Question about Dell E151FP 15" Flat Panel LCD Monitor
Inverter part show me the inverter location in circuit board
  • 3 Answers
After you remove the metal plate covering the electronics, you will see the circuit board(s). The larger one is what is described as having the inverter as part of it, or what they call the inverter. Go to this website:
http://www.lcdrepair.us/FAQ.html
to get more info.
Posted on Jan 29, 2008
SOURCE:
My sensui tv model i2i21 shows blur pic when i start it but after some half hour it shows clear pic pls help
Back - light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis.
To some model sets; especially LED back-lighted types; the back-light inverter circuit will be part of the main power supply board [SMPS]. In such cases, the power supply board might need replacement. To some models sets, the back-light inverter and SMPS section circuit will be integrated at its main board itself. If so; the main board should be replaced. To some models of sets, all these section circuit will be integrated at its main board. If this is the case, you have to replace the main board.
Sep 04, 2017 | Televison & Video
My LED TV is not showing in video but audio is fine. There dont seems to be backlight visible from the back. Flash light test shows images and videos on the screen.
Back - light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis. http://electronicshelponline.blogspot.com/ To some model sets; especially LED back-lighted types; the back-light inverter circuit will be part of the main power supply board [SMPS]. In such cases, the power supply board might need replacement. To some models sets, the back-light inverter and SMPS section circuit will be integrated at its main board itself. If so; the main board should be replaced. To some models of sets, all these section circuit will be integrated at its main board. If this is the case, you have to replace the main board.
Jan 13, 2017 | Televison & Video
I need to know where to locate the back light inverter for a Hitachi LE55a6r9a hdtv.
Jan 02, 2017 | Hitachi Televison & Video
My tv won't show picture only volumne
Nov 13, 2016 | Televison & Video
When i turn my Sharp Aquos on the power green light will show and the screeb will show for 2 seconds and go dark while the green light will still be on. what could be the problem?
Sep 11, 2016 | Sharp Televison & Video
MY TELEFUNKEN TV IS NOT SHOWING PICTURES AND THERE SOUND. HOW TO FIX THIS PROBLEM?
http://electro-medical.blogspot.com/
Mar 04, 2016 | Televison & Video
Toshiba LCD 2009 TV picture won't show when turned on but sound works fine. Picture shows after 4-5 minutes. Help...
Jan 02, 2016 | Toshiba Televison & Video
This TV started to fail by showing degradation in the images, and now does not show images at all although the sound is as good as it always was. Its age is only two years.
Dec 07, 2015 | Televison & Video
Where is the inverter board located in the sanyo dp42849
Aug 22, 2012 | Sanyo DP42849 42 in. HDTV
Why has screen gone black on compaq 8510p. Can vaguely see print
Sounds like either your backlight bulb has failed or the inverter that powers the bulb has failed or a connection has come loose from the inverter to the LCD panel. Unless the laptop was "Jarred" or dropped, I doubt the bulb has burned out....most likely if no damage occued, the inverter has failed or there is a loose connection with the inverter.
Jun 30, 2010 | HP Compaq 8510p Notebook
Dell E151FP 15" Flat Panel LCD Monitor Logo
237 people viewed this question
Ekse
Clive
Clive
