BTU Kerosene Deluxe
Heating & Cooling Logo
2,489 people viewed this question
Top Kaz Heating & Cooling Experts
Paul Carew
Mack Baxter
Marvin
Marvin
Are you a Kaz Heating and Cooling Expert? Answer questions, earn points and help others
